I am using YOLOP for my application.
I am using Jetson Xavier for my application.
Since there is no docker file, I created a custom dockerfile. Please find dockerfile attached. Docker build was successful. But when i run below command inside container as mentioned in the readme instruction for testing an image, i get below error and i am not able to figure out what is the issue and what is the solution.
command executed:
python3 tools/demo.py --source images/inp --save-dir images/outp
Error Log:
File "/usr/local/lib/python3.6/dist-packages/sklearn/__check_build/__init__.py", line 44, in <module>
from ._check_build import check_build # noqa
ImportError: /usr/local/lib/python3.6/dist-packages/sklearn/__check_build/../../scikit_learn.libs/libgomp-d22c30c5.so.1.0.0: cannot allocate memory in static TLS block
During handling of the above exception, another exception occurred:
File "tools/demo.py", line 29, in <module>
from lib.core.postprocess import morphological_process, connect_lane
File "/yolop/lib/core/postprocess.py", line 6, in <module>
from sklearn.cluster import DBSCAN
File "/usr/local/lib/python3.6/dist-packages/sklearn/__init__.py", line 81, in <module>
from . import __check_build # noqa: F401
File "/usr/local/lib/python3.6/dist-packages/sklearn/__check_build/__init__.py", line 46, in <module>
raise_build_error(e)
File "/usr/local/lib/python3.6/dist-packages/sklearn/__check_build/__init__.py", line 41, in raise_build_error
%s""" % (e, local_dir, ''.join(dir_content).strip(), msg))
___________________________________________________________________________
Contents of /usr/local/lib/python3.6/dist-packages/sklearn/__check_build:
__pycache__ _check_build.cpython-36m-aarch64-linux-gnu.so__init__.py
setup.py
It seems that scikit-learn has not been built correctly.
If you have installed scikit-learn from source, please do not forget
to build the package before using it: run `python setup.py install` or
`make` in the source directory.
If you have used an installer, please check that it is suited for your
Python version, your operating system and your platform.
yolop.Dockerfile (4.3 KB)
Regards,
Monalisa
