SLB9670 TPM interupt config on Jetson Nano
I am trying to get a SLB9670 SPI based TPM working with a Jetson Orin Nano on a custom carrier board. The TPM is mostly functional, but I am having some troubles configuring the interrupt correctly.
I am seeing the following error message in the kernel logs when probing the device:
[  627.473792] tpm_tis_spi spi1.0: 2.0 TPM (device-id 0x1D, rev-id 54)
[  627.480711] tpm tpm1: [Firmware Bug]: TPM interrupt not working, polling instead
Below is a condensed version of my device-tree configuration:
  bus@0 {
    pinmux@2430000 {
      status = "okay";
      pinctrl-names = "default";
      pinctrl-0 = <&tpm_pinmux>;
      tpm_pinmux: tpm {
        // GPIO14 <- TPM_PIRQ_N
        gpio14-slb9670-irq {
          nvidia,pins = "gp_pwm3_px3";
          nvidia,pull = <TEGRA_PIN_PULL_NONE>;
          nvidia,tristate = <TEGRA_PIN_DISABLE>;
          nvidia,enable-input = <TEGRA_PIN_ENABLE>;
        // SPI1_MOSI
        spi1-mosi {
          nvidia,pins = "spi3_mosi_py2";
          nvidia,function = "spi3";
          nvidia,enable-input = <TEGRA_PIN_DISABLE>;
        // SPI1_MISO
        spi1-miso {
          nvidia,pins = "spi3_miso_py1";
        // SPI1_CS0
        spi1-cs0-slb9670 {
          nvidia,pins = "spi3_cs0_py3";
          nvidia,function = "gp";
        // SPI1_CLK
        spi1-sclk {
          nvidia,pins = "spi3_sck_py0";
    pinmux@c300000 {
      status = "okay";
      pinctrl-0 = <&tpm_pinmux_aon>;
      tpm_pinmux_aon: tpm-aon {
        // GPIO05 -> TPM_PP
        gpio05-slb9670-present {
          nvidia,pins = "spi2_mosi_pcc2";
          nvidia,pull = <TEGRA_PIN_PULL_UP>;
        // GPIO_06 -> TPM_RST_N
        gpio06-slb9670-nreset {
          nvidia,pins = "spi2_cs0_pcc3";
    spi@3230000 {
      status = "okay";
      cs-gpios = <&gpio TEGRA234_MAIN_GPIO(Y, 3) GPIO_ACTIVE_LOW>;
      num-cs = <1>;
      /delete-node/ spi@0;
      // TPM: SPI1_CS0
      tpm_slb9670: slb9670@0 {
          compatible = "infineon,slb9670";
          status = "okay";
          reg = <0>;
          spi-max-frequency = <32000000>;
          reset-gpios = <&gpio TEGRA234_AON_GPIO(CC, 3) GPIO_ACTIVE_LOW>;
          interrupts = <TEGRA234_MAIN_GPIO(X, 3) IRQ_TYPE_EDGE_FALLING>; // GPIO14
          interrupt-parent = <&gpio>;
The PIRQ signal from the TPM is connected to GPIO14 on the Jetson (gp_pwm_px3 on the SoC)
There is also 10k external pullup on the PIRQ signal from the TPM.
I’ve put a logic analyzer on the interrupt line near the TPM previously, and I do see the TPM toggling the interrupt line.
Any help would be greatly appreciated. Thanks!
hello cameron50,
it seems you should not using an interrupt..
