I am trying to utilize SMB Direct ( SMB over RDMA) on some of my Windows 2012 severs using IB. Does anyone have any directions, links, or advice?
What is the problem?
Did you look here?
https://community.mellanox.com/s/article/windows-driver-solutions
Right now I have the servers connected back to back. The servers have pci gen 3x8. I followed these directions Archived MSDN and TechNet Blogs | Microsoft Docs Archived MSDN and TechNet Blogs | Microsoft Docs to setup SMB Direct. I do a drag and drop copy and maybe get 3 Gbps for a second then under 1 Gbps.
There are some helpful links there, but it mostly talks about RoCE.
I have to servers with connect x-3 cards. They have SMB multichannel and SMB Direct enabled. From some of the directions I’ve seen that is pretty much the extent of the configuration. I copy over 60GB of data, but I’m only seeing maybe 4 Gbps transfer.
Can you share the configuration, connectivity and so on.
Are the servers connected back to back? what is the topology?
Are the servers with PCI gen 3 x8? Tuned to performance?
Thanks,
Ophir.
it should be better,
make sure that RDMA is running.
Try to follow this post, and send your feedback.
HowTo Configure RoCE in Windows Environment (Global Pause) https://community.mellanox.com/s/article/howto-configure-roce-in-windows-environment--global-pause-x
