I’m trying to sniff RoCE traffic on a ConnectX-6 adapter.
As for ConnectX-5, Offloaded Traffic Sniffer feature is removed. So I used the mellanox/tcpdump-rdma Docker container. However, even the container does not work:
[root@nslrack05 /]# tcpdump -i mlx5_1
tcpdump: mlx5_1: No such device exists
(SIOCGIFHWADDR: No such device)
What am I missing? Thanks in advance.
Hello Mariano,
To sniff RoCE traffic with tcpdump, please review the information (for ConnectX-4 and above) provided below:
https://community.mellanox.com/s/article/how-to-dump-rdma-traffic-using-the-inbox-tcpdump-tool–connectx-4-x
Information on installing and build tcpdump and libpcap below :
http://books.gigatux.nl/mirror/snortids/0596006616/snortids-CHP-2-SECT-4.html
Download latest libpcap 1.10 and tcpdump 4.99 from https://www.tcpdump.org/
Extract, Configure, compile and install:
configure --enable-rdma --prefix=
make -j
make install
set LD_LIBRARY_PATH to use new pcap library
export LD_LIBRARY_PATH=/lib
Run command below to check if current tcpdump reports RDMA capable interfaces
tcpdump --list-interfaces |grep RDMA
Run RoCE traffic and tcpdump
tcpdump -i mlx5_0
If after reviewing the documentations above and you still have issue with issue with sniff RoCE traffic issue, please open a support case and we will provide further assistance. If you do not have a current support contract, please email the Nvidia team at Networking-contracts@nvidia.com to set up a valid support contract.
Thank you,
Nvidia Networking Support
