I have run ethtool --set-priv-flags enp3s0f1 sniffer on but it shows
ethtool: bad command line argument(s)
For more information run ethtool -h
then I run
ethtool --show-priv-flags enp3s0f1
it shows
Private flags for enp3s0f1:
rx_cqe_moder : on
tx_cqe_moder : on
rx_cqe_compress : on
tx_cqe_compress : on
rx_striding_rq : on
rx_no_csum_complete: on
dropless_rq : on
per_channel_stats : on
hw_lro : on
tx_xdp_hw_checksum : on
skb_xmit_more : on
There is no sniffer at all !!! And would you like to tell me how to solve this problem?
chenh1
August 25, 2020, 7:44am
#2
Hi Luo,
We removed support for Offloaded Traffic Sniffer feature, but we can suggest using the docker-container solution to use RDMA devices, in order to capture and analyze RDMA packets using tcpdump.
Requirements
- ConnectX-3/4/5
Installation instructions:
Install OS that is compatible with kernel 4.9 and above
Install Upstream kernel starting from version 4.9 support sniffing RDMA(RoCE) traffic
Yum install docker
Docker pull mellanox/tcpdump-rdma
Service docker start
Docker run -it -v /dev/infiniband:/dev/infiniband -v /tmp/traces:/tmp/traces --net=host --privileged mellanox/tcpdump-rdma bash
Install MFT 4.9
Install perftest package from MLNX_OFED RPMS directory
Capture RoCE packets with the following:
tcpdump -i mlx5_0 -s 0 -w /tmp/traces/capture1.pcap
or
tcpdump -i mlx4_0 -s 0 -w /tmp/traces/capture1.pcap
Run ib_write_bw test , as below:
Server : ib_write_bw -d mlx5_0 -a -F
Client: ib_write_bw -a -F <Server_ip>
Open the pcap through wireshark to verify
Regards,
Chen
Where can one find the upstream kernel necessary for this Docker container approach?
