Hi support,
We have integrated a driver for tc358743 chip (HDMI 2 CSI bridge).
This driver is using the Nvida kernel API, the soc_camera API:
soc_camera_power_on(&client->dev, scsd);
When we load the driver tc358743 and launch our V4L2 program, the CSI synchronisation suceed (The HDMI source is a computer).
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.40-gafe5771-dirty (qualistream@qse-test-1) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #44 SMP PREEMPT Thu Dec 8 09:39:38 CET 2016
[ 0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: jetson-tk1, model: NVIDIA Tegra124 PM375, serial: 0
[ 0.000000] Truncating memory at 0x80000000 to fit in 32-bit physical address space
[ 0.000000] Found tsec, start=0xf4900000 size=2000000
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: f46ff000 - f46ff80f
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: f8500000 - f96fffff
[ 0.000000] 2nd Framebuffer: f9700000 - fdefffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Tsec: f4900000 - f68fffff
[ 0.000000] cma: CMA: reserved 16 MiB at 9e000000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] On node 0 totalpages: 492288
[ 0.000000] free_area_init_node: node 0, pgdat c0cfc300, node_mem_map c0e09000
[ 0.000000] Normal zone: 992 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 126976 pages, LIFO batch:31
[ 0.000000] HighMem zone: 3038 pages used for memmap
[ 0.000000] HighMem zone: 365312 pages, LIFO batch:31
[ 0.000000] DTS File Name: arch/arm/boot/dts/tegra124-jetson_tk1-pm375-000-c00-00.dts
[ 0.000000] Tegra12: CPU Speedo value 2292, Soc Speedo value 2287, Gpu Speedo value 2120
[ 0.000000] Tegra12: CPU Speedo ID 1, Soc Speedo ID 1, Gpu Speedo ID 1
[ 0.000000] Tegra12: CPU Process ID 1,Soc Process ID 1,Gpu Process ID 1
[ 0.000000] Tegra Revision: A01 SKU: 0x81 CPU Process: 1 Core Process: 1
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
[ 0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1092000000
[ 0.000000] Lowering sbus maximum rate from 420000000 to 384000000
[ 0.000000] Lowering vic03 maximum rate from 900000000 to 828000000
[ 0.000000] Lowering tsec maximum rate from 900000000 to 828000000
[ 0.000000] Lowering msenc maximum rate from 600000000 to 528000000
[ 0.000000] Lowering se maximum rate from 600000000 to 528000000
[ 0.000000] Lowering vde maximum rate from 600000000 to 528000000
[ 0.000000] Lowering host1x maximum rate from 500000000 to 444000000
[ 0.000000] Lowering vi maximum rate from 700000000 to 600000000
[ 0.000000] Lowering isp maximum rate from 700000000 to 600000000
[ 0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
[ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
[ 0.000000] Lowering sdmmc1 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering sdmmc3 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 2320500000
[ 0.000000] tegra dvfs: VDD_CPU nominal 1260mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_CORE nominal 1150mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] ------------[ cut here ]------------
[ 0.000000] WARNING: at arch/arm/mach-tegra/clock.c:969 tegra_common_init_clock+0x54/0x84()
[ 0.000000] tegra: sbc1 boot rate 12000000 exceeds max rate 2000000
[ 0.000000] Modules linked in:
[ 0.000000] CPU: 0 PID: 0 Comm: swapper Not tainted 3.10.40-gafe5771-dirty #44
[ 0.000000] [<c0016418>] (unwind_backtrace+0x0/0x140) from [<c0012f48>] (show_stack+0x18/0x1c)
[ 0.000000] [<c0012f48>] (show_stack+0x18/0x1c) from [<c00638ec>] (warn_slowpath_common+0x54/0x70)
[ 0.000000] [<c00638ec>] (warn_slowpath_common+0x54/0x70) from [<c00639b4>] (warn_slowpath_fmt+0x38/0x48)
[ 0.000000] [<c00639b4>] (warn_slowpath_fmt+0x38/0x48) from [<c0b3f818>] (tegra_common_init_clock+0x54/0x84)
[ 0.000000] [<c0b3f818>] (tegra_common_init_clock+0x54/0x84) from [<c0b3ef7c>] (tegra12x_init_early+0xe4/0x160)
[ 0.000000] [<c0b3ef7c>] (tegra12x_init_early+0xe4/0x160) from [<c0b3a0e0>] (setup_arch+0x150/0x19c)
[ 0.000000] [<c0b3a0e0>] (setup_arch+0x150/0x19c) from [<c0b37878>] (start_kernel+0x78/0x2bc)
[ 0.000000] [<c0b37878>] (start_kernel+0x78/0x2bc) from [<80008074>] (0x80008074)
[ 0.000000] ---[ end trace 1b75b31a2719ed1c ]---
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] tegra12_plle_clk_enable: pll_e is already enabled
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1df1000 s15360 r8192 d13312 u36864
[ 0.000000] pcpu-alloc: s15360 r8192 d13312 u36864 alloc=9*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 491296
[ 0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00 tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal fbcon=map:1 commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 board_info=0x0177:0x0000:0x02:0x43:0x00 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt vmalloc=512M
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 1923MB = 1923MB total
[ 0.000000] Memory: 1921404k/1921404k available, 141956k reserved, 1461244K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xdf800000 - 0xff000000 ( 504 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdf000000 ( 496 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b366b0 (11450 kB)
[ 0.000000] .init : 0xc0b37000 - 0xc0bb6c00 ( 511 kB)
[ 0.000000] .data : 0xc0bb8000 - 0xc0d15560 (1398 kB)
[ 0.000000] .bss : 0xc0d15560 - 0xc0db0454 ( 620 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:960
[ 0.000000] the number of interrupt controllers found is 5
[ 0.000000] Architected local timer running at 12.00MHz (phys).
[ 0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863311536128ns
[ 0.000000] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.004566] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=12000
[ 0.004638] pid_max: default: 32768 minimum: 301
[ 0.004946] Mount-cache hash table entries: 512
[ 0.027441] Initializing cgroup subsys debug
[ 0.027487] Initializing cgroup subsys freezer
[ 0.027596] CPU: Testing write buffer coherency: ok
[ 0.027671] ftrace: allocating 34472 entries in 68 pages
[ 0.072690] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.072736] Setting up static identity map for 0xc08048c8 - 0xc0804974
[ 0.076713] ftrace: Allocated trace_printk buffers
[ 0.084361] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.087380] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.090405] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.090598] Brought up 4 CPUs
[ 0.090664] SMP: Total of 4 processors activated.
[ 0.090683] CPU: All CPU(s) started in SVC mode.
[ 0.091659] devtmpfs: initialized
[ 0.100231] pinctrl core: initialized pinctrl subsystem
[ 0.100567] regulator-dummy: no parameters
[ 0.101301] NET: Registered protocol family 16
[ 0.103691] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.105010] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
[ 0.106489] console [pstore-1] enabled
[ 0.106529] ramoops: attached 0x200000@0xf8300000, ecc: 0/0
[ 0.106918] cpuidle: using governor ladder
[ 0.106942] cpuidle: using governor menu
[ 0.110021] Unable to clip rate for parent pll_p of clock sbc1: -22
[ 0.110653] ardbeg_camera_auxdata: update camera lookup table.
[ 0.119237] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
[ 0.119636] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.126493] Wake16 for irq=34
[ 0.128963] Wake58 for irq=81
[ 0.129013] Wake41 for irq=129
[ 0.129032] Wake43 for irq=129
[ 0.129095] Wake40 for irq=53
[ 0.129115] Wake42 for irq=53
[ 0.133179] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x43:0x44:0x00
[ 0.133264] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x43:0x44:0x00
[ 0.133331] disp1 pclk=154700000
[ 0.133341] disp2 pclk=297000000
[ 0.133350] Selecting UARTD as the debug console
[ 0.133397] The debug console clock name is uartd
[ 0.133817] ardbeg_modem_init: modem_id = 0
[ 0.136495] Clear bootloader IO dpd settings
[ 0.136733] Loading jetson TK1 EMC tables.
[ 0.136983] tegra: pll_m is selected as scalable EMC clock source
[ 0.137030] Lowering emc maximum rate from 1200000000 to 924000000
[ 0.137060] tegra: validated EMC DFS table
[ 0.137191] ardbeg_edp_init: CPU regulator 11000 mA
[ 0.493630] ardbeg_edp_init: GPU regulator 11400 mA
[ 0.494646] swapper/0 isomgr_init(): iso emc max clk=924000KHz
[ 0.494668] swapper/0 isomgr_init(): max_iso_bw=7392000KB<6>[ 0.577849] platform tegradc.0: IOVA linear map 0xf8500000(1200000)
[ 0.581189] platform tegradc.0: IOVA linear map 0xf9700000(4800000)
[ 0.586245] platform tegradc.1: IOVA linear map 0xf8500000(1200000)
[ 0.589579] platform tegradc.1: IOVA linear map 0xf9700000(4800000)
[ 0.589717] ardbeg_camera_init: QSCSI ++
[ 0.589888] *** tc358743 START *** tc358743uirq_init...
[ 0.589934] *** tc358743 END *** tc358743irq_init...
[ 0.590162] FUSE: cp_rev 0 ft_rev 0
[ 0.590336] tegra11_soctherem_oc_int_init(): OC interrupts are not enabled
[ 0.590758] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.590789] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.591092] mc-err: Started MC error interface!
[ 0.601639] bio: create slab <bio-0> at 0
[ 0.603502] reg-fixed-voltage 0.regulator: Consumer c1 does not have device name
[ 0.603540] reg-fixed-voltage 0.regulator: Consumer c2 does not have device name
[ 0.603572] of_get_named_gpio_flags: can't parse gpios property
[ 0.603698] vdd-ac-bat: 8400 mV
[ 0.603835] reg-fixed-voltage 1.regulator: Consumer c1 does not have device name
[ 0.603871] reg-fixed-voltage 1.regulator: Consumer c2 does not have device name
[ 0.603902] of_get_named_gpio_flags: can't parse gpios property
[ 0.604000] vdd-3v3-aon: 3300 mV
[ 0.604149] reg-fixed-voltage 8.regulator: Consumer c1 does not have device name
[ 0.604184] reg-fixed-voltage 8.regulator: Consumer c2 does not have device name
[ 0.604217] reg-fixed-voltage 8.regulator: Consumer c3 does not have device name
[ 0.604256] reg-fixed-voltage 8.regulator: Consumer c6 does not have device name
[ 0.604289] reg-fixed-voltage 8.regulator: Consumer c7 does not have device name
[ 0.604321] reg-fixed-voltage 8.regulator: Consumer c8 does not have device name
[ 0.604353] reg-fixed-voltage 8.regulator: Consumer c9 does not have device name
[ 0.604385] reg-fixed-voltage 8.regulator: Consumer c10 does not have device name
[ 0.604419] reg-fixed-voltage 8.regulator: Consumer c11 does not have device name
[ 0.604451] reg-fixed-voltage 8.regulator: Consumer c12 does not have device name
[ 0.604497] of_get_named_gpio_flags: can't parse gpios property
[ 0.604587] reg-3v3-supply: 3300 mV
[ 0.606210] vgaarb: loaded
[ 0.606858] SCSI subsystem initialized
[ 0.607053] libata version 3.00 loaded.
[ 0.607233] usbcore: registered new interface driver usbfs
[ 0.607298] usbcore: registered new interface driver hub
[ 0.607406] usbcore: registered new device driver usb
[ 0.607641] of_get_named_gpio_flags exited with status 20
[ 0.607679] of_get_named_gpio_flags exited with status 21
[ 0.608085] of_get_named_gpio_flags exited with status 157
[ 0.608103] of_get_named_gpio_flags exited with status 158
[ 0.608332] of_get_named_gpio_flags exited with status 217
[ 0.608349] of_get_named_gpio_flags exited with status 218
[ 0.608580] of_get_named_gpio_flags exited with status 172
[ 0.608598] of_get_named_gpio_flags exited with status 173
[ 0.608854] of_get_named_gpio_flags exited with status 206
[ 0.608871] of_get_named_gpio_flags exited with status 207
[ 0.610279] as3722 4-0040: AS3722 ID: ID1:ID2:ID3 = 0x0c:0x01:0x15
[ 0.610311] as3722 4-0040: Final OTP version 1V21
[ 0.614921] gpiochip_find_base: found new base at 1016
[ 0.615011] gpiochip_add: registered GPIOs 1016 to 1023 on device: as3722-gpio
[ 0.615048] GPIO chip as3722-gpio: created GPIO range 0->7 ==> as3722-pinctrl PIN 0->7
[ 0.615214] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.615274] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.615329] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.615363] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.615397] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.615430] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.615490] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.615524] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.615557] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.615590] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.615624] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.615656] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.615690] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.615778] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.615812] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.615846] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.615879] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.615914] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.615950] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.615983] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.616016] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.616049] as3722-regulator as3722-regulator.0: Consumer c11 does not have device name
[ 0.616083] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[ 0.616116] as3722-regulator as3722-regulator.0: Consumer c13 does not have device name
[ 0.616149] as3722-regulator as3722-regulator.0: Consumer c14 does not have device name
[ 0.616182] as3722-regulator as3722-regulator.0: Consumer c15 does not have device name
[ 0.616238] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.616271] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.616326] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.616359] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.616392] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.616425] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.616458] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.616491] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.616524] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.616557] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.616590] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.616649] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.616683] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.616792] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.616826] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.616859] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.616915] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.616967] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.617001] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.617034] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.617091] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.617124] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.617182] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.617238] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.617271] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.617346] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.617379] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.617412] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.618338] vdd-cpu: 650 <--> 1300 mV at 1000 mV 3500 mA
[ 0.619110] vdd-core: applied init 1000000uV constraint
[ 0.619711] vdd-core: 700 <--> 1350 mV at 1000 mV 3500 mA
[ 0.620917] vddio-ddr: at 1350 mV
[ 0.621241] as3722-sd3: no parameters
[ 0.621840] avdd-pll-pex: 1050 mV
[ 0.623028] vdd-1v8: at 1800 mV
[ 0.623386] vdd-gpu: applied init 1000000uV constraint
[ 0.624265] vdd-gpu: 650 <--> 1200 mV at 1000 mV 3500 mA
[ 0.624761] avdd-pll: at 1050 mV at 300 mA
[ 0.626045] vdd-cam: 1800 mV at 150 mA
[ 0.626720] avdd-dsi-csi: at 1200 mV at 150 mA
[ 0.627939] vdd-rtc: 800 mV at 150 mA
[ 0.628420] avdd-cam: 2800 mV at 150 mA
[ 0.628929] vdd-1v2-cam: 1175 mV at 150 mA
[ 0.629300] vddio-sdmmc-2: 1800 <--> 3300 mV at 150 mA
[ 0.629800] vdd-1v1-cam: 1275 mV at 150 mA
[ 0.630771] avdd-spi: 3300 mV at 150 mA
[ 0.631300] vdd-2v7-cam: 2800 mV at 150 mA
[ 0.631819] vpp-fuse: 1800 mV at 150 mA
[ 0.632406] of_get_named_gpio_flags: can't parse gpios property
[ 0.632417] of_get_named_gpio_flags: can't parse gpios property
[ 0.632875] Linux video capture interface: v2.00
[ 0.634002] Advanced Linux Sound Architecture Driver Initialized.
[ 0.634454] ardbeg_wifi_power: 1
[ 0.734862] of_get_named_gpio_flags exited with status 108
[ 0.734992] usb0-vbus: 5000 mV
[ 0.735179] of_get_named_gpio_flags exited with status 109
[ 0.735302] usb1-usb2-vbus: 5000 mV
[ 0.735475] of_get_named_gpio_flags exited with status 86
[ 0.735584] vdd-hdmi: 5000 mV
[ 0.735784] of_get_named_gpio_flags exited with status 63
[ 0.735890] avdd-hdmi-pll: 3300 mV
[ 0.735940] avdd-hdmi-pll: supplied by avdd-pll-pex
[ 0.736130] reg-fixed-sync-voltage 9.regulator: Consumer c3 does not have device name
[ 0.736164] of_get_named_gpio_flags: can't parse gpios property
[ 0.736253] reg-5v0-supply: 5000 mV
[ 0.736426] reg-fixed-sync-voltage a.regulator: Consumer c1 does not have device name
[ 0.736461] reg-fixed-sync-voltage a.regulator: Consumer c2 does not have device name
[ 0.736495] reg-fixed-sync-voltage a.regulator: Consumer c3 does not have device name
[ 0.736546] reg-fixed-sync-voltage a.regulator: Consumer c10 does not have device name
[ 0.736580] reg-fixed-sync-voltage a.regulator: Consumer c11 does not have device name
[ 0.736613] reg-fixed-sync-voltage a.regulator: Consumer c12 does not have device name
[ 0.736647] reg-fixed-sync-voltage a.regulator: Consumer c13 does not have device name
[ 0.736680] reg-fixed-sync-voltage a.regulator: Consumer c14 does not have device name
[ 0.736731] reg-fixed-sync-voltage a.regulator: Consumer c15 does not have device name
[ 0.736790] of_get_named_gpio_flags: can't parse gpios property
[ 0.736890] reg-1v8-supply: 1800 mV
[ 0.737184] reg-fixed-sync-voltage b.regulator: Consumer c1 does not have device name
[ 0.737230] of_get_named_gpio_flags exited with status 138
[ 0.737339] reg-dcdc-1v2: 1200 mV
[ 0.737509] reg-fixed-sync-voltage c.regulator: Consumer c7 does not have device name
[ 0.737545] reg-fixed-sync-voltage c.regulator: Consumer c8 does not have device name
[ 0.737590] of_get_named_gpio_flags exited with status 1018
[ 0.738102] as3722-gpio2-supply: 3300 mV
[ 0.738317] reg-fixed-sync-voltage d.regulator: Consumer c1 does not have device name
[ 0.738365] of_get_named_gpio_flags exited with status 1020
[ 0.738839] as3722-gpio4-supply: 3300 mV
[ 0.739012] of_get_named_gpio_flags exited with status 136
[ 0.739127] sdmmc-en-supply: 3300 mV
[ 0.739291] of_get_named_gpio_flags exited with status 138
[ 0.739382] vdd-cdc-1v2-aud: 1200 mV
[ 0.739545] reg-fixed-sync-voltage 10.regulator: Consumer c1 does not have device name
[ 0.739581] reg-fixed-sync-voltage 10.regulator: Consumer c2 does not have device name
[ 0.739615] reg-fixed-sync-voltage 10.regulator: Consumer c3 does not have device name
[ 0.739646] of_get_named_gpio_flags: can't parse gpios property
[ 0.739746] reg-aon-1v8: 1800 mV
[ 0.739925] reg-fixed-sync-voltage 11.regulator: Consumer c1 does not have device name
[ 0.739958] of_get_named_gpio_flags: can't parse gpios property
[ 0.740047] reg-aon-1v2: 1200 mV
[ 0.743045] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is disconnected
[ 0.746395] tegra: started io power detection dynamic control
[ 0.746422] tegra: NO_IO_POWER setting 0x0
[ 0.746449] Switching to clocksource arch_sys_counter
[ 0.768905] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.769097] nvmap_page_pool_init: Total MB RAM: 1892
[ 0.769123] nvmap_page_pool_init: nvmap page pool size: 60555 pages (236 MB)
[ 0.769291] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.769457] iram: dma coherent mem declare 0x40001000,258048
[ 0.770297] misc nvmap: created heap iram base 0x40001000 size (252KiB)
[ 0.770462] nvmap:inner cache maint threshold=2097152
[ 0.780177] Wake39 for irq=52
[ 0.780274] tegra-otg tegra-otg: otg transceiver registered
[ 0.780649] NET: Registered protocol family 2
[ 0.781347] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.781468] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.781601] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.781664] TCP: reno registered
[ 0.781689] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.781732] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.782032] NET: Registered protocol family 1
[ 0.782426] RPC: Registered named UNIX socket transport module.
[ 0.782451] RPC: Registered udp transport module.
[ 0.782472] RPC: Registered tcp transport module.
[ 0.782493] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.782539] PCI: CLS 0 bytes, default 64
[ 0.782794] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 0.788280] host1x host1x: initialized
[ 0.789530] CPU PMU: probing PMU on CPU 0
[ 0.789566] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.790195] tegra_throttle : init passed
[ 0.790309] Tegra cpuquiet initialized: disabled
[ 0.790450] cpu-tegra: init EDP limit: 2320 MHz
[ 0.791446] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.791855] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.792086] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
[ 0.792328] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.793854] bounce pool size: 64 pages
[ 0.795296] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.795597] NTFS driver 2.1.30 [Flags: R/O].
[ 0.795742] fuse init (API version 7.22)
[ 0.795983] msgmni has been set to 930
[ 0.797378] io scheduler noop registered (default)
[ 0.797711] of_get_named_gpio_flags: can't parse gpios property
[ 0.797721] of_get_named_gpio_flags: can't parse gpios property
[ 0.797730] of_get_named_gpio_flags: can't parse gpios property
[ 0.998668] PCIE: port 0: link down, retrying
[ 1.198713] PCIE: port 0: link down, retrying
[ 1.398755] PCIE: port 0: link down, retrying
[ 1.398777] PCIE: port 0: link down, ignoring
[ 1.403932] PCI host bridge to bus 0000:00
[ 1.403961] pci_bus 0000:00: root bus resource [mem 0x32100000-0x3fffffff]
[ 1.403992] pci_bus 0000:00: root bus resource [mem 0x12100000-0x320fffff pref]
[ 1.404025] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 1.404052] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 1.404118] pci 0000:00:00.0: [10de:0e13] type 01 class 0x060400
[ 1.404214] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.404440] PCI: bus0: Fast back to back transfers disabled
[ 1.404470] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.404699] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 1.404734] pci 0000:01:00.0: reg 10: [io 0x0000-0x00ff]
[ 1.404781] pci 0000:01:00.0: reg 18: [mem 0x00000000-0x00000fff 64bit]
[ 1.404814] pci 0000:01:00.0: reg 20: [mem 0x00000000-0x00003fff 64bit pref]
[ 1.404918] pci 0000:01:00.0: supports D1 D2
[ 1.404930] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.406565] PCI: bus1: Fast back to back transfers disabled
[ 1.406598] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.406616] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 01
[ 1.406908] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 1.406938] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.406969] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
[ 1.407087] aer 0000:00:00.0:pcie02: service driver aer loaded
[ 1.407182] pcieport 0000:00:00.0: BAR 8: assigned [mem 0x32100000-0x321fffff]
[ 1.407218] pcieport 0000:00:00.0: BAR 9: assigned [mem 0x12100000-0x121fffff 64bit pref]
[ 1.407254] pcieport 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 1.407288] pci 0000:01:00.0: BAR 4: assigned [mem 0x12100000-0x12103fff 64bit pref]
[ 1.407337] pci 0000:01:00.0: BAR 2: assigned [mem 0x32100000-0x32100fff 64bit]
[ 1.407384] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.407417] pcieport 0000:00:00.0: PCI bridge to [bus 01]
[ 1.407445] pcieport 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 1.407475] pcieport 0000:00:00.0: bridge window [mem 0x32100000-0x321fffff]
[ 1.407530] pcieport 0000:00:00.0: bridge window [mem 0x12100000-0x121fffff 64bit pref]
[ 1.407574] PCIE: No Link speed change happened
[ 1.408125] pwm-backlight pwm-backlight: unable to request PWM, trying legacy API
[ 1.408233] sysedp_create_consumer: unable to create pwm-backlight, no consumer_data for pwm-backlight found
[ 1.409126] tsec tsec: initialized
[ 1.410633] isp isp.0: initialized
[ 1.411612] isp isp.1: initialized
[ 1.413156] falcon vic03.0: initialized
[ 1.414340] falcon msenc: initialized
[ 1.415161] tegradc tegradc.0: DSI: HS clock rate is 464500
[ 1.416325] vdd_lcd_bl regulator get failed
[ 1.416349] dsi regulator get failed
[ 1.418263] tegradc tegradc.0: nominal-pclk:154700000 parent:154500000 div:1.0 pclk:154500000 153153000~168623000
[ 1.507696] tegradc tegradc.0: DSI pad calibration done
[ 1.514847] tegradc tegradc.0: probed
[ 1.515322] tegradc tegradc.0: fb registered
[ 1.515346] tegradc tegradc.0: nominal-pclk:154679000 parent:463500000 div:3.0 pclk:154500000 153132210~168600110
[ 1.521190] gpio wake4 for gpio=111
[ 1.521470] tegra-i2c tegra12-i2c.3: no acknowledge from address 0x50
[ 1.522447] tegradc tegradc.1: probed
[ 1.526312] Console: switching to colour frame buffer device 80x30
[ 1.530805] tegradc tegradc.1: fb registered
[ 1.532472] hdmi_state_machine_worker (tid dd30d580): state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.535739] hdmi_state_machine_set_state_l: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.539234] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[ 1.543280] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.546389] serial8250.0: ttyS0 at MMIO 0x70006300 (irq = 122) is a Tegra
[ 1.578547] hdmi_state_machine_worker (tid dd30d580): state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.578551] hdmi_disable_l: audio_switch 0
[ 1.578554] hdmi_disable_l: hpd_switch 0
[ 1.578560] hdmi_state_machine_set_state_l: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.588544] hdmi_state_machine_worker (tid dd30d580): state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.588547] hdmi_disable_l: audio_switch 0
[ 1.588550] hdmi_disable_l: hpd_switch 0
[ 1.588555] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 3.966046] console [ttyS0] enabled
[ 3.971886] serial-tegra.0: ttyTHS0 at MMIO 0x70006000 (irq = 68) is a SERIAL_TEGRA
[ 3.983668] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 3.995574] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 4.012424] loop: module loaded
[ 4.017861] nct1008_nct72 0-004c: success in enabling rail vdd_nct72
[ 4.029444] gpio wake35 for gpio=70
[ 4.035132] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 4.043469] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 4.057418] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 4.072191] tegra_profiler: Branch: Dev
[ 4.078226] tegra_profiler: Version: 1.103
[ 4.084433] tegra_profiler: Samples version: 34
[ 4.091045] tegra_profiler: IO version: 18
[ 4.097127] armv7_pmu: arch: Cortex A15, type: 4, ver: 0
[ 4.104600] tegra_profiler: auth: init
[ 4.110596] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[ 4.119702] tegra-sata tegra-sata.0: version 1.0
[ 4.119717] of_get_named_gpio_flags: can't parse gpios property
[ 4.120352] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 4.133330] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[ 4.146835] scsi0 : tegra-sata
[ 4.152105] scsi1 : tegra-sata
[ 4.157168] ata1: SATA max UDMA/133 irq 55
[ 4.163010] ata2: DUMMY
[ 4.168294] tegra_spi_setup : speed=1000000
[ 4.174438] tegra_spi_probe : spi-max-frequency 1000000
[ 4.181803] tegra_spi_probe : spi-max-frequency 25000000
[ 4.189267] tun: Universal TUN/TAP device driver, 1.6
[ 4.195900] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.203914] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 4.213304] r8169 0000:01:00.0 eth0: RTL8168g/8111g at 0xdf83e000, 00:04:4b:70:8f:cc, XID 0c000800 IRQ 641
[ 4.226082] r8169 0000:01:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 4.237851] usbcore: registered new interface driver asix
[ 4.244939] usbcore: registered new interface driver ax88179_178a
[ 4.252754] usbcore: registered new interface driver cdc_ether
[ 4.260268] usbcore: registered new interface driver smsc95xx
[ 4.267643] usbcore: registered new interface driver cdc_subset
[ 4.275218] usbcore: registered new interface driver cdc_ncm
[ 4.282388] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.290624] tegra USB phy - inst[1] platform info:
[ 4.296896] port_otg: no
[ 4.300807] has_hostpc: yes
[ 4.304922] phy_interface: USB_PHY_INTF_UTMI
[ 4.310531] op_mode: TEGRA_USB_OPMODE_HOST
[ 4.315996] qc2_voltage: 0
[ 4.320087] vbus_gpio: -1
[ 4.324047] hot_plug: disabled
[ 4.328427] remote_wakeup: enabled
[ 4.334659] tegra-ehci tegra-ehci.1: Tegra EHCI Host Controller
[ 4.342063] tegra-ehci tegra-ehci.1: new USB bus registered, assigned bus number 1
[ 4.352521] Wake40 for irq=53
[ 4.356835] Wake42 for irq=53
[ 4.361110] tegra-ehci tegra-ehci.1: irq 53, io mem 0x7d004000
[ 4.373547] tegra-ehci tegra-ehci.1: USB 2.0 started, EHCI 1.10
[ 4.380797] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.388871] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.398520] usb usb1: Product: Tegra EHCI Host Controller
[ 4.405251] usb usb1: Manufacturer: Linux 3.10.40-gafe5771-dirty ehci_hcd
[ 4.413466] usb usb1: SerialNumber: tegra-ehci.1
[ 4.420008] hub 1-0:1.0: USB hub found
[ 4.425214] hub 1-0:1.0: 1 port detected
[ 4.430850] tegra USB phy - inst[2] platform info:
[ 4.437058] port_otg: no
[ 4.440934] has_hostpc: yes
[ 4.445071] phy_interface: USB_PHY_INTF_UTMI
[ 4.450702] op_mode: TEGRA_USB_OPMODE_HOST
[ 4.456164] qc2_voltage: 0
[ 4.460238] vbus_gpio: -1
[ 4.464199] hot_plug: disabled
[ 4.468600] remote_wakeup: enabled
[ 4.472560] ata1: SATA link down (SStatus 0 SControl 300)
[ 4.481585] tegra-ehci tegra-ehci.2: Tegra EHCI Host Controller
[ 4.488933] tegra-ehci tegra-ehci.2: new USB bus registered, assigned bus number 2
[ 4.499283] Wake41 for irq=129
[ 4.503723] Wake43 for irq=129
[ 4.508177] tegra-ehci tegra-ehci.2: irq 129, io mem 0x7d008000
[ 4.521545] tegra-ehci tegra-ehci.2: USB 2.0 started, EHCI 1.10
[ 4.528933] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.537194] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.547073] usb usb2: Product: Tegra EHCI Host Controller
[ 4.553881] usb usb2: Manufacturer: Linux 3.10.40-gafe5771-dirty ehci_hcd
[ 4.562066] usb usb2: SerialNumber: tegra-ehci.2
[ 4.568536] hub 2-0:1.0: USB hub found
[ 4.573738] hub 2-0:1.0: 1 port detected
[ 4.579373] ehci-pci: EHCI PCI platform driver
[ 4.585440] tegra_xusb_read_usb_calib: usb_calib0 = 0x0285038b
[ 4.592936] usbcore: registered new interface driver usb-storage
[ 4.600549] usbcore: registered new interface driver usbserial
[ 4.607863] usbcore: registered new interface driver option
[ 4.614875] usbserial: USB Serial support registered for GSM modem (1-port)
[ 4.623447] usbcore: registered new interface driver pl2303
[ 4.630554] usbserial: USB Serial support registered for pl2303
[ 4.638030] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[ 4.648584] tegra USB phy - inst[0] platform info:
[ 4.654968] port_otg: yes
[ 4.659098] has_hostpc: yes
[ 4.663386] phy_interface: USB_PHY_INTF_UTMI
[ 4.669243] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 4.675041] qc2_voltage: 0
[ 4.679301] vbus_pmu_irq: 0
[ 4.683557] vbus_gpio: -1
[ 4.687603] charging: enabled
[ 4.691959] remote_wakeup: disabled
[ 4.699501] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 4.714751] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
[ 4.722942] as3722-rtc as3722-rtc.1: RTC interrupt 449
[ 4.732241] i2c /dev entries driver
[ 4.738358] virtual_init
[ 4.744063] nvavp nvavp: allocated IOVA at 8ff00000 for AVP os
[ 4.752034] tegra_dtv_probe: probing dtv.
[ 4.757607] setup_stream: bufsize = 4096, bufnum = 4
[ 4.762765] ar0832_init: ++
[ 4.768949] i2c-core: driver [max77387] using legacy suspend method
[ 4.776769] i2c-core: driver [max77387] using legacy resume method
[ 4.784468] i2c-core: driver [as364x] using legacy suspend method
[ 4.792004] i2c-core: driver [as364x] using legacy resume method
[ 4.799549] [IMX135] sensor driver loading
[ 4.805045] [IMX179] sensor driver loading
[ 4.810495] [IMX185] sensor driver loading
[ 4.815966] [imx132] sensor driver loading
[ 4.821406] [AR0330] sensor driver loading
[ 4.826780] [ar0261] sensor driver loading
[ 4.832119] [AR1335] sensor driver loading
[ 4.837463] [ov4689] sensor driver loading
[ 4.843553] usbcore: registered new interface driver uvcvideo
[ 4.850556] USB Video Class driver (1.1.1)
[ 4.856764] zram: Created 1 device(s) ...
[ 4.862547] otg state changed: SUSPEND --> PERIPHERAL
[ 4.869370] tegra_wdt tegra_wdt.0: last reset is due to power on reset
[ 4.877329] tegra_wdt_probe done
[ 4.882021] sdhci: Secure Digital Host Controller Interface driver
[ 4.889498] sdhci: Copyright(c) Pierre Ossman
[ 4.895083] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.902312] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[ 4.915791] sdhci-tegra sdhci-tegra.3: Speedo value 2287
[ 4.922492] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 4.934745] mmc0: no vqmmc regulator found
[ 4.940204] mmc0: no vmmc regulator found
[ 4.945559] mmc0: Invalid maximum block size, assuming 512 bytes
[ 4.952946] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
[ 4.987555] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 5.000275] sdhci-tegra sdhci-tegra.2: Speedo value 2287
[ 5.007400] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 5.022670] mmc1: no vqmmc regulator found
[ 5.028612] mmc1: no vmmc regulator found
[ 5.034398] mmc1: Invalid maximum block size, assuming 512 bytes
[ 5.064776] mmc0: BKOPS_EN bit is not set
[ 5.075940] sdhci-tegra sdhci-tegra.3: Found T2T coeffs data
[ 5.042329] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found
[ 5.077552] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[ 5.094620] gpio wake56 for gpio=170
[ 5.094627] sdhci-tegra sdhci-tegra.3: 200MHz tap hole coeffs found
[ 5.113433] tegra-se tegra12-se: tegra_se_probe: complete
[ 5.122976] usbcore: registered new interface driver usbhid
[ 5.130394] usbhid: USB HID core driver
[ 5.136410] tegra-hier-ictlr tegra-hier-ictlr: probed
[ 5.222164] usbcore: registered new interface driver snd-usb-audio
[ 5.230743] MAX98090 driver built on Sep 20 2016 at 10:39:12
[ 5.238973] tegra_offload_platform probe successfull.
[ 5.246868] succefully registered offload opstegra30_avp_audio_platform_probe successful.
[ 5.521145] rt5639 0-001c: read 0xfd=0x6
[ 5.542319] rt5639 0-001c: ASoC: mux INR Mux has no paths
[ 5.549498] rt5639 0-001c: ASoC: mux INL Mux has no paths
[ 5.557298] gpio wake49 for gpio=143
[ 5.638085] **********Auto tuning windows*************
[ 5.644901] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 5.652097] win[0]: 0(0) - 62(1)
[ 5.657001] win[1]: 67(0) - 131(1)
[ 5.662022] win[2]: 136(0) - 199(1)
[ 5.667063] win[3]: 204(0) - 255(1)
[ 5.672030] ***************************************
[ 5.678381] ********tuning windows after inserting holes*****
[ 5.685570] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 5.692561] win[0]:-1(0) - 30(2)
[ 5.697280] win[1]:32(2) - 62(1)
[ 5.701952] win[2]:67(0) - 98(2)
[ 5.706572] win[3]:100(2) - 131(1)
[ 5.711332] win[4]:136(0) - 166(2)
[ 5.716051] win[5]:168(2) - 199(1)
[ 5.720733] win[6]:204(0) - 234(2)
[ 5.725365] win[7]:236(2) - 255(1)
[ 5.729972] ***********************************************
[ 5.736807] **********Tuning values*********
[ 5.742230] **estimated values**
[ 5.746542] T2T_Vmax 56, T2T_Vmin 78, 1'st_hole_Vmax 48, UI_Vmax 89
[ 5.753950] **Calculated values**
[ 5.758398] T2T_Vmax 73, 1'st_hole_Vmax 31, UI_Vmax 68
[ 5.764741] T2T_Vmin 73, 1'st_hole_Vmin 31, UI_Vmin 68
[ 5.771041] ***********************************
[ 5.776721] ***********final tuning windows**********
[ 5.782907] win[0]: 12 - 23
[ 5.786799] win[1]: 40 - 49
[ 5.790682] win[2]: 80 - 87
[ 5.794549] win[3]: 112 - 118
[ 5.798604] win[4]: 149 - 150
[ 5.802613] win[5]: 185 - 186
[ 5.806582] win[6]: 217 - 213
[ 5.810501] win[7]: 255 - 242
[ 5.814373] ********************************
[ 5.819595] best tap win - (12-23), best tap value 18 prev_best_tap 0
[ 6.372468] **********Auto tuning windows*************
[ 6.378696] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 6.385316] win[0]: 0(0) - 61(1)
[ 6.389690] win[1]: 67(0) - 131(1)
[ 6.394244] win[2]: 136(0) - 199(1)
[ 6.398895] win[3]: 205(0) - 255(1)
[ 6.403499] ***************************************
[ 6.409536] ********tuning windows after inserting holes*****
[ 6.416455] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 6.423103] win[0]:-2(0) - 31(2)
[ 6.427452] win[1]:33(2) - 61(1)
[ 6.431761] win[2]:67(0) - 100(2)
[ 6.436162] win[3]:102(2) - 131(1)
[ 6.440624] win[4]:136(0) - 169(2)
[ 6.445067] win[5]:171(2) - 199(1)
[ 6.449470] win[6]:205(0) - 238(2)
[ 6.453879] win[7]:240(2) - 255(1)
[ 6.458292] ***********************************************
[ 6.464950] **********Tuning values*********
[ 6.470314] **estimated values**
[ 6.474652] T2T_Vmax 56, T2T_Vmin 78, 1'st_hole_Vmax 48, UI_Vmax 89
[ 6.482122] **Calculated values**
[ 6.486661] T2T_Vmax 72, 1'st_hole_Vmax 32, UI_Vmax 69
[ 6.493057] T2T_Vmin 72, 1'st_hole_Vmin 32, UI_Vmin 69
[ 6.499392] ***********************************
[ 6.505097] ***********final tuning windows**********
[ 6.511303] win[0]: 11 - 24
[ 6.515218] win[1]: 41 - 48
[ 6.519119] win[2]: 80 - 88
[ 6.523005] win[3]: 115 - 118
[ 6.527070] win[4]: 149 - 153
[ 6.531094] win[5]: 188 - 186
[ 6.535078] win[6]: 218 - 217
[ 6.539011] win[7]: 255 - 242
[ 6.542893] ********************************
[ 6.548127] best tap win - (11-24), best tap value 18 prev_best_tap 18
[ 6.555710] sdhci-tegra sdhci-tegra.3: sdhci_tegra_verify_best_tap: tuning freq 200000000hz, best tap 18
[ 6.564547] rt5639 0-001c: rt5639_headset_detect RT5639_PWR_ANLG1(0x63) = 0xa814
[ 6.564795] rt5639 0-001c: rt5639_headset_detect RT5639_IRQ_CTRL2(0xbe) = 0x0
[ 6.589449] mmc0: new HS200 MMC card at address 0001
[ 6.596735] mmcblk mmc0:0001: Card claimed for testing.
[ 6.603567] mmcblk0: mmc0:0001 SEM16G 14.6 GiB
[ 6.609720] mmcblk0rpmb: mmc0:0001 SEM16G partition 3 4.00 MiB
[ 6.621616] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 6.633630] rt5639 0-001c: rt5639_headset_detect jack_type = 2
[ 6.641250] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[ 6.652883] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> tegra30-spdif mapping ok
[ 6.664477] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> tegra30-i2s.3 mapping ok
[ 6.676369] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> dit-hifi mapping ok
[ 6.688329] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> dit-hifi mapping ok
[ 6.700292] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[ 6.711989] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[ 6.723703] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai <-> tegra-offload-pcm mapping ok
[ 6.737534] compress asoc: snd-soc-dummy-dai <-> tegra-offload-compr mapping ok
[ 6.749781] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[ 6.761621] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[ 6.773553] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai <-> tegra-offload-pcm mapping ok
[ 6.787637] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[ 6.803684] input: tegra-rt5639 Headphone Jack as /devices/platform/tegra-snd-rt5639.0/sound/card1/input0
[ 6.818787] sysedp_create_consumer: unable to create speaker, no consumer_data for speaker found
[ 6.830640] oprofile: using timer interrupt.
[ 6.839876] GACT probability NOT on
[ 6.845666] Mirror/redirect action on
[ 6.851594] u32 classifier
[ 6.856475] Actions configured
[ 6.861994] Netfilter messages via NETLINK v0.30.
[ 6.868856] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 6.877478] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 6.886536] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 6.894723] xt_time: kernel timezone is -0000
[ 6.901238] ipip: IPv4 over IPv4 tunneling driver
[ 6.908453] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.915860] arp_tables: (C) 2002 David S. Miller
[ 6.922459] TCP: cubic registered
[ 6.927808] NET: Registered protocol family 10
[ 6.934914] mip6: Mobile IPv6
[ 6.939714] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 6.947028] sit: IPv6 over IPv4 tunneling driver
[ 6.954292] NET: Registered protocol family 17
[ 6.960457] NET: Registered protocol family 15
[ 6.966612] NET: Registered protocol family 35
[ 6.972644] NET: Registered protocol family 37
[ 6.978500] NET: Registered protocol family 41
[ 6.985617] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 7.020556] Registering SWP/SWPB emulation handler
[ 7.026746] last reset is due to power on reset
[ 7.026746]
[ 7.035497] Disabling clocks left on by bootloader:
[ 7.041758] audio_2x
[ 7.045587] audio
[ 7.049080] audio4
[ 7.052585] audio3
[ 7.056067] audio2
[ 7.059458] audio1
[ 7.062800] audio0
[ 7.066171] hdmi_audio
[ 7.069782] entropy
[ 7.073109] dsi2-fixed
[ 7.076687] dsi1-fixed
[ 7.080215] nor
[ 7.083077] trace
[ 7.086068] sdmmc4_ddr
[ 7.089471] sdmmc3_ddr
[ 7.092901] cclk_lp
[ 7.096046] pll_x_out0
[ 7.099496] pll_m_out1
[ 7.103035] tegra_dvfs: vdd_cpu connected to regulator
[ 7.109044] tegra_dvfs: vdd_core connected to regulator
[ 7.115066] tegra_dvfs: vdd_gpu connected to regulator
[ 7.122149] cpu_cold cooling device is registered
[ 7.127744] cpu_hot cooling device is registered
[ 7.127896] Tegra CPU DFLL is initialized with use_dfll = 1
[ 7.127957] CPU rate: 696 MHz
[ 7.408357] tegra dvfs: tegra sysfs cap interface is initialized
[ 7.415293] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[ 7.423330] tegra_actmon.emc: Completed initialization (0)
[ 7.429974] tegra_actmon.avp: Completed initialization (0)
[ 7.436544] tegra_mon.cpu_emc: Completed initialization (0)
[ 7.445990] reg-aon-1v2: incomplete constraints, leaving on
[ 7.452622] reg-aon-1v8: incomplete constraints, leaving on
[ 7.459323] sdmmc-en-supply: incomplete constraints, leaving on
[ 7.466296] as3722-gpio4-supply: incomplete constraints, leaving on
[ 7.473666] reg-dcdc-1v2: incomplete constraints, leaving on
[ 7.480482] reg-5v0-supply: incomplete constraints, leaving on
[ 7.487522] avdd-hdmi-pll: incomplete constraints, leaving on
[ 7.494523] usb0-vbus: incomplete constraints, leaving on
[ 7.501212] vpp-fuse: incomplete constraints, leaving on
[ 7.507869] vdd-2v7-cam: incomplete constraints, leaving on
[ 7.514828] avdd-spi: incomplete constraints, leaving on
[ 7.521575] vdd-1v1-cam: incomplete constraints, leaving on
[ 7.528633] vddio-sdmmc-2: incomplete constraints, leaving on
[ 7.535869] vdd-1v2-cam: incomplete constraints, leaving on
[ 7.542998] avdd-cam: incomplete constraints, leaving on
[ 7.549847] vdd-cam: incomplete constraints, leaving on
[ 7.556653] as3722-sd3: incomplete constraints, leaving on
[ 7.563736] vdd-3v3-aon: incomplete constraints, leaving on
[ 7.570865] vdd-ac-bat: incomplete constraints, leaving on
[ 7.577948] regulator-dummy: incomplete constraints, leaving on
[ 7.586157] of_get_named_gpio_flags exited with status 128
[ 7.586214] gpio wake51 for gpio=128
[ 7.591641] input: gpio-keys.4 as /devices/platform/gpio-keys.4/input/input1
[ 7.601103] as3722-rtc as3722-rtc.1: setting system clock to 2017-02-14 09:17:17 UTC (1487063837)
[ 7.614002] ALSA device list:
[ 7.618499] #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 7.625523] #1: tegra-rt5639
[ 7.631286] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[ 7.643250] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[ 7.717441] EXT4-fs (mmcblk0p1): recovery complete
[ 7.724871] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.736558] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 7.747353] devtmpfs: mounted
[ 7.752471] Freeing unused kernel memory: 508K (c0b37000 - c0bb6000)
[ 8.009730] init: plymouth-upstart-bridge main process (118) terminated with status 1
[ 8.021759] init: plymouth-upstart-bridge main process ended, respawning
[ 8.068234] init: plymouth-upstart-bridge main process (128) terminated with status 1
[ 8.079917] init: plymouth-upstart-bridge main process ended, respawning
[ 8.093422] init: ureadahead main process (121) terminated with status 5
[ 8.130441] init: plymouth-upstart-bridge main process (132) terminated with status 1
[ 8.142245] init: plymouth-upstart-bridge main process ended, respawning
[ 9.210451] systemd-udevd[284]: starting version 204
[ 9.496407] ------------[ cut here ]------------
[ 9.496442] WARNING: at drivers/regulator/core.c:2018 _regulator_disable+0xd8/0x100()
[ 9.496450] unbalanced disables for as3722-gpio4-supply
[ 9.496461] Modules linked in:
[ 9.496475] CPU: 3 PID: 318 Comm: sh Tainted: G W 3.10.40-gafe5771-dirty #44
[ 9.496517] [<c0016418>] (unwind_backtrace+0x0/0x140) from [<c0012f48>] (show_stack+0x18/0x1c)
[ 9.496565] [<c0012f48>] (show_stack+0x18/0x1c) from [<c00638ec>] (warn_slowpath_common+0x54/0x70)
[ 9.496586] [<c00638ec>] (warn_slowpath_common+0x54/0x70) from [<c00639b4>] (warn_slowpath_fmt+0x38/0x48)
[ 9.496602] [<c00639b4>] (warn_slowpath_fmt+0x38/0x48) from [<c0389a5c>] (_regulator_disable+0xd8/0x100)
[ 9.496623] [<c0389a5c>] (_regulator_disable+0xd8/0x100) from [<c0389ac0>] (regulator_disable+0x3c/0x7c)
[ 9.496644] [<c0389ac0>] (regulator_disable+0x3c/0x7c) from [<c00555d4>] (dsi_p_wuxga_10_1_disable+0x50/0x8c)
[ 9.496672] [<c00555d4>] (dsi_p_wuxga_10_1_disable+0x50/0x8c) from [<c033a970>] (_tegra_dc_controller_disable+0xe8/0x2c0)
[ 9.496694] [<c033a970>] (_tegra_dc_controller_disable+0xe8/0x2c0) from [<c033ab84>] (_tegra_dc_disable+0x3c/0x98)
[ 9.496710] [<c033ab84>] (_tegra_dc_disable+0x3c/0x98) from [<c033cdb4>] (tegra_dc_disable+0x10c/0x1a0)
[ 9.496733] [<c033cdb4>] (tegra_dc_disable+0x10c/0x1a0) from [<c0372594>] (tegra_fb_blank+0x6c/0x18c)
[ 9.496760] [<c0372594>] (tegra_fb_blank+0x6c/0x18c) from [<c02f6f50>] (fb_blank+0x5c/0xa0)
[ 9.496782] [<c02f6f50>] (fb_blank+0x5c/0xa0) from [<c02fc358>] (store_blank+0x58/0x80)
[ 9.496801] [<c02fc358>] (store_blank+0x58/0x80) from [<c0403d84>] (dev_attr_store+0x20/0x2c)
[ 9.496823] [<c0403d84>] (dev_attr_store+0x20/0x2c) from [<c01a7094>] (sysfs_write_file+0x84/0xb8)
[ 9.496847] [<c01a7094>] (sysfs_write_file+0x84/0xb8) from [<c0146b24>] (vfs_write+0xc4/0x18c)
[ 9.496863] [<c0146b24>] (vfs_write+0xc4/0x18c) from [<c0147014>] (SyS_write+0x60/0x190)
[ 9.496883] [<c0147014>] (SyS_write+0x60/0x190) from [<c000ee80>] (ret_fast_syscall+0x0/0x30)
[ 9.496892] ---[ end trace 1b75b31a2719ed1e ]---
[ 9.498945] otg state changed: PERIPHERAL --> SUSPEND
[ 9.499122] tegra-udc tegra-udc.0: USB cable/charger disconnected
[ 9.499422] otg state changed: SUSPEND --> HOST
[ 9.504186] tegra USB phy - inst[0] platform info:
[ 9.504204] port_otg: yes
[ 9.504220] has_hostpc: yes
[ 9.504229] phy_interface: USB_PHY_INTF_UTMI
[ 9.504237] op_mode: TEGRA_USB_OPMODE_HOST
[ 9.504247] qc2_voltage: 0
[ 9.504264] vbus_gpio: -1
[ 9.504275] hot_plug: disabled
[ 9.504286] remote_wakeup: enabled
[ 10.052264] systemd-udevd[347]: could not open moddep file '/lib/modules/3.10.40-gafe5771-dirty/modules.dep.bin'
[ 10.093833] init: bluetooth main process (377) terminated with status 1
[ 10.094471] init: bluetooth main process ended, respawning
[ 10.455748] init: udev-fallback-graphics main process (452) terminated with status 1
[ 10.509427] tegra-ehci tegra-ehci.0: Tegra EHCI Host Controller
[ 10.509492] tegra-ehci tegra-ehci.0: new USB bus registered, assigned bus number 3
[ 10.509748] tegra-ehci tegra-ehci.0: irq 52, io mem 0x7d000000
[ 10.515574] tegra-ehci tegra-ehci.0: USB 2.0 started, EHCI 1.10
[ 10.515778] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 10.515801] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.515821] usb usb3: Product: Tegra EHCI Host Controller
[ 10.515837] usb usb3: Manufacturer: Linux 3.10.40-gafe5771-dirty ehci_hcd
[ 10.515852] usb usb3: SerialNumber: tegra-ehci.0
[ 10.517955] hub 3-0:1.0: USB hub found
[ 10.518008] hub 3-0:1.0: 1 port detected
[ 10.689243] init: bluetooth main process (461) terminated with status 1
[ 10.689273] init: bluetooth main process ended, respawning
[ 10.750682] r8169 0000:01:00.0 eth0: link down
[ 10.750727] r8169 0000:01:00.0 eth0: link down
[ 10.750810] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.842334] init: bluetooth main process (624) terminated with status 1
[ 10.842358] init: bluetooth main process ended, respawning
[ 10.947563] init: bluetooth main process (688) terminated with status 1
[ 10.947585] init: bluetooth main process ended, respawning
[ 10.995205] init: bluetooth main process (739) terminated with status 1
[ 10.995226] init: bluetooth main process ended, respawning
[ 11.046455] init: bluetooth main process (762) terminated with status 1
[ 11.046475] init: bluetooth main process ended, respawning
[ 11.225757] init: bluetooth main process (820) terminated with status 1
[ 11.225786] init: bluetooth main process ended, respawning
[ 11.361574] init: bluetooth main process (868) terminated with status 1
[ 11.361599] init: bluetooth main process ended, respawning
[ 11.389300] init: Failed to obtain startpar-bridge instance: Unknown parameter: INSTANCE
[ 11.430410] init: bluetooth main process (898) terminated with status 1
[ 11.430430] init: bluetooth main process ended, respawning
[ 11.469177] init: bluetooth main process (924) terminated with status 1
[ 11.469207] init: bluetooth main process ended, respawning
[ 11.505611] init: bluetooth main process (948) terminated with status 1
[ 11.505634] init: bluetooth respawning too fast, stopped
[ 13.718744] r8169 0000:01:00.0 eth0: link up
[ 13.718756] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 15.119395] r8169 0000:01:00.0 eth0: link down
[ 18.925483] r8169 0000:01:00.0 eth0: link up
[ 21.500256] init: failsafe main process (845) killed by TERM signal
[ 22.012428] init: plymouth-upstart-bridge main process ended, respawning
[ 51.466264] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
[ 66.933711] EBBChar: Initializing the EBBChar LKM
[ 66.933731] EBBChar: registered correctly with major number 241
[ 66.935135] EBBChar: device class registered correctly
[ 66.935996] EBBChar: device class created correctly
[ 66.950873] vi vi.0: initialized
[ 66.951270] platform vi.1: Driver vi requests probe deferral
[ 66.951318] soc-camera-pdrv soc-camera-pdrv.4: Probing soc-camera-pdrv.4
[ 66.956458] tc358743_probe : CHIPID=0x00 REVISIONID=0x00
[ 68.570891] Write EDID: 256 (1)
[ 68.688270] Activate EDID Mode DDC2B 1 0
[ 68.689669] tc358743_enable_interrupts: cable connected = 1
[ 69.311319] tc358743_probe : force initial interrupt mask: 0x043f : Reset Needed ?
[ 69.318997] tc358743_init_interrupts : Done
[ 69.319585] tc358743_probe : IRQ 403 5V Present
[ 69.319762] tc358743_probe : devm_request_threaded_irq succeed
[ 69.320457] tc358743_enable_interrupts: cable connected = 1
[ 69.325623] tc358743_g_edid : Dump EDID lenRead=256 Mode=2
[ 69.326498] 00 ff ff ff ff ff ff 00 46 65 00 50 01 00 00 00 01
[ 69.341268] 1a 01 03 a2 00 00 00 02 ee 95 a3 54 4c 99 26 0f
[ 69.355163] 50 54 04 43 00 01 01 01 01 01 01 01 01 01 01 01
[ 69.369069] 01 01 01 01 01 02 3a 80 18 71 38 2d 40 58 2c 45
[ 69.382959] 00 c4 8e 21 00 00 1e 00 00 00 fc 00 51 53 20 45
[ 69.396857] 4e 47 49 4e 45 20 48 49 44 00 00 00 fd 00 18 4b
[ 69.410879] 0f 51 09 00 0a 20 20 20 20 20 20 00 00 00 fe 00
[ 69.424897] 48 49 44 56 32 30 31 36 51 31 20 20 20 01 a1 02
[ 69.438915] 03 16 f0 41 90 23 09 07 07 83 01 00 00 67 03 0c
[ 69.452932] 00 00 00 b8 21 02 3a 80 18 71 38 2d 40 58 58 45
[ 69.466980] 00 80 38 74 00 00 18 00 00 00 00 00 00 00 00 00
[ 69.480996] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 69.495012] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 69.509028] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 69.523047] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 69.537073] 00 00 00 00 00 00 00 00 00 00 00 00 00 70 84
[ 69.553413] Link status : Signal OK Sync OK HDMI PHY with DE PLL lock 5V Yes<5>[ 69.553536] vi vi.0: Supporting mbus format code 0x2006 using YUV422 (UYVY) packed
[ 69.553548] vi vi.0: Supporting mbus format code 0x2006 using YUV422 (VYUY) packed
[ 69.553560] vi vi.0: Supporting mbus format code 0x2006 using YUV422 (YUYV) packed
[ 69.553576] vi vi.0: Supporting mbus format code 0x2006 using YUV422 (YVYU) packed
[ 69.553588] vi vi.0: Supporting mbus format code 0x2006 using YUV420 (YU12) planar
[ 69.553601] vi vi.0: Supporting mbus format code 0x2006 using YVU420 (YV12) planar
[ 69.555122] vi vi.0: Tegra camera driver loaded.
[ 69.558948] vi vi.1: initialized
[ 69.558969] soc-camera-pdrv soc-camera-pdrv.1: Probing soc-camera-pdrv.1
[ 69.564297] vi vi.1: Tegra camera driver loaded.
[ 69.565183] otg state changed: HOST --> SUSPEND
[ 69.566356] tc358743_s_power : state = 1
[ 69.572993] Image is 1920x1080@60, ~1991 Gbps bandwidth (~996MHz/lane) [Wrong width]
[ 69.573000] Wrong width (1920 vs 640)
[ 69.574074] tegra-ehci tegra-ehci.0: remove, state 4
[ 69.574087] usb usb3: USB disconnect, device number 1
[ 69.574805] tegra-ehci tegra-ehci.0: USB bus 3 deregistered
[ 69.575446] otg state changed: SUSPEND --> PERIPHERAL
[ 69.576802] Setting pll to frequency 1075 (1075) MHz
[ 69.588040] tc358743_enable_interrupts: cable connected = 1
[ 69.590924] Starting CSI 2 LANS
[ 69.602518] tc358743_s_power : state = 0
[ 69.979909] g_hid_mk gadget: QSE_HID_MK
[ 69.979924] g_hid_mk gadget: g_hid_mk ready
[ 69.979939] tegra-udc: bind to driver g_hid_mk
[ 69.980686] tegra-udc: bind to driver g_hid_mk
[ 70.452053] g_hid_mk gadget: high-speed config #1: Hid MK
[ 70.452120] tegra-udc tegra-udc.0: connected to SDP
[ 113.333838] tc358743_s_power : state = 1
<b>[ 113.339668] Image is 1920x1080@60, ~1991 Gbps bandwidth (~996MHz/lane) [Wrong width]</b>
[ 113.339672] Wrong width (1920 vs 640)
[ 113.343491] Setting pll to frequency 1075 (1075) MHz
[ 113.353922] tc358743_enable_interrupts: cable connected = 1
[ 113.356890] Starting CSI 2 LANS
[ 113.374182] Image is 1920x1080@60, ~1991 Gbps bandwidth (~996MHz/lane)
[ 113.374186] Setting pll to frequency 1075 (1075) MHz
[ 113.384613] tc358743_enable_interrupts: cable connected = 1
[ 113.387496] Starting CSI 2 LANS
[ 113.552554] enable_stream: enable
[ 113.553804] tc358743_s_stream:Enable
These 2 lines indicates that the CSI synchronisation succeeded.
