Solved: Tesla T4 GPUs Tensorflow 2.1 RuntimeError uknown device on Cisco UCS c240 M5 system
What could be causing the Tesla T4 GPUs to not be listed as device_type=‘GPU’ in the output of:
tf.config.list_physical_devices()?
This results in “uknown device” when Tensorflow tries to access the GPUs:
with tf.device('/gpu:3'): a = tf.constant(3.0)
# Output
RuntimeError: /job:localhost/replica:0/task:0/device:GPU:3 unknown device.
What more can I do to troubleshoot this further?
Environment containing this issue:
  • Cisco UCS c240 M5 system has:
    ** 72x CPUs and
    ** 5x Tesla T4 GPUs
  • Ubuntu 18.04 LTS
  • NVIDIA-SMI 418.126.02 Driver Version: 418.126.02 CUDA Version: 10.1
    ** All 5 T4 are recognized by nvidia-smi
  • Tensorflow 2.1.0
  • libcudnn7_7.6.5.32-1+cuda10.1_amd64
    import tensorflow as tf
# Output
    [PhysicalDevice(name='/physical_device:CPU:0', device_type='CPU'),
    PhysicalDevice(name='/physical_device:XLA_CPU:0', device_type='XLA_CPU'),
    PhysicalDevice(name='/physical_device:XLA_GPU:0', device_type='XLA_GPU'),
    PhysicalDevice(name='/physical_device:XLA_GPU:1', device_type='XLA_GPU'),
    PhysicalDevice(name='/physical_device:XLA_GPU:2', device_type='XLA_GPU'),
    PhysicalDevice(name='/physical_device:XLA_GPU:3', device_type='XLA_GPU'),
    PhysicalDevice(name='/physical_device:XLA_GPU:4', device_type='XLA_GPU')]
    tf.config.list_physical_devices('GPU')
# Output
    from tensorflow.python.client import device_lib
    print(device_lib.list_local_devices())
# Output
    [name: "/device:CPU:0"
    device_type: "CPU"
    memory_limit: 268435456
    locality {
    incarnation: 13771363116588327167
    , name: "/device:XLA_CPU:0"
    device_type: "XLA_CPU"
    memory_limit: 17179869184
    locality {
    incarnation: 17218183889029182531
    physical_device_desc: "device: XLA_CPU device"
    , name: "/device:XLA_GPU:0"
    device_type: "XLA_GPU"
    locality {
    incarnation: 9157258922701839704
    physical_device_desc: "device: XLA_GPU device"
    , name: "/device:XLA_GPU:1"
    locality {
    incarnation: 4158970543181084654
    , name: "/device:XLA_GPU:2"
    locality {
    incarnation: 15403740508526850072
    , name: "/device:XLA_GPU:3"
    locality {
    incarnation: 9287480476894551351
    , name: "/device:XLA_GPU:4"
    locality {
    incarnation: 15439875423529567742
This issue was caused by missing cuda library files.
Solution was:
sudo apt remove --autoremove nvidia-cuda-toolkit
sudo apt update
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-key adv --fetch-keys  http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/7fa2af80.pub
sudo bash -c 'echo "deb http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64 /" > /etc/apt/sources.list.d/cuda.list'
sudo bash -c 'echo "deb http://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64 /" > /etc/apt/sources.list.d/cuda_learn.list'
Install CUDA 10.1 packages
sudo apt update
sudo apt install cuda-10-1
sudo apt install libcudnn7
Reboot the system.
Tesla t4 GPUs are now showing up as device_type=‘GPU’ !
# Output
 PhysicalDevice(name='/physical_device:XLA_GPU:4', device_type='XLA_GPU'),
 PhysicalDevice(name='/physical_device:GPU:0', device_type='GPU'),
 PhysicalDevice(name='/physical_device:GPU:1', device_type='GPU'),
 PhysicalDevice(name='/physical_device:GPU:2', device_type='GPU'),
 PhysicalDevice(name='/physical_device:GPU:3', device_type='GPU'),
 PhysicalDevice(name='/physical_device:GPU:4', device_type='GPU')]
Tensors can now be placed on the T4 GPUs.
with tf.device('/device:GPU:3'):
  a = tf.constant([[1.0, 2.0, 3.0], [4.0, 5.0, 6.0]])
  b = tf.constant([[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]])
c = tf.matmul(a, b)
print(c)
# Output
tf.Tensor(
[[22. 28.]
 [49. 64.]], shape=(2, 2), dtype=float32)
Hope this helps someone else.
Dave
