i want to test multicast.
server:
ib_send_bw -d mlx5_1 -F -x 3 -c UD --run_infinitely --report_gbits -M 225.1.1.20
client:
ib_send_bw -d mlx5_1 -F -x 3 -c UD --run_infinitely --report_gbits -g -M 225.1.1.20
and in this way, i failed.
i don’t know correct parameters to test multicast. can anyone help me?
Hi ,
Please try to run the below commands
ib_send_bw 2 -g -x 0
ib_send_bw 2 -g -x 0 225.1.1.20
The -g, --mcg Send messages to multicast group with 1 QP attached to it.
In your case you only need to add -g in the server side
server:
ib_send_bw -d mlx5_1 -F -g -x 3 -c UD --run_infinitely --report_gbits -M 225.1.1.20
client:
Samer
sorry to bother you again. there is also some question.
when i set your commands, both output is as below:
- Waiting for client to connect… *
how can i set receiver at the cilent?
i want to test one sender, two receiver. can i achieve it with perftest?
Yes
On Server 1 run the ib_send_bw command
On server 2 run ib_send_bw and IP address of the Server 1
example:
Server1# ib_send_bw
Server2# ib_send_bw <IP address of the Server 1>
