Hi Experts,
I am working on Nvidia Jetson Orin NX platform, I combine the Jetson Orin NX platform with below board
Module: Jetson Orin NX 16GB-DRAM (P3767-0000)
Carrier Board: Jetson Orin Nano reference carrier board (P3768-0000)
Because it is not the standard development kit of Nvidia. So I have below questions
- What command line I should use to burn the Jetson Orin NX 16GB-DRAM (P3767-0000) module
- how can I update the firmware of Jetson Orin NX 16GB-DRAM (P3767-0000) module? In link JetPack SDK | NVIDIA Developer and 🚀 Initial Setup Guide - Jetson Orin Nano - NVIDIA Jetson AI Lab, I think may I need to upgrade firmware to use the JetPack 6.x. But in Link 🚀 Initial Setup Guide - Jetson Orin Nano - NVIDIA Jetson AI Lab, this only a microSD-only method to update the firmware.
- Is there any cuda and video analysis demos, and how can I run thems?
thanks,
Limeng
Our official bsp not support the custom carrier board.
Please reach out the vendor you bought to get the customized bsp.
Maybe you misunderstand what I mean.
I Bought all the boards from NVIDIA.
I Bought Jetson Orin Nano development kit, and Jetson Orin NX module from Nvidia.
Our product wants to use the Jetson Orin NX modul, and I found out that Jetson Orin Nano reference carrier board (P3768-0000) and Jetson Orin NX 16GB-DRAM (P3767-0000) can work together from this link Quick Start — NVIDIA Jetson Linux Developer Guide.
But because there is no sd slot on Jetson Orin NX 16GB-DRAM (P3767-0000), so I ask how to upgrade firmware for Jetson Orin NX 16GB-DRAM (P3767-0000)? Because I only found out the microSD-only method to update the firmware, I don’t find out doc to tell me how to upgrade Jetson Orin NX 16GB-DRAM (P3767-0000) without sd slot
thanks,
LImeng
As nagesh_accord suggest, you could download Driver Package (BSP) and Sample Root Filesystem from Jetson Linux | NVIDIA Developer . (Take JP6.2 for example)
And follow the Quick Start — NVIDIA Jetson Linux Developer Guide to flash your device.
