If I use a lot of GPUs, will it speed up the simulation? I would appreciate it if you could tell me how to increase the processing speed. I have the following settings for a 10000 second multi-robot simulation. Machine learning is not implemented yet.
sim_params.dt=1/60
max_step=600000 (defined by myself, and using at while loop)
I’m using GeForce RTX2080Ti, and it takes about 9650 seconds in real time with rendering disabled. And the GPU utilization was 14%.
