Spi@c260000 slave not working on jetson agx orin
I want to use spi1 as a slave but, it was not working.
Here is my spi@c260000 configuration and pinmux
This is “dmesg | grep spi”
lastly, The full dmesg content is as follows.
dmesg.txt (71.1 KB)
Please, tell me your solution.
Thank you :)
Hi lewis15,
For SPI slave, could you configure the pinmux as following?
spi2_sck_pcc0 {
    nvidia,pins = "spi2_sck_pcc0";
    nvidia,function = "spi2";
    nvidia,pull = <TEGRA_PIN_PULL_NONE>;
    nvidia,tristate = <TEGRA_PIN_ENABLE>;
    nvidia,enable-input = <TEGRA_PIN_ENABLE>;
    nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
    nvidia,lpdr = <TEGRA_PIN_DISABLE>;
spi2_miso_pcc1 {
    nvidia,pins = "spi2_miso_pcc1";
    nvidia,tristate = <TEGRA_PIN_DISABLE>;
    nvidia,enable-input = <TEGRA_PIN_DISABLE>;
spi2_mosi_pcc2 {
    nvidia,pins = "spi2_mosi_pcc2";
spi2_cs0_pcc3 {
    nvidia,pins = "spi2_cs0_pcc3";
May I also know how do you verify SPI slave for SPI2?
(i.e. what’s your SPI master? how do you connect them?)
Hi Kevin,
  • I’m using for custom board. also I’m using Jetpack version in 5.1.2.
  • My SPI master is MCU. They connect they connect by pass the Level Shifter.
    Pin connect is MCU SCK ↔ AP SCK, MCU MISO ↔ AP MISO, MCU MOSI ↔ AP MOSI, MCU CS0 ↔ AP CS0
  • Here is my circuit diagram
-Level Shifter
-AP
-MCU
Hi kevin,
I modified pinmux as you suggested. but, SPI isn’t working.
It seems your SPI master at MCU side using 3.3V but the default level for SPI2 is 1.8V.
Please also add a level shift for SPI2 for 3.3V SPI signal.
The level shift is two-way, so it doesn’t matter.
I will suggest you confirming you use the same level for both SPI master and slave.
Does your SPI2 still not work as slave?
