Hi, thanks for the reply.
I’ve run across this thread in previous searches, but I’ve just scoured it again thouroughly to see if I could learn anything new from it.
I’ve reverted to an unmodified spi-tegra124-slave module and added the change recommended in your post on 01/18/2017 to get rid of the following error:
[16279.770648] spi-tegra124-slave 7000d600.spi: Pin group name for clock line is not defined.
[16279.779559] spi-tegra124-slave: probe of 7000d600.spi failed with error -22
My device tree looks like this:
spi1: spi@7000d600 {
compatible = "nvidia,tegra124-spi-slave";
reg = <0x0 0x7000d600 0x0 0x200>;
interrupts = <0 82 0x04>;
nvidia,dma-request-selector = <&apbdma 16>;
iommus = <&smmu 14>;
#address-cells = <1>;
#size-cells = <0>;
dmas = <&apbdma 16>, <&apbdma 16>;
dma-names = "rx", "tx";
nvidia,clk-parents = "pll_p", "clk_m";
nvidia,rx-trigger-words = <8>;
spi-max-frequency = <45000000>;
status = "okay";
prod-settings {
#prod-cells = <3>;
prod {
prod = <0x4 0x0 0x16>;
prod_c_flash {
status = "disabled";
prod = <0x4 0xffffffc0 0x6>;
prod_c_loop {
prod = <0x4 0xfffff000 0x44b>;
spi1_0 {
compatible = "spisb";
#size-cells = <0>;
reg = <0>;
In the second post from notthetup, he describes a problem that is nearly identical to mine. The rx-dma-err occurs frequently but not on every other transfer.
[ 231.630569] spi-tegra124-slave 7000d600.spi: Rx len:2048 bpw:16 10000us 12000000Hz
[ 231.630730] spi-tegra124-slave 7000d600.spi: The def 0x13f08000 and written 0x3f0902f
[ 231.630906] spi-tegra124-slave 7000d600.spi: Starting rx dma for len:2048
[ 231.631160] spi_master spi1: Before DMA EN
[ 231.631359] spi_master spi1: CMD[03f0902f]: Sl M0 CS0 [HHHH] LSB MSb Rx Pa 16b TRANS[00ff0400]:BSY I:255 B:1024
FIFO[00400005]:RxF:0 TxE:64 Err[] RxSTA[E] TxSTA[E]DMA[00110000]: RxTr:2 TxTr:2 B:1023
[ 231.632766] spi_master spi1: @isr
[ 231.632985] spi_master spi1: CMD[03f0902f]: Sl M0 CS0 [HHHH] LSB MSb Rx Pa 16b TRANS[40ff0264]:RDY I:255 B:612
FIFO[01400004]:RxF:2 TxE:64 Err[] RxSTA[] TxSTA[E]DMA[00110000]: RxTr:2 TxTr:2 B:1023
[ 231.633313] spi_master spi1: transferred[612] != requested[1024]
[ 231.640306] spi_master spi1: CMD[03f0902f]: Sl M0 CS0 [HHHH] LSB MSb Rx Pa 16b TRANS[00ff0264]:BSY I:255 B:612
[ 231.661299] spi_master spi1: rx-dma-err [status:01400004]
[ 231.667122] spi_master spi1: CMD[03f0902f]: Sl M0 CS0 [HHHH] LSB MSb Rx Pa 16b TRANS[00ff0264]:BSY I:255 B:612
[ 231.687115] spi_master spi1: after controller reset
[ 231.687199] spi_master spi1: CMD[13f08000]: Sl M1 CS0 [HHHH] LSB MSb Un 1b TRANS[00ff0000]:BSY I:255 B:0
FIFO[00400005]:RxF:0 TxE:64 Err[] RxSTA[E] TxSTA[E]DMA[00110000]: RxTr:2 TxTr:2 B:0
[ 231.687364] spi_master spi1: failed to transfer one message from queue
If I add a few prints to the source code and enable tspi->variable_length_transfer like this:
--- a/drivers/spi/spi-tegra124-slave.c
+++ b/drivers/spi/spi-tegra124-slave.c
@@ -1209,7 +1209,7 @@ static int tegra_spi_start_transfer_one(struct spi_device *spi,
command1 |= SPI_CONTROL_MODE_3;
tegra_spi_writel(tspi, command1, SPI_COMMAND1);
- tspi->variable_length_transfer = false;
+ tspi->variable_length_transfer = true;
if (cdata && cdata->variable_length_transfer)
} else {
@@ -1393,6 +1393,7 @@ static int tegra_spi_wait_on_message_xfer(struct tegra_spi_data *tspi)
/* wait for spi isr */
ret = wait_for_completion_interruptible_timeout(
&tspi->xfer_completion, timeout);
+ dev_dbg(tspi->dev, "ret = %d after wait_for_completion_interruptible_timeout spi isr\n", ret);
if (ret <= 0) {
/* interrupted-wait/late interrupt is considered spurious */
atomic_set(&tspi->isr_expected, 0);
@@ -1556,11 +1557,13 @@ static int tegra_spi_transfer_one_message(struct spi_master *master,
is_first_msg = false;
/* wait for spi-interrupt and handle transfer error */
ret = tegra_spi_wait_on_message_xfer(tspi);
+ dev_dbg(tspi->dev, "ret = %d after tegra_spi_wait_on_message_xfer\n", ret);
if (ret)
goto exit;
tegra_clk_pin_control(false, tspi);
/* unpack and copy data to client */
ret = tegra_spi_handle_message(tspi, xfer);
+ dev_dbg(tspi->dev, "ret = %d after tegra_spi_handle_message\n", ret);
if (ret < 0)
goto exit;
@@ -1759,7 +1762,8 @@ static int tegra_spi_probe(struct platform_device *pdev)
tspi->dma_req_sel = pdata->dma_req_sel;
tspi->clock_always_on = pdata->is_clkon_always;
tspi->rx_trig_words = pdata->rx_trig_words;
- tspi->clk_pin = (char *)pdata->clk_pin;
+ tspi->clk_pin = NULL;
+ /*(char *)pdata->clk_pin;
if (tspi->clk_pin) {
tspi->clk_pin_state_enabled = true;
tspi->pctl_dev = pinctrl_get_dev_from_of_compatible
@@ -1781,6 +1785,7 @@ static int tegra_spi_probe(struct platform_device *pdev)
dev_err(&pdev->dev, "Pin group name for clock line is not defined.\n");
goto exit_free_master;
tspi->gpio_slave_ready = pdata->gpio_slave_ready;
I get this:
[ 2077.048954] spi-tegra124-slave 7000d600.spi: Rx len:2048 bpw:16 10000us 12000000Hz
[ 2077.048985] spi-tegra124-slave 7000d600.spi: The def 0x13f08000 and written 0x3f0902f
[ 2077.049014] spi-tegra124-slave 7000d600.spi: Starting rx dma for len:2048
[ 2077.049087] spi_master spi1: Before DMA EN
[ 2077.049107] spi_master spi1: CMD[03f0902f]: Sl M0 CS0 [HHHH] LSB MSb Rx Pa 16b TRANS[00ff0400]:BSY I:255 B:1024
[ 2077.049846] spi_master spi1: @isr
[ 2077.049874] spi_master spi1: CMD[03f0902f]: Sl M0 CS0 [HHHH] LSB MSb Rx Pa 16b TRANS[40ff0311]:RDY I:255 B:785
FIFO[00c00004]:RxF:1 TxE:64 Err[] RxSTA[] TxSTA[E]DMA[00110000]: RxTr:2 TxTr:2 B:1023
[ 2077.049939] spi-tegra124-slave 7000d600.spi: ret = 1000 after wait_for_completion_interruptible_timeout spi isr
[ 2077.049952] spi-tegra124-slave 7000d600.spi: ret = 0 after tegra_spi_wait_on_message_xfer
[ 2078.048484] spi_master spi1: rx-dma-timeout [wait:0]
[ 2078.048963] spi_master spi1: CMD[03f0902f]: Sl M0 CS0 [HHHH] LSB MSb Rx Pa 16b TRANS[00ff0311]:BSY I:255 B:785
[ 2078.049320] spi_master spi1: after controller reset
[ 2078.049679] spi_master spi1: CMD[13f08000]: Sl M1 CS0 [HHHH] LSB MSb Un 1b TRANS[00ff0000]:BSY I:255 B:0
[ 2078.049904] spi-tegra124-slave 7000d600.spi: ret = -5 after tegra_spi_handle_message
[ 2078.050336] spi_master spi1: failed to transfer one message from queue
Which I think clearly illustrates exactly what’s going on. This is what’s baffling me, and I was unable to find a solution in the link you posted above.
