Wake Pin Initiator Target Mode 3.3V Tolerance Enable LPDR Enable
Do I need to set these properties above when configuring the SPI pin?
SPI0_SCK output
SPI0_MISO input
SPI0_MOSI output
SPI0_CS0* output
SPI0_CS1* output
Is the direction configured correctly like this ?
Req. Initial State
How to configure the pull-up and pull-down resistors?
Hi 550399056,
You can just configure Customer Usage
, Pin Direction
and Req. Initial State
as following:
SPI1_SCK → Output → Drive 0
SPI1_DIN → Input → Int PD
SPI1_DOUT → Output → Drive 0
SPI1_CS0 → Output → Drive 1
SPI1_CS1 → Output → Drive 1
system
Closed
5
