I am using the Jetson Nano Development Kit - B01. I’m experiencing issues when trying to read values via SPI communication from sensors with pull-up resistors on the Jetson Nano.
The first image shows an oscilloscope measurement of the CS pin from an ENS160 + aht21 gas sensor. The voltage doesn’t completely drop to 0V, resulting in inconsistent readings - sometimes it reads correctly, other times it doesn’t.
The second image shows an oscilloscope measurement of the CS pin from a different accelerometer sensor. The voltage constantly fluctuates, making it impossible to read any values.
I have tested both sensors on different boards with other MCUs, and they output values normally. I can guarantee that there are no issues with the sensors themselves.
I’m wondering if adjusting the drive strength of the Jetson Nano board might help to fully control the CS pin voltage.
Additionally, I unfortunately couldn’t activate SPI through Jetson-IO on my board. Instead, I followed iflybri2’s post (SPI setup issues with Jetson Nano B01 DevKit) as a reference. I was able to activate SPI by first decompiling the dtb file, modifying it, then compiling and flashing it.
I’ve also uploaded my current dtb file for reference. Due to upload issues, I changed the extension to txt.
tegra210-p3448-0000-p3449-0000-b00.txt (231.8 KB)
Plus
I flashed through Nvidia SDK Manager, so I am using L4T 32.7.5, Jetpack 4.6.5
