• Hardware Platform: Jetson Xavier NX
• DeepStream Version: 6.1.1
• JetPack Version (valid for Jetson only): 5.0.2
• TensorRT Version: 8.4.1.5
I use UDP streaming to transfer data from server to client host.
Here are pipelines I use:
- Server:
gst-launch-1.0 v4l2src device=/dev/video2 ! videoconvert ! video/x-raw ! nvvideoconvert ! "video/x-raw(memory:NVMM)" ! nvv4l2h265enc insert-sps-pps=1 maxperf-enable=1 idrinterval=15 ! rtph265pay ! udpsink host=192.168.0.10 port=5000
- Client:
gst-launch-1.0 udpsrc port=5000 ! application/x-rtp, encoding-name="H265", payload=96 ! rtph265depay ! avdec_h265 ! xvimagesink sync=false
Client host displays video well like this:
However, if I change the server pipeline to the command below (using nvv4l2camerasrc instead of v4l2src):
gst-launch-1.0 nvv4l2camerasrc device=/dev/video2 ! nvvideoconvert ! 'video/x-raw(memory:NVMM), format=UYVY' ! nvvideoconvert ! "video/x-raw(memory:NVMM), format=NV12" ! nvv4l2h265enc insert-sps-pps=1 idrinterval=15 maxperf-enable=1 ! rtph265pay ! udpsink host=192.168.0.10 port=5000
Client host will display abnormally like this:
My questions are:
According to this Jetson Nano FAQ, and this Macrosilicon USB - #5 by DaneLLL, I know I must customize nvv4l2camerasrc’ source to solve the wrong color issue. But I will greatly appreciate it if you could guide me on how to do it, customize and rebuild the source. Of course it will depend on enviroment I use, Deepstream’s version and Camera’s format, the DS’s version is at the opening and the Camera’s format will be at the “For more information” section.
Why is the displayed video splitted so abnormally?
For more information:
- Camera format is:
- If I add width=640 and height=512 in the caps like this command:
gst-launch-1.0 nvv4l2camerasrc device=/dev/video2 ! nvvideoconvert ! 'video/x-raw(memory:NVMM), format=UYVY, width=640, height=512' ! nvvideoconvert ! "video/x-raw(memory:NVMM), format=NV12" ! nvv4l2h265enc insert-sps-pps=1 idrinterval=15 maxperf-enable=1 ! rtph265pay ! udpsink host=192.168.0.10 port=5000
Then the displayed video on screen is:
