t.roth
1
We have on machine out of 18 identical ones which refuses to do ibstat
, because
ibpanic: [8821] main: stat of IB device ‘mlx5_0’ failed: No such file or directory
However, the link is up and running, and ibstatus
is happy
default gid: fe80:...
base lid: 0x17b
sm lid: 0x0fc
state: 4: ACTIVE
phys state: 5: LinkUp
rate: 100 Gb/sec (2X HDR)
link_layer: InfiniBand
This situation is invariant under reboots (and cable change).
What might be the matter here?
Cheers,
Thomas
t.roth
2
Wrong!
The IB interface is actually mlx5_1
, and ibstat mlx5_1
shows basically the same as ibstatus
However, the first interface works as the Ethernet interface of the box, and it has lost is gid
~# ibstatus
Infiniband device 'mlx5_0' port 1 status:
default gid: unknown
base lid: 0x0
sm lid: 0x0
state: 4: ACTIVE
rate: 10 Gb/sec (1X QDR)
link_layer: Ethernet
This is of course what makes ibstat
cause a panic.
Nevertheless: this Ethernet port seems to work well (it’s the primary network interface for this machine).
No idea what happened to its gid…
Hi Customer,
ibstat/ibstatus is mainly used to check the interface status in IB mode.
You can test again with the latest MLNX OFED driver.
Enjoy it.
system
Closed
4
