Static calibration recorder tool for pinhole camera model
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
I’m using the static calibration recorder tool (DriveWorks SDK Reference: Static Calibration Recorder Tool) with the supported Entron F008A120RM0AV2 camera sensor and the checkerboard_14x9_74mm_A0.pdf checkerboard as instructed at DriveWorks SDK Reference: Static Camera Calibration Tutorial .
I couldn’t find an option to perform intrinsics calibration for the pinhole camera model. It only outputs calibration for the ftheta model, no matter if I do it with images/video/rig.
My questions:
  1. Is it possible to use the tool for intrinsics calibration of pinhole camera model? If so, how?
  2. Assuming I will perform the intrinsics calibration for pinhole camera myself and create a corresponding rig file, should the extrinsics calibration work?
  3. Can you confirm that rectification functions have support for pinhole camera model? In the samples it seems they should but if it’s deprecated I’d like to know
Thanks,
Alon
You mean, the model name is noticed as “Model”: “ftheta” in rig.json after calibration ? Did you pass any initial rig file as input?
When I ran with the --rig option it performed calibration for model=ftheta regardless of if the rig contained “Model”: “ftheta” or “Model”: “pinhole”.
When I ran with the --video OR --image options (without the rig, as described in the tutorial) it also always performs calibration for the ftheta model.
The camera model is set to ftheta always
Can you try changing model to pinhole in output json file of calibration-recorder (intrinsics_constraints.json) and feed into calibration-graph-cli. We are testing only ftheta.
I will use the tools with ftheta.
