Stencil HBAO+ on DX12
Is it possible to enable stencil test in HBAO with DX12?
I work on a VR game that uses HBAO+. The pixels in the corners are not visible to the player and we use a stencil mesh to early exit the shaders. Looking at the capture, HBAO+ contains mostly fullscreen pixel shaders. If we could early exit in these locations with stencil tests or early z, we could save 10% gpu time.
stencil
Hello @lmira and welcome to the NVIDIA developer forums!
I cannot answer this from the top of my head, but I will try to find it out for you.
Hi again!
HBAO happens on driver level after early-z w/ depth test and similar, so any pixels excluded at that stage should also not be affected by the later stage pixel shaders.
What capture do you mean?
Hi Markus, I did a PIX capture. In this example HBAO takes ~1ms per eye.
It runs ~20 full screen passes with 1 large triangle covering the whole viewport.
I believe HBAO does not take advantage of the stencil mesh:
  • Depth and Stencil test are disable in all HBAO passes
  • I don’t see any performance improvement with/without stencil mesh enabled.
Looking at the file HBAOPlus/GFSDK_SSAO.h at master · NVIDIAGameWorks/HBAOPlus · GitHub,
it seems we can set a custom depth stencil state for DX11, but not for DX12?
