I own both a TX1 and a TX2 and I was wondering to re-use the camera module on the TX1 as an additional camera on the TX2 … so to build a stereo camera system (I need a cheap solution as I am a simple un-founded student)
I noticed the camera module connector is of the same type of the one used for the display connector, so Ideally I was thinking to plug the second camera module (the one coming from the TX1) on the display port od the TX2 … unfortunately, there is not enough room to fit the second camera module on the TX2 and I was now googling to find a male-to-female cable (also few cm will suffice) to move away from the board one of the two connectors (used as an extension cable).
Before to proceed I was wondering if you have any advice, will the second camera work if plugged into the display port? also, where can I find such an extension cable for the display port connector?
Thanks for your help!!!
