Storage temperature issues of the latest modified version of Jetson Orin Nano
This storage temperature does not really match the conditions that can be realized in an industrial setting. Is this reasonable?
That specification is for the module in storage (not deployed/installed in a carrier) or during transportation. Refer to the part of the note below that table: “Duration based on product being packed and stored in a controlled environment without power on.”
For the actual operating temperatures, the range is much wider:
Does it mean that when I mount the nano onto our own baseboard and then power it on to flash the system, I no longer need to worry about this storage temperature during transportation?
Correct. The storage temperature in the spec you referenced is pre-deployment, for example while it sits in storage waiting to be sold (by a distributor) or in inventory waiting to be put into service. The storage temp and humidity directly relate to the storage life spec in the same table: as long as the module stays in those storage ranges, it remains deployable for 5 years from the NVIDIA shipment date. Once the module is in service, the operating temperature specs apply.
