Is jetson nano module Industry grade board which can sustain at harsh temperatures?
hey we are a group of ML Engineers getting into hardware, we wanted to know if this is a industrial gade board? cause we will be using this in our custom made hardware. This will be enclosued in a box and placed outdoor.
The Jetson Nano module is designed for commercial uses and isn’t rated for industrial environments. You could determine if the specs meet your requirements and enclosure, and if the module resides inside an enclosure you could integrate an appropriate cooling solution for it.
See here for a discussion of the Nano module operating temperature range and the Thermal Design Guide:
There are also various Jetson Ecosystem partners who could help design enclosure and see here for a listing of off-the-shelf cases that are available (some of which are IP-rated).
