I wonder if it’s just a software thing when the temperature went below 0c into negative numbers there’s some unsigned int somewhere that caused it to be treated as a very large number and caused the shutdown.
Doing some searching I finally found that Nvidia released a new module in Jul 2019.
The specs for the temp were -25 C to +80 C
Will this help me with my cold weather failure if I acquire this module? Or are there other areas
to look at such as the carrier board and Arduino sensors?
I read the document but it didn’t appease me, did a little more looking and found document
SP-09732-001_v1.1.pdf. - I assume this is the specs for the new carrier board.
On page 3 I found this.
Developer Kit Operating Temperature Range
0 0C to 35 0C (see Note)
Other concerns are the added wifi and SD card.
Warmer temperatures are coming up so can continue with Nano, am looking at TX series though.
Another route is to build a bed warmer similar to my 3d printer bed.
I guess all of this and more has to be considered for extreme conditions.
Dev kit includes carrier board, so its temp range is different to module, dev kit should not be used for product. Customer should make custom carrier board for their end product and so for the whole thermal design.
