Stream specific tracker config for multistream pipeline
• Hardware Platform GPU
• DeepStream Version 7.0
• TensorRT Version 10.6.0
• NVIDIA GPU Driver Version 560.35.03
I’m running 3 streams in a pipeline
for each stream, I need different tracker config, how to approach this problem were 3 streams should be run in a pipeline.
stream - 1, tracker config
BaseConfig:
  minDetectorConfidence: 0.3   # If the confidence of a detector bbox is lower than this, then it won't be considered for tracking
TargetManagement:
  enableBboxUnClipping: 1   # In case the bbox is likely to be clipped by image border, unclip bbox
  maxTargetsPerStream: 1500  # Max number of targets to track per stream. Recommended to set >10. Note: this value should account for the targets being tracked in shadow mode as well. Max value depends on the GPU memory capacity
  # [Creation & Termination Policy]
  minIouDiff4NewTarget: 0.5   # If the IOU between the newly detected object and any of the existing targets is higher than this threshold, this newly detected object will be discarded.
  minTrackerConfidence: 0.2   # If the confidence of an object tracker is lower than this on the fly, then it will be tracked in shadow mode. Valid Range: [0.0, 1.0]
  probationAge: 5 # If the target's age exceeds this, the target will be considered to be valid.
  maxShadowTrackingAge: 50  # Max length of shadow tracking. If the shadowTrackingAge exceeds this limit, the tracker will be terminated.
  earlyTerminationAge: 3   # If the shadowTrackingAge reaches this threshold while in TENTATIVE period, the target will be terminated prematurely.
TrajectoryManagement:
  useUniqueID: 0   # Use 64-bit long Unique ID when assignining tracker ID. Default is [true]
DataAssociator:
  dataAssociatorType: 0 # the type of data associator among { DEFAULT= 0 }
  associationMatcherType: 0 # the type of matching algorithm among { GREEDY=0, GLOBAL=1 }
  checkClassMatch: 1  # If checked, only the same-class objects are associated with each other. Default: true
  # [Association Metric: Thresholds for valid candidates]
  minMatchingScore4Overall: 0.2   # Min total score
  minMatchingScore4SizeSimilarity: 0.6  # Min bbox size similarity score
  minMatchingScore4Iou: 0.1       # Min IOU score
  minMatchingScore4VisualSimilarity: 0.6  # Min visual similarity score
  # [Association Metric: Weights]
  matchingScoreWeight4VisualSimilarity: 0.7  # Weight for the visual similarity (in terms of correlation response ratio)
  matchingScoreWeight4SizeSimilarity: 0.0    # Weight for the Size-similarity score
  matchingScoreWeight4Iou: 0.3   # Weight for the IOU score
StateEstimator:
  stateEstimatorType: 1  # the type of state estimator among { DUMMY=0, SIMPLE=1, REGULAR=2 }
  # [Dynamics Modeling]
  processNoiseVar4Loc: 2.0    # Process noise variance for bbox center
  processNoiseVar4Size: 1.0   # Process noise variance for bbox size
  processNoiseVar4Vel: 0.1    # Process noise variance for velocity
  measurementNoiseVar4Detector: 4.0    # Measurement noise variance for detector's detection
  measurementNoiseVar4Tracker: 16.0    # Measurement noise variance for tracker's localization
VisualTracker:
  visualTrackerType: 1 # the type of visual tracker among { DUMMY=0, NvDCF=1 }
  # [NvDCF: Feature Extraction]
  useColorNames: 1     # Use ColorNames feature
  useHog: 1         # Use Histogram-of-Oriented-Gradient (HOG) feature
  featureImgSizeLevel: 3  # Size of a feature image. Valid range: {1, 2, 3, 4, 5}, from the smallest to the largest
  featureFocusOffsetFactor_y: -0.2 # The offset for the center of hanning window relative to the feature height. The center of hanning window would move by (featureFocusOffsetFactor_y*featureMatSize.height) in vertical direction
  # [NvDCF: Correlation Filter]
  filterLr: 0.05 # learning rate for DCF filter in exponential moving average. Valid Range: [0.0, 1.0]
  filterChannelWeightsLr: 0.1 # learning rate for the channel weights among feature channels. Valid Range: [0.0, 1.0]
  gaussianSigma: 0.75 # Standard deviation for Gaussian for desired response when creating DCF filter [pixels]
stream - 2 and 3, tracker config
%YAML:1.0
BaseConfig:
  minDetectorConfidence: 0.1   # If the confidence of a detector bbox is lower than this, then it won't be considered for tracking
TargetManagement:
  probationAge: 10 # If the target's age exceeds this, the target will be considered to be valid.
  earlyTerminationAge: 10   # If the shadowTrackingAge reaches this threshold while in TENTATIVE period, the target will be terminated prematurely.
DataAssociator:
StateEstimator:
VisualTracker:
Can you have a try with nvtracker sub-batching based on here: Gst-nvtracker — DeepStream documentation?
hi
can you share any example in python for Sub-batching (Alpha) nv tracker.
I have used below, to assign each stream a tracker config
stream - 0 - tracker_config_1.yml
stream - 1 - tracker_config_2.yml
but it is not making any difference,
both stream 0 and 1 takes tracker_config_1.yml
why is that?
[tracker]
tracker-width=640
tracker-height=384
gpu-id=0
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
ll-config-file=tracker_config_1.yml;tracker_config_2.yml
sub-batches=0;1
tracker.set_property("sub-batches", "0;1")
When I used above, I got
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Initialized
[NvTrackerParams::getConfigRoot()] !!![WARNING] File doesn’t exist. Will go ahead with default values
but it worked when setting as set_property.
when I used below in config file, it is not working.
sub-batches=0;1
Here is the usage of sub-batching: Gst-nvtracker — DeepStream documentation
thanks @kesong
link was helpful,
I was able to implement,
you can close this topic.
