Suject: Jetson Orin Nano stuck at "End-user configuration" during first boot (JetPack 6.x) Dear Support Team, I am experiencing a persistent issue w
Subject: Jetson Orin Nano stuck at “End-user configuration” during first boot (JetPack 6.x)
​Dear Support Team,
​I am experiencing a persistent issue with my Jetson Orin Nano Developer Kit. After flashing the SD card with JetPack 6.1/6.2 (L4T 36.4.3), the system fails to reach the GUI setup screen.
​Problem Details:
  • ​The boot process proceeds normally through UEFI and starts loading the Linux kernel.
  • ​The system hangs indefinitely at the following line: [***] (1 of 2) A start job is running for End-user configuration after initial OEM installation.
  • ​I have waited for over 90 minutes, but the setup screen never appears.
​Troubleshooting steps already taken:
  1. ​Reset to Defaults: I have performed a “Reset Settings” within the NVIDIA Configuration menu in UEFI.
  2. ​Flashing Tools: I have tried flashing the 128GB SD card using both Rufus and balenaEtcher.
  3. ​Hardware Check: The NVMe SSD is removed to ensure the system boots from the SD card only.
  4. ​Network: No internet cable or Wi-Fi is connected during the initial setup to avoid update-related hangs.
​Could you please advise if this is a known firmware compatibility issue with L4T 36.4.3 or if there is a specific hardware initialization failure?.
​Best regards,
We recommend to install sdk manager to full flash the device.
