Hi, I would like to know if I can connect a BT microphone to a Jetson Orin Nano.
And if yes, does it need to be a specific type of microphone, or could it be any?
Thanks in advance
Thanks in advance
Connecting a Bluetooth (BT) microphone to a Jetson Orin Nano is possible, but it requires some considerations. The Jetson Orin Nano has a 40-pin GPIO expansion header, which exposes audio I/O connections, including I2S (Inter-IC Sound) interface. However, Bluetooth connectivity is not directly supported by the GPIO header.
To connect a BT microphone to the Jetson Orin Nano, you’ll need to use a separate Bluetooth module or a USB Bluetooth adapter. Here are a few options:
When choosing a BT microphone, consider the following factors:
In summary, while the Jetson Orin Nano does not have built-in Bluetooth connectivity, you can connect a BT microphone using a separate Bluetooth module or USB adapter. When selecting a microphone, consider compatibility, audio quality, and power requirements.
Here’s a comparison of the options:
| Option | Advantages | Disadvantages |
| USB Bluetooth adapter | Easy to use, widely available | May require additional power, depends on adapter quality |
| Bluetooth module with I2S interface | Direct connection to Jetson Orin Nano, potentially lower latency | May require additional configuration, power supply, and module quality can vary |
| Audio codec with Bluetooth connectivity | Integrated solution, potentially easier to use | May be more expensive, depends on codec quality and compatibility |
Ultimately, the choice of BT microphone and connection method depends on your specific requirements, such as audio quality, power constraints, and ease of use.
Please enable this:
Enabling Bluetooth Audio — NVIDIA Jetson Linux Developer Guide
And please check if any kernel configs are required for bluetooth microphone. You can enable the configs and rebuild kernel by referring to
Kernel Customization — NVIDIA Jetson Linux Developer Guide
No data from Joystick Logitech-f710 - #10 by DaneLLL
