Hi, as a lot of changes on the infiniband / rdma stuff were happening in 5.10 kernel the OFED 5.4-1.0.3.0 is incompatible with it, after installation I’m getting lots of errors in the foramt:
Thank you for posting your inquiry on the NVIDIA Networking Community.
Based on the information provided, the errors you are facing appear when the kernel is update and the MLNX_OFED was already installed based on the previous kernel.
To resolve this issue, we recommend to uninstall the current MLNX_OFED installation through the syntax → # ofed_uninstall.sh
and then reinstall MLNX_OFED with the following syntax → # ./mlnxofedinstall --add-kernel-support -vvv -y
Be aware that MLNX_OFED 5.4 GA does not support kernels > 5.10+. Currently there is no information available when MLNX_OFED will support kernels > 5.10+
