Hi Team,
Whether “NVIDIA ConnectX-7 Adapter Cards Firmware Release v28.45.1200” (NVIDIA ConnectX-7 Adapter Cards Firmware Release Notes v28.45.1200 - NVIDIA Docs ) supports NVMe OF ?
If supported, can I use the procedure in this link (EnterpriseSupport ) to verify NVMe ?
Thanks in advance.
gilh
July 20, 2025, 6:55am
2
Hi
Yes, it is supported, and you can use the webpage to configure the CX7
Best Regards
Thankyou.
Do I need to install MLNX_OFED at first, then I should use firmware update ?
gilh
July 20, 2025, 11:52am
4
FW update,It is always recommended to do. OFED only if you are using the target “offload”
I want to confirm the webpage to install ConnectX-7 firmware. So can I prefer this page. Updating the ConnectX-7 Firmware — NVIDIA DGX H100/H200 Firmware Update Guide ?
I am even checking for Crypto features supported in MCX75310AAC-NEAT in same firmware. But the firmware release note are common to all the Adaptor cards. Could you please confirm the Crypto supported in the firmware for MCX75310AAC-NEAT.
Thankyou @gilh
Some ConnectX-7 OPN have Crypto supported, other no.
Please see the following link: NVIDIA ConnectX-7 Adapter Cards User Manual - NVIDIA Docs
MCX75310AAS-NEAT, MCX75310AAS-HEAT, MCX713104AS-ADAT - Crypto not supported
MCX75310AAC-NEAT, MCX713104AC-ADAT - Crypto supported
Best regards,
Michael.
@michaelbe Thankyou. This was helpful
