If Argus API is used via nvarguscamerasrc gstreamer plugin, it outputs bunch of hardware init/de-init logs (GST_ARGUS:, CONSUMER:, PowerServiceHwVic:), e.g.:
$ gst-launch-1.0 nvarguscamerasrc ! nvoverlaysink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 4056 x 3040 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 354,000000; Exposure Range min 16000, max 165770000;
GST_ARGUS: 3840 x 2160 FR = 59,999999 fps Duration = 16666667 ; Analog Gain range min 1,000000, max 354,000000; Exposure Range min 16000, max 165770000;
GST_ARGUS: 1920 x 1080 FR = 59,999999 fps Duration = 16666667 ; Analog Gain range min 1,000000, max 354,000000; Exposure Range min 5000, max 352112000;
GST_ARGUS: 2028 x 1520 FR = 160,000000 fps Duration = 6250000 ; Analog Gain range min 1,000000, max 354,000000; Exposure Range min 3000, max 252525000;
GST_ARGUS: 1348 x 750 FR = 240,000038 fps Duration = 4166666 ; Analog Gain range min 1,000000, max 354,000000; Exposure Range min 0, max 2000000;
GST_ARGUS: 692 x 520 FR = 480,000077 fps Duration = 2083333 ; Analog Gain range min 1,000000, max 354,000000; Exposure Range min 0, max 2000000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 59,999999
GST_ARGUS: PowerService: requested_clock_Hz=27216000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:01.330161805
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Setting pipeline to NULL ...
Freeing pipeline ...
GST_ARGUS:
PowerServiceHwVic::cleanupResources
This verbosity should be controlled via GST_DEBUG env var, but nvidia plugin completely ignores it.
How to disables these messages?
