Expected behaviour: invoking # systemctl suspend makes the laptop go to suspend
Actual behaviour: invoking # systemctl suspend makes systemctl log brefly appear on screen (as if the laptop was powering off), then brings me to the login screen.
Downgrading to version 3:455.28-1.fc33 makes suspend work.
Some days ago I followed this guide because suspend was not working anymore after another update.
I suspect that the files mentioned in that guied are missing for some reason in version 470, which causes the suspend to break.
Feel free to write me if more details are needed. Thank you for your attention.
EDIT: I tried to downgrade driver running sudo dnf install xorg-x11-drv-nvidia-3:455.28-1.fc33 but it seems that this caused to unload the driver, because running nvidia-settings from terminal outputs:
$ nvidia-settings
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
So i think that unloading the driver is a workaround too
