Nvidia driver causes boot hang when upgrading to Fedora 23
Fedora 23 uses Xserver v20, nvidia supports v19. Machine hangs on boot until you manually remove the nvidia driver.
I raised this issue with Fedora and they told me to raise it with nvidia.
https://bugzilla.redhat.com/show_bug.cgi?id=1272760
Anyone here on the nvidia driver / Fedora communications team who can look at this?
“Fedora 23 uses Xserver v20, nvidia supports v19.”
There’s your problem. Fedora ships unstable Xorg development versions. NVIDIA supports the latest stable version of xorg-server 1.17.2. So it doesn’t work. NVIDIA will support the next Xorg release when it’s actually released. That’s how it has always been. So the fix is to downgrade to the stable version of Xorg.
See: http://us.download.nvidia.com/XFree86/Linux-x86_64/355.11/README/minimumrequirements.html
But Fedora 23 is in final freeze and is due to be the stable, latest version next week.
https://fedoraproject.org/wiki/Releases/23/Schedule
How are you supposed to do that when the machine doesn’t boot?
Your Fedora machine does boot, it is just that the X Server that you are used to does not start. At the black screen with the flashing underscore, hit CTRL-ALT-2 or CTRL-ALT-3 and login as root at the console. You now have your machine in a usable state.
You can then downgrade the x11-xorg server to a 1.17 version.
If you are not familiar with running this type of thing, then you probably should downgrade to F22 immediately if you can at all. This is not super trivial to fix and will require some work and research on your behalf.
If you are confident at the command line, then I highly suggest that you start looking into the process as it only took me a short time to downgrade xorg-x11 to 1.17 (from Fedora 22 repos) and get up and running again with a Fedora 23 installation (everything except xorg-x11 was standard F23) using the latest NVIDIA driver. This will be extremely valuable to you later, trust me.
As a side note, I am having a few other issues with F23 that are a bit painful with respect to specific applications not playing nicely, this however has nothing to do with the NVIDIA driver, but it is why I am not recommending anyone specifically upgrade from F22 to F23 right now.
Also, you will note that F23 release has slipped another week and this issue (XORG-X11 v1.18 causing issues with NVIDIA) is not one of the reasons for the slip. This problem is not going away and until an NVIDIA driver is released with ABI support for V1.18 then it will be a problem in F23.
