I noticed unusual behavior with swizzling the alpha component into any RGB channel. In the first image, I have constructed an image where the R component has the same values as the alpha component, and the r channel is displayed. In the second image, I’ve swizzled from A to R. Notice to dramatic increase in values after the swizzle. This behavior is consistent with at least PNG and TGA so I expect it not to be format dependent.
Conversely, but not demonstrated here. Swizzling any channel from RGB to A seems to have the opposite effect, where the value ranges decrease.
I can’t think of why this behavior should be happening. So I thought I’d report it for a sanity check.
