I would like to start using Mellanox equipment with a new SAN upgrade I’m planning out. I have a couple of questions that hopefully someone might be able to help me with. I want to use 2 SX1012’s to connect 4 VMWARE hosts, a Nimble CS1000 SAN, and HP 5400zl core. I’d like to use the 40GBE to 10GBE breakout cables and have everything running Ethernet and SFP+. What would be the ideal connection to make between both SX1012’s? I didn’t know about InfiniBand until I started researching Mellanox, can that be used in conjunction with Ethernet protocol? Attached is a diagram of our setup. I appreciate anyone’s time and guidance.
Jason the SX1012 is an Ethernet switch. So Infiniband is not relevant here. To connect these switches between each other I suggest you use 2 cables type 40GbE DAC.
