Hey, I’m trying to obtain the 36.2 kernel sources for Jetpack 6.0, but ./source_sync.sh isn’t working.
Another question, I don’t quite understand whether to obtain the kernel from the drivers section or the sources section. I know that the sources is the source code as is, but if someone can explain the specific differences to me I would appreciate it.
I deduce that for the installation, with the drivers it is with ./flash.sh and with the source it is by changing the Image file and the /lib/modules.
It seems like the server is down. Please get the kernel code from the tarball:
Kernel Customization — NVIDIA Jetson Linux Developer Guide 1 documentation
Okay i will get kernel from source. For rootfs I can use Sample Root Filesystem or i must use Sample Root Filesystem Sources ?.
And when I have the RT Kernel compiled, the installation for Jetson 36.2 is the same as Jetson 35?
Or there is some different detail?
Please try with JetPack 6.0 GA release.
