Hello NV Teams
Orin nx 16G
board: customer board
I currently have two sets of equipment. Both of them are orin nx 16+customer board. One of them can start normally, while the other one has been reprogrammed with the same qspi. However, when the working hard drive is placed on the latter set, it fails to start. Below is the log from the debugging serial port. log.txt (37.2 KB)
I’d like to add one more thing. I scanned the QR code on the back of the module.
The activated modules are as follows
We have over a hundred sets of equipment that require the use of a copy hard drive method. Currently, four modules have encountered this problem. Could you please take a look and help us out?
Yes the modules and the base plate are all exactly the same.
Yes. I didn’t see any error message, so I have no idea where to start either.
I’m very sorry. I haven’t tried it on the official baseboard yet because I only have one official baseboard in my possession. If it’s a direct flash of the system, it can be started on any baseboard.
I would like to add one more point:
Today, after re-flashing the system on the module that couldn’t start yesterday, it was able to boot up. However, when I tried it on the module that was working fine yesterday, it failed to start again. This is very strange. I can assure you that the software versions of both the module and the baseboard are exactly the same, and they are using the same ones.
I reinstalled the flash system on a new hard drive. This hard drive was paired with an unbootable module. After re-flashing the system, everything worked fine. However, yesterday I still had another module that could boot normally with another disk. When I swapped the disks, I found that the other one couldn’t boot either. I suspect it might be a problem with the module materials.
If reflashing the module recovers the system from the failure state, there may be an underlying issue with the module itself.
Please help verify which operations trigger this behavior.
Today, I conducted a further investigation and discovered that it was likely due to a conflict between the customer’s ef7221 driver and the I2C interface, which caused the system to fail to start.
He did it in this way:
dtc -I fs -O dtb /proc/device-tree > system.dtb
fdtoverlay -i system.dtb -o system_ef7221.dtb ~/Downloads/camera-fdt/ef7221.dtbo
sudo install -m 0644 system_ef7221.dtb /boot/dtb/
sudo cp /boot/extlinux/extlinux.conf /boot/extlinux/extlinux.conf.bak.ef7221-$(date +%Y%m%d-%H%M%S)
sudo nano /boot/extlinux/extlinux.conf
append:FDT /boot/dtb/system_ef7221.dtb
I have verified that it was this that caused it.
But now I want to load it using the overlay method. The result of my modification to /boot/extlinux/extlinux.conf is as follows:
LABEL EF7221 MENU LABEL Custom Header Config:
LINUX /boot/Image
FDT /boot/dtb/kernel_y-c6-orin-nx-3643.dtb
INITRD /boot/initrd
APPEND ${cbootargs} root=PARTUUID=797940aa-4f6b-4a97-b577-afa666cce0b5 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb video=efifb:off console=tty0
OVERLAYS /boot/dtb/ef7221.dtbo
However, it seems that the overlay.dtbo has not been loaded successfully. Could you please help me check if there is something wrong with my overlay method?
