1>------ Up-To-Date check: Project: vect_addition, Configuration: Debug x64 ------
1>Project is not up-to-date: last build was unsuccessful.
1>------ Build started: Project: vect_addition, Configuration: Debug x64 ------
1>Build started 3/23/2019 2:12:40 PM.
1>Building with tools version “15.0”.
1>Target “EnableIntermediateOutputPathMismatchWarning” skipped, due to false condition; (‘$(RestoreProjectStyle)’ == ‘PackageReference’) was evaluated as (‘’ == ‘PackageReference’).
1>Target _CheckForInvalidConfigurationAndPlatform:
1> Set Property: _InvalidConfigurationMessageText=The OutputPath property is not set for project ‘vect_addition.vcxproj’. Please check to make sure that you have specified a valid combination of Configuration and Platform for this project. Configuration=‘Debug’ Platform=‘x64’.
1> Set Property: _InvalidConfigurationMessageText=The OutputPath property is not set for project ‘vect_addition.vcxproj’. Please check to make sure that you have specified a valid combination of Configuration and Platform for this project. Configuration=‘Debug’ Platform=‘x64’. This error may also appear if some other project is trying to follow a project-to-project reference to this project, this project has been unloaded or is not included in the solution, and the referencing project does not build using the same or an equivalent Configuration or Platform.
1> Task “Error” skipped, due to false condition; ( ‘$(_InvalidConfigurationError)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1> Task “Warning” skipped, due to false condition; ( ‘$(_InvalidConfigurationWarning)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1> Using “Message” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “Message”
1> Task Parameter:Text=Configuration=Debug
1> Task Parameter:Importance=Low
1> Configuration=Debug
1> Done executing task “Message”.
1> Task “Message”
1> Task Parameter:Text=Platform=x64
1> Platform=x64
1> Task “Error” skipped, due to false condition; (‘$(OutDir)’ != ‘’ and !HasTrailingSlash(‘$(OutDir)’)) was evaluated as (‘E:\source\practice\cuda_lab\vect_addition\x64\Debug' != ‘’ and !HasTrailingSlash(‘E:\source\practice\cuda_lab\vect_addition\x64\Debug')).
1> Task “Error” skipped, due to false condition; (’$(BaseIntermediateOutputPath)’ != ‘’ and !HasTrailingSlash(‘$(BaseIntermediateOutputPath)’)) was evaluated as (‘obj' != ‘’ and !HasTrailingSlash(‘obj')).
1> Task “Error” skipped, due to false condition; (’$(IntermediateOutputPath)’ != ‘’ and !HasTrailingSlash(‘$(IntermediateOutputPath)’)) was evaluated as (‘x64\Debug' != ‘’ and !HasTrailingSlash(‘x64\Debug')).
1> Task “Error” skipped, due to false condition; ( ‘$(_InitialMSBuildProjectExtensionsPath)’ != ‘’ And ‘$(MSBuildProjectExtensionsPath)’ != ‘$(_InitialMSBuildProjectExtensionsPath)’ ) was evaluated as ( ‘E:\source\practice\cuda_lab\vect_addition\vect_addition\obj' != ‘’ And ‘E:\source\practice\cuda_lab\vect_addition\vect_addition\obj' != ‘E:\source\practice\cuda_lab\vect_addition\vect_addition\obj' ).
1> Task “Warning” skipped, due to false condition; ( ‘$(EnableBaseIntermediateOutputPathMismatchWarning)’ == ‘true’ And ‘$(_InitialBaseIntermediateOutputPath)’ != ‘$(BaseIntermediateOutputPath)’ And ‘$(BaseIntermediateOutputPath)’ != ‘$(MSBuildProjectExtensionsPath)’ ) was evaluated as ( ‘’ == ‘true’ And ‘obj' != ‘obj' And ‘obj' != ‘E:\source\practice\cuda_lab\vect_addition\vect_addition\obj' ).
1>Target “_CheckForInvalidConfigurationAndPlatform” skipped. Previously built successfully.
1>Target SetTelemetryEnvironmentVariables:
1> Using “SetEnv” task from assembly “E:\Applications\Microsoft Visual Studio\Common7\IDE\VC\VCTargets\Microsoft.Build.CppTasks.Common.dll”.
1> Task “SetEnv”
1> Task Parameter:Name=VSTEL_SolutionSessionID
1> Task Parameter:Prefix=False
1> VSTEL_SolutionSessionID=
1> Done executing task “SetEnv”.
1> Task “SetEnv”
1> Task Parameter:Name=VSTEL_CurrentSolutionBuildID
1> VSTEL_CurrentSolutionBuildID=
1> Task “SetEnv”
1> Task Parameter:Name=VSTEL_ProjectID
1> Task Parameter:Value={A7976A72-8D66-437B-8D23-FABF03B2EE2F}
1> VSTEL_ProjectID={A7976A72-8D66-437B-8D23-FABF03B2EE2F}
1> Output Property: VSTEL_ProjectID={A7976A72-8D66-437B-8D23-FABF03B2EE2F}
1>Target _PrepareForBuild:
1> Set Property: BuildType=Build
1> Set Property: _BuildActionType=Build
1> Task “CreateItem” skipped, due to false condition; (’%(CustomBuild.IncludeFileToTool)’!=’’) was evaluated as (’’!=’’).
1> Removed Item(s):
1> CustomBuildStep=
1> vect_addition
1> Message=Performing Custom Build Step
1>Target _PrepareForReferenceResolution:
1> Set Property: TargetFrameworkMoniker=
1> Set Property: _FindDependencies=false
1> Set Property: AdditionalExplicitAssemblyReferences=
1> Task “Message” skipped, due to false condition; (’$(_REFERENCE_DEBUG)‘==‘true’) was evaluated as (’‘==‘true’).
1>Target “ComputeCrtSDKReference” skipped, due to false condition; (’@(ClCompile)‘!=’’ and ‘$(WindowsAppContainer)’==‘true’ and ‘$(UseCrtSDKReference)’ != ‘false’) was evaluated as (‘’!=‘’ and ‘false’==‘true’ and ‘’ != ‘false’).
1>Target BeforeResolveReferences:
1>Target AssignProjectConfiguration:
1> Set Property: ShouldUnsetParentConfigurationAndPlatform=true
1> Using “AssignProjectConfiguration” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “AssignProjectConfiguration”
1> Task Parameter:CurrentProject=E:\source\practice\cuda_lab\vect_addition\vect_addition\vect_addition.vcxproj
1> Task Parameter:CurrentProjectConfiguration=Debug
1> Task Parameter:CurrentProjectPlatform=x64
1> Task Parameter:OutputType=exe
1> Task Parameter:ResolveConfigurationPlatformUsingMappings=False
1> Task Parameter:SolutionConfigurationContents=
1> Debug|x64
1>
1> Task Parameter:OnlyReferenceAndBuildProjectsEnabledInSolutionConfiguration=True
1> Task Parameter:ShouldUnsetParentConfigurationAndPlatform=True
1> Done executing task “AssignProjectConfiguration”.
1>Target “AssignProjectConfiguration” skipped. Previously built successfully.
1>Target _SplitProjectReferencesByFileExistence:
1> Task “ResolveNonMSBuildProjectOutput” skipped, due to false condition; (‘$(BuildingInsideVisualStudio)’==‘true’ and ‘@(ProjectReferenceWithConfiguration)’!=‘’) was evaluated as (‘true’==‘true’ and ‘’!=‘’).
1>Target _GetProjectReferenceTargetFrameworkProperties:
1> Set Property: ReferringTargetFrameworkForProjectReferences=.NETFramework,Version=v4.0
1> Using “MSBuild” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “MSBuild”
1> Task Parameter:Targets=GetTargetFrameworks
1> Task Parameter:BuildInParallel=True
1> Task Parameter:RemoveProperties=;TargetFramework;RuntimeIdentifier
1> Task Parameter:SkipNonexistentTargets=True
1> Done executing task “MSBuild”.
1> Task “GetReferenceNearestTargetFrameworkTask” skipped, due to false condition; (‘@(_ProjectReferenceTargetFrameworkPossibilities->Count())’ != ‘0’ and ‘$(ReferringTargetFrameworkForProjectReferences)’ != ‘’) was evaluated as (‘0’ != ‘0’ and ‘.NETFramework,Version=v4.0’ != ‘’).
1>Target PrepareProjectReferences:
1>Target “_RemoveNameMetadataFromProjectReferenceItems” skipped, due to false condition; (‘@(ProjectReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Target ResolveProjectReferences:
1> Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and (‘$(BuildingInsideVisualStudio)’ == ‘true’ or ‘$(BuildProjectReferences)’ != ‘true’) and ‘$(VisualStudioVersion)’ != ‘10.0’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and (‘true’ == ‘true’ or ‘true’ != ‘true’) and ‘15.0’ != ‘10.0’ and ‘’ != ‘’).
1> Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and (‘$(BuildingInsideVisualStudio)’ == ‘true’ or ‘$(BuildProjectReferences)’ != ‘true’) and ‘$(VisualStudioVersion)’ == ‘10.0’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and (‘true’ == ‘true’ or ‘true’ != ‘true’) and ‘15.0’ == ‘10.0’ and ‘’ != ‘’).
1> Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘$(BuildingInsideVisualStudio)’ != ‘true’ and ‘$(BuildProjectReferences)’ == ‘true’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and ‘true’ != ‘true’ and ‘true’ == ‘true’ and ‘’ != ‘’).
1> Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘$(BuildingProject)’ == ‘true’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and ‘true’ == ‘true’ and ‘’ != ‘’).
1> Task “Warning” skipped, due to false condition; (‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘@(_MSBuildProjectReferenceNonexistent)’ != ‘’) was evaluated as (‘’ != ‘’ and ‘’ != ‘’).
1>Target “FindInvalidProjectReferences” skipped, due to false condition; (‘$(FindInvalidProjectReferences)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1>Target “ResolveNativeReferences” skipped, due to false condition; (‘@(NativeReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Target “_PrepareForReferenceResolution” skipped. Previously built successfully.
1>Target “ResolveProjectReferences” skipped. Previously built successfully.
1>Target GetFrameworkPaths:
1> Added Item(s): _TargetFramework40DirectoryItem=C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319
1> Added Item(s): _TargetFramework35DirectoryItem=C:\WINDOWS\Microsoft.NET\Framework\v3.5
1> Added Item(s): _TargetFramework30DirectoryItem=C:\WINDOWS\Microsoft.NET\Framework\v3.0
1> Added Item(s): _TargetFramework20DirectoryItem=C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727
1> Added Item(s): _TargetedFrameworkDirectoryItem=C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319
1> Added Item(s): _CombinedTargetFrameworkDirectoriesItem=C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319
1> Set Property: TargetFrameworkDirectory=C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319
1> Set Property: TargetFrameworkSDKDirectory=C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A
1> Added Item(s): _TargetFrameworkSDKDirectoryItem=C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A
1>Target “GetWinFXPath” skipped, due to false condition; ((‘@(Page)’ != ‘’ or ‘@(ApplicationDefinition)’ != ‘’ or ‘@(Resource)’ != ‘’) and (‘$(GetWinFXNativePath)’ != ‘’ or ‘$(GetWinFXWoWPath)’ != ‘’ )) was evaluated as ((‘’ != ‘’ or ‘’ != ‘’ or ‘’ != ‘’) and (‘’ != ‘’ or ‘’ != ‘’ )).
1>Target “GetFrameworkPaths” skipped. Previously built successfully.
1>Target GetReferenceAssemblyPaths:
1> Task “GetReferenceAssemblyPaths” skipped, due to false condition; (‘$(TargetFrameworkMoniker)’ != ‘’ and (‘$(_TargetFrameworkDirectories)’ == ‘’ or ‘$(_FullFrameworkReferenceAssemblyPaths)’ == ‘’)) was evaluated as (‘’ != ‘’ and (‘C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.0’ == ‘’ or ‘C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.0’ == ‘’)).
1> Set Property: TargetFrameworkDirectory=C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.0;;
1> Set Property: TargetFrameworkDirectory=C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.0;;;E:\Windows Kits\10\References
1> Set Property: RemoveAssemblyFoldersIfNoTargetFramework=true
1>Target SetBuildDefaultEnvironmentVariables:
1> Task “SetEnv”
1> Task Parameter:Name=PATH
1> Task Parameter:Value=E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\bin\HostX86\x64;E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\bin\HostX86\x86;E:\Windows Kits\10\bin\10.0.17763.0\x86;;C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.6.1 Tools;E:\Applications\Microsoft Visual Studio\Common7\tools;E:\Applications\Microsoft Visual Studio\Common7\ide;C:\Program Files (x86)\HTML Help Workshop;;E:\Applications\Microsoft Visual Studio\MSBuild\15.0\Bin;C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319;;E:\Applications\Anaconda3;E:\Applications\Anaconda3\Library\mingw-w64\bin;E:\Applications\Anaconda3\Library\usr\bin;E:\Applications\Anaconda3\Library\bin;E:\Applications\Anaconda3\Scripts;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;E:\Applications\IntelSWTools\compilers_and_libraries_2019.0.117\windows\mpi\intel64\bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\compiler;C:\Program Files\Microsoft MPI\Bin;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\dotnet;E:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin;E:\Program Files (x86)\IncrediBuild;C:\Program Files\Git\cmd;C:\Program Files\Java\jdk1.8.0_181\bin;C:\Program Files\Intel\WiFi\bin;C:\Program Files\Common Files\Intel\WirelessCommon;E:\Applications\IntelSWTools\compilers_and_libraries_2019.0.117\windows\mkl\lib;C:\Program Files\NVIDIA Corporation\NVSMI;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn;C:\Program Files\Microsoft SQL Server\130\Tools\Binn;C:\Program Files (x86)\Microsoft SQL Server\130\DTS\Binn;C:\Program Files\Microsoft SQL Server\130\DTS\Binn;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn;C:\Program Files (x86)\Microsoft SQL Server\150\DTS\Binn;C:\Program Files\Microsoft SQL Server\120\Tools\Binn;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin;E:\Applications\nodejs;C:\Users\zeref\Downloads\Programs\opencv\build\x64\vc15\bin;E:\Applications\Anaconda3;E:\Applications\Anaconda3\Library\mingw-w64\bin;E:\Applications\Anaconda3\Library\usr\bin;E:\Applications\Anaconda3\Library\bin;E:\Applications\Anaconda3\Scripts;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;E:\Applications\IntelSWTools\compilers_and_libraries_2019.0.117\windows\mpi\intel64\bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\compiler;C:\Program Files\Microsoft MPI\Bin;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\dotnet;E:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin;E:\Program Files (x86)\IncrediBuild;C:\Program Files\Git\cmd;C:\Program Files\Java\jdk1.8.0_181\bin;C:\Program Files\Intel\WiFi\bin;C:\Program Files\Common Files\Intel\WirelessCommon;E:\Applications\IntelSWTools\compilers_and_libraries_2019.0.117\windows\mkl\lib;C:\Program Files\NVIDIA Corporation\NVSMI;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn;C:\Program Files\Microsoft SQL Server\130\Tools\Binn;C:\Program Files (x86)\Microsoft SQL Server\130\DTS\Binn;C:\Program Files\Microsoft SQL Server\130\DTS\Binn;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn;C:\Program Files (x86)\Microsoft SQL Server\150\DTS\Binn;C:\Program Files\Microsoft SQL Server\120\Tools\Binn;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin;E:\Applications\nodejs;C:\Users\zeref\AppData\Local\Microsoft\WindowsApps;C:\Users\zeref\AppData\Roaming\npm;
1> PATH=E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\bin\HostX86\x64;E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\bin\HostX86\x86;E:\Windows Kits\10\bin\10.0.17763.0\x86;;C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.6.1 Tools;E:\Applications\Microsoft Visual Studio\Common7\tools;E:\Applications\Microsoft Visual Studio\Common7\ide;C:\Program Files (x86)\HTML Help Workshop;;E:\Applications\Microsoft Visual Studio\MSBuild\15.0\Bin;C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319;;E:\Applications\Anaconda3;E:\Applications\Anaconda3\Library\mingw-w64\bin;E:\Applications\Anaconda3\Library\usr\bin;E:\Applications\Anaconda3\Library\bin;E:\Applications\Anaconda3\Scripts;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;E:\Applications\IntelSWTools\compilers_and_libraries_2019.0.117\windows\mpi\intel64\bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\compiler;C:\Program Files\Microsoft MPI\Bin;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\dotnet;E:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin;E:\Program Files (x86)\IncrediBuild;C:\Program Files\Git\cmd;C:\Program Files\Java\jdk1.8.0_181\bin;C:\Program Files\Intel\WiFi\bin;C:\Program Files\Common Files\Intel\WirelessCommon;E:\Applications\IntelSWTools\compilers_and_libraries_2019.0.117\windows\mkl\lib;C:\Program Files\NVIDIA Corporation\NVSMI;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn;C:\Program Files\Microsoft SQL Server\130\Tools\Binn;C:\Program Files (x86)\Microsoft SQL Server\130\DTS\Binn;C:\Program Files\Microsoft SQL Server\130\DTS\Binn;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn;C:\Program Files (x86)\Microsoft SQL Server\150\DTS\Binn;C:\Program Files\Microsoft SQL Server\120\Tools\Binn;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin;E:\Applications\nodejs;C:\Users\zeref\Downloads\Programs\opencv\build\x64\vc15\bin;E:\Applications\Anaconda3;E:\Applications\Anaconda3\Library\mingw-w64\bin;E:\Applications\Anaconda3\Library\usr\bin;E:\Applications\Anaconda3\Library\bin;E:\Applications\Anaconda3\Scripts;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;E:\Applications\IntelSWTools\compilers_and_libraries_2019.0.117\windows\mpi\intel64\bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\compiler;C:\Program Files\Microsoft MPI\Bin;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\dotnet;E:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin;E:\Program Files (x86)\IncrediBuild;C:\Program Files\Git\cmd;C:\Program Files\Java\jdk1.8.0_181\bin;C:\Program Files\Intel\WiFi\bin;C:\Program Files\Common Files\Intel\WirelessCommon;E:\Applications\IntelSWTools\compilers_and_libraries_2019.0.117\windows\mkl\lib;C:\Program Files\NVIDIA Corporation\NVSMI;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn;C:\Program Files\Microsoft SQL Server\130\Tools\Binn;C:\Program Files (x86)\Microsoft SQL Server\130\DTS\Binn;C:\Program Files\Microsoft SQL Server\130\DTS\Binn;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn;C:\Program Files (x86)\Microsoft SQL Server\150\DTS\Binn;C:\Program Files\Microsoft SQL Server\120\Tools\Binn;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin;E:\Applications\nodejs;C:\Users\zeref\AppData\Local\Microsoft\WindowsApps;C:\Users\zeref\AppData\Roaming\npm;
1> Output Property: Path=E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\bin\HostX86\x64%3bE:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\bin\HostX86\x86%3bE:\Windows Kits\10\bin\10.0.17763.0\x86%3b%3bC:\Program Files %28x86%29\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.6.1 Tools%3bE:\Applications\Microsoft Visual Studio\Common7\tools%3bE:\Applications\Microsoft Visual Studio\Common7\ide%3bC:\Program Files %28x86%29\HTML Help Workshop%3b%3bE:\Applications\Microsoft Visual Studio\MSBuild\15.0\Bin%3bC:\WINDOWS\Microsoft.NET\Framework\v4.0.30319%3b%3bE:\Applications\Anaconda3%3bE:\Applications\Anaconda3\Library\mingw-w64\bin%3bE:\Applications\Anaconda3\Library\usr\bin%3bE:\Applications\Anaconda3\Library\bin%3bE:\Applications\Anaconda3\Scripts%3bC:\Program Files %28x86%29\Common Files\Oracle\Java\javapath%3bE:\Applications\IntelSWTools\compilers_and_libraries_2019.0.117\windows\mpi\intel64\bin%3bC:\Program Files %28x86%29\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt%3bC:\Program Files %28x86%29\Common Files\Intel\Shared Libraries\redist\ia32_win\mpirt%3bC:\Program Files %28x86%29\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler%3bC:\Program Files %28x86%29\Common Files\Intel\Shared Libraries\redist\ia32_win\compiler%3bC:\Program Files\Microsoft MPI\Bin%3bC:\Program Files %28x86%29\Intel\iCLS Client%3bC:\Program Files\Intel\iCLS Client%3bC:\WINDOWS\system32%3bC:\WINDOWS%3bC:\WINDOWS\System32\Wbem%3bC:\WINDOWS\System32\WindowsPowerShell\v1.0%3bC:\WINDOWS\System32\OpenSSH%3bC:\Program Files %28x86%29\Intel\Intel%28R%29 Management Engine Components\DAL%3bC:\Program Files\Intel\Intel%28R%29 Management Engine Components\DAL%3bC:\Program Files %28x86%29\Intel\Intel%28R%29 Management Engine Components\IPT%3bC:\Program Files\Intel\Intel%28R%29 Management Engine Components\IPT%3bC:\Program Files\dotnet%3bE:\Program Files %28x86%29\Microsoft Visual Studio 14.0\VC\bin%3bE:\Program Files %28x86%29\IncrediBuild%3bC:\Program Files\Git\cmd%3bC:\Program Files\Java\jdk1.8.0_181\bin%3bC:\Program Files\Intel\WiFi\bin%3bC:\Program Files\Common Files\Intel\WirelessCommon%3bE:\Applications\IntelSWTools\compilers_and_libraries_2019.0.117\windows\mkl\lib%3bC:\Program Files\NVIDIA Corporation\NVSMI%3bC:\Program Files %28x86%29\Microsoft SQL Server\130\Tools\Binn%3bC:\Program Files\Microsoft SQL Server\130\Tools\Binn%3bC:\Program Files %28x86%29\Microsoft SQL Server\130\DTS\Binn%3bC:\Program Files\Microsoft SQL Server\130\DTS\Binn%3bC:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn%3bC:\Program Files %28x86%29\Microsoft SQL Server\150\DTS\Binn%3bC:\Program Files\Microsoft SQL Server\120\Tools\Binn%3bC:\Program Files %28x86%29\NVIDIA Corporation\PhysX\Common%3bC:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin%3bE:\Applications\nodejs%3bC:\Users\zeref\Downloads\Programs\opencv\build\x64\vc15\bin%3bE:\Applications\Anaconda3%3bE:\Applications\Anaconda3\Library\mingw-w64\bin%3bE:\Applications\Anaconda3\Library\usr\bin%3bE:\Applications\Anaconda3\Library\bin%3bE:\Applications\Anaconda3\Scripts%3bC:\Program Files %28x86%29\Common Files\Oracle\Java\javapath%3bE:\Applications\IntelSWTools\compilers_and_libraries_2019.0.117\windows\mpi\intel64\bin%3bC:\Program Files %28x86%29\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt%3bC:\Program Files %28x86%29\Common Files\Intel\Shared Libraries\redist\ia32_win\mpirt%3bC:\Program Files %28x86%29\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler%3bC:\Program Files %28x86%29\Common Files\Intel\Shared Libraries\redist\ia32_win\compiler%3bC:\Program Files\Microsoft MPI\Bin%3bC:\Program Files %28x86%29\Intel\iCLS Client%3bC:\Program Files\Intel\iCLS Client%3bC:\WINDOWS\system32%3bC:\WINDOWS%3bC:\WINDOWS\System32\Wbem%3bC:\WINDOWS\System32\WindowsPowerShell\v1.0%3bC:\WINDOWS\System32\OpenSSH%3bC:\Program Files %28x86%29\Intel\Intel%28R%29 Management Engine Components\DAL%3bC:\Program Files\Intel\Intel%28R%29 Management Engine Components\DAL%3bC:\Program Files %28x86%29\Intel\Intel%28R%29 Management Engine Components\IPT%3bC:\Program Files\Intel\Intel%28R%29 Management Engine Components\IPT%3bC:\Program Files\dotnet%3bE:\Program Files %28x86%29\Microsoft Visual Studio 14.0\VC\bin%3bE:\Program Files %28x86%29\IncrediBuild%3bC:\Program Files\Git\cmd%3bC:\Program Files\Java\jdk1.8.0_181\bin%3bC:\Program Files\Intel\WiFi\bin%3bC:\Program Files\Common Files\Intel\WirelessCommon%3bE:\Applications\IntelSWTools\compilers_and_libraries_2019.0.117\windows\mkl\lib%3bC:\Program Files\NVIDIA Corporation\NVSMI%3bC:\Program Files %28x86%29\Microsoft SQL Server\130\Tools\Binn%3bC:\Program Files\Microsoft SQL Server\130\Tools\Binn%3bC:\Program Files %28x86%29\Microsoft SQL Server\130\DTS\Binn%3bC:\Program Files\Microsoft SQL Server\130\DTS\Binn%3bC:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn%3bC:\Program Files %28x86%29\Microsoft SQL Server\150\DTS\Binn%3bC:\Program Files\Microsoft SQL Server\120\Tools\Binn%3bC:\Program Files %28x86%29\NVIDIA Corporation\PhysX\Common%3bC:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin%3bE:\Applications\nodejs%3bC:\Users\zeref\AppData\Local\Microsoft\WindowsApps%3bC:\Users\zeref\AppData\Roaming\npm%3b
1> Task “SetEnv”
1> Task Parameter:Name=LIB
1> Task Parameter:Value=E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\lib\Spectre\x64;;E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\atlmfc\lib\Spectre\x64;;E:\Applications\Microsoft Visual Studio\VC\Auxiliary\VS\lib\x64;;E:\Windows Kits\10\lib\10.0.17763.0\ucrt\x64;;;E:\Applications\Microsoft Visual Studio\VC\Auxiliary\VS\UnitTest\lib;E:\Windows Kits\10\lib\10.0.17763.0\um\x64;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\lib\um\x64;;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Lib\um\x64
1> LIB=E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\lib\Spectre\x64;;E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\atlmfc\lib\Spectre\x64;;E:\Applications\Microsoft Visual Studio\VC\Auxiliary\VS\lib\x64;;E:\Windows Kits\10\lib\10.0.17763.0\ucrt\x64;;;E:\Applications\Microsoft Visual Studio\VC\Auxiliary\VS\UnitTest\lib;E:\Windows Kits\10\lib\10.0.17763.0\um\x64;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\lib\um\x64;;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Lib\um\x64
1> Output Property: LIB=E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\lib\Spectre\x64%3b%3bE:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\atlmfc\lib\Spectre\x64%3b%3bE:\Applications\Microsoft Visual Studio\VC\Auxiliary\VS\lib\x64%3b%3bE:\Windows Kits\10\lib\10.0.17763.0\ucrt\x64%3b%3b%3bE:\Applications\Microsoft Visual Studio\VC\Auxiliary\VS\UnitTest\lib%3bE:\Windows Kits\10\lib\10.0.17763.0\um\x64%3bC:\Program Files %28x86%29\Windows Kits\NETFXSDK\4.6.1\lib\um\x64%3b%3bC:\Program Files %28x86%29\Windows Kits\NETFXSDK\4.6.1\Lib\um\x64
1> Task “SetEnv”
1> Task Parameter:Name=LIBPATH
1> Task Parameter:Value=E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\atlmfc\lib\Spectre\x64;;E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\lib\Spectre\x64;
1> LIBPATH=E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\atlmfc\lib\Spectre\x64;;E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\lib\Spectre\x64;
1> Output Property: LIBPATH=E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\atlmfc\lib\Spectre\x64%3b%3bE:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\lib\Spectre\x64%3b
1> Task “SetEnv”
1> Task Parameter:Name=INCLUDE
1> Task Parameter:Value=E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\include;;E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\atlmfc\include;;E:\Applications\Microsoft Visual Studio\VC\Auxiliary\VS\include;;E:\Windows Kits\10\Include\10.0.17763.0\ucrt;;;E:\Applications\Microsoft Visual Studio\VC\Auxiliary\VS\UnitTest\include;E:\Windows Kits\10\Include\10.0.17763.0\um;E:\Windows Kits\10\Include\10.0.17763.0\shared;E:\Windows Kits\10\Include\10.0.17763.0\winrt;E:\Windows Kits\10\Include\10.0.17763.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Include\um;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Include\um;
1> INCLUDE=E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\include;;E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\atlmfc\include;;E:\Applications\Microsoft Visual Studio\VC\Auxiliary\VS\include;;E:\Windows Kits\10\Include\10.0.17763.0\ucrt;;;E:\Applications\Microsoft Visual Studio\VC\Auxiliary\VS\UnitTest\include;E:\Windows Kits\10\Include\10.0.17763.0\um;E:\Windows Kits\10\Include\10.0.17763.0\shared;E:\Windows Kits\10\Include\10.0.17763.0\winrt;E:\Windows Kits\10\Include\10.0.17763.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Include\um;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Include\um;
1> Output Property: INCLUDE=E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\include%3b%3bE:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\atlmfc\include%3b%3bE:\Applications\Microsoft Visual Studio\VC\Auxiliary\VS\include%3b%3bE:\Windows Kits\10\Include\10.0.17763.0\ucrt%3b%3b%3bE:\Applications\Microsoft Visual Studio\VC\Auxiliary\VS\UnitTest\include%3bE:\Windows Kits\10\Include\10.0.17763.0\um%3bE:\Windows Kits\10\Include\10.0.17763.0\shared%3bE:\Windows Kits\10\Include\10.0.17763.0\winrt%3bE:\Windows Kits\10\Include\10.0.17763.0\cppwinrt%3bC:\Program Files %28x86%29\Windows Kits\NETFXSDK\4.6.1\Include\um%3bC:\Program Files %28x86%29\Windows Kits\NETFXSDK\4.6.1\Include\um%3b
1>Target “SetUserMacroEnvironmentVariables” skipped, due to false condition; (‘@(BuildMacro)’ != ‘’ and ‘$(DesignTimeBuild)’ != ‘true’) was evaluated as (‘’ != ‘’ and ‘’ != ‘true’).
1>Target GetResolvedWinMD:
1> Added Item(s):
1> Link=
1> tmp
1> AcceptableNonZeroExitCodes=
1> AdditionalDependencies=cudart.lib;kernel32.lib;user32.lib;gdi32.lib;winspool.lib;comdlg32.lib;advapi32.lib;shell32.lib;ole32.lib;oleaut32.lib;uuid.lib;odbc32.lib;odbccp32.lib;kernel32.lib;user32.lib;gdi32.lib;winspool.lib;comdlg32.lib;advapi32.lib;shell32.lib;ole32.lib;oleaut32.lib;uuid.lib;odbc32.lib;odbccp32.lib;
1> AdditionalLibraryDirectories=;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\lib\x64
1> AllowIsolation=true
1> CLRImageType=Default
1> DataExecutionPrevention=true
1> DelaySign=
1> DeleteSoon=true
1> Driver=NotSet
1> EnableUAC=true
1> GenerateDebugInformation=true
1> GenerateMapFile=false
1> IgnoreAllDefaultLibraries=false
1> IgnoreEmbeddedIDL=false
1> ImportLibrary=E:\source\practice\cuda_lab\vect_addition\x64\Debug\vect_addition.lib
1> InterproceduralOptimization=true
1> KeyFile=
1> LinkErrorReporting=PromptImmediately
1> ManifestFile=x64\Debug\vect_addition.exe.intermediate.manifest
1> MapExports=false
1> MinimalRebuildFromTracking=true
1> NoEntryPoint=false
1> OutputFile=E:\source\practice\cuda_lab\vect_addition\x64\Debug\vect_addition.exe
1> PerUserRedirection=false
1> Profile=false
1> ProfileGuidedDatabase=E:\source\practice\cuda_lab\vect_addition\x64\Debug\vect_addition.pgd
1> ProgramDatabaseFile=E:\source\practice\cuda_lab\vect_addition\x64\Debug\vect_addition.pdb
1> RandomizedBaseAddress=true
1> RegisterOutput=false
1> SetChecksum=false
1> ShowProgress=NotSet
1> SubSystem=Console
1> SupportNobindOfDelayLoadedDLL=false
1> SupportUnloadOfDelayLoadedDLL=false
1> SuppressStartupBanner=true
1> SwapRunFromCD=false
1> SwapRunFromNET=false
1> TargetMachine=MachineX64
1> TrackerLogDirectory=x64\Debug\vect_addition.tlog
1> TurnOffAssemblyGeneration=false
1> TypeLibraryResourceID=1
1> UACExecutionLevel=AsInvoker
1> UACUIAccess=false
1> WPOAssemblyOutput=NoListing
1> Removed Item(s):
1> Link=
1> tmp
1> DelaySign=
1> DeleteSoon=true
1> Driver=NotSet
1> EnableUAC=true
1> KeyFile=
1> MapExports=false
1> Profile=false
1>Target PlatformPrepareForBuild:
1> Set Property: ConfigurationPlatformExists=true
1> Set Property: _CurrentPlatformToolsetShortName=v141
1> Task “VCMessage” skipped, due to false condition; (‘$(_Error64bitToolsNotInstalled)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(_ToolsetFound)’ != ‘true’ and ‘$(PlatformToolset)’ == ‘’) was evaluated as (‘’!=‘true’ and ‘true’ != ‘true’ and ‘v141’ == ‘’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(_ToolsetFound)’ != ‘true’ and ‘$(PlatformToolset)’ == ‘v110’) was evaluated as (‘’!=‘true’ and ‘true’ != ‘true’ and ‘v141’ == ‘v110’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(_ToolsetFound)’ != ‘true’ and ‘$(PlatformToolset)’ == ‘v100’) was evaluated as (‘’!=‘true’ and ‘true’ != ‘true’ and ‘v141’ == ‘v100’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(_ToolsetFound)’ != ‘true’ and ‘$(PlatformToolset)’ == ‘v90’) was evaluated as (‘’!=‘true’ and ‘true’ != ‘true’ and ‘v141’ == ‘v90’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(_ToolsetFound)’ != ‘true’ and ‘$(PlatformToolset)’ != ‘v90’ and ‘$(PlatformToolset)’ != ‘v100’ and ‘$(PlatformToolset)’ != ‘v110’) was evaluated as (‘’!=‘true’ and ‘true’ != ‘true’ and ‘v141’ != ‘v90’ and ‘v141’ != ‘v100’ and ‘v141’ != ‘v110’).
1>Target _CheckWindowsSDKInstalled:
1> Set Property: WindowsSDKInstalled=false
1> Set Property: WindowsSDK_UAP_Support=false
1> Set Property: WindowsSDK_Desktop_Support=false
1> Set Property: WindowsSDKInstalled=true
1> Set Property: WindowsSDK_UAP_Support= true
1> Set Property: WindowsSDK_Desktop_Support=true
1> Task “VCMessage” skipped, due to false condition; (‘$(WindowsSDKInstalled)’ != ‘true’) was evaluated as (‘true’ != ‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(WindowsAppContainer)’ != ‘true’ and ‘$(WindowsSDK_Desktop_Support)’ != true) was evaluated as (‘false’ != ‘true’ and ‘true’ != true).
1>Target “GetReferenceAssemblyPaths” skipped. Previously built successfully.
1>Target “AssignLinkMetadata” skipped, due to false condition; ( ‘$(SynthesizeLinkMetadata)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1>Target SetCABuildNativeEnvironmentVariables:
1> Task “SetEnv”
1> Task Parameter:Value=E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\atlmfc\include;E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\include;E:\Windows Kits\10\Include\10.0.17763.0\ucrt;;E:\Windows Kits\10\Include\10.0.17763.0\um;E:\Windows Kits\10\Include\10.0.17763.0\shared;E:\Windows Kits\10\Include\10.0.17763.0\winrt;E:\Windows Kits\10\Include\10.0.17763.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Include\um;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Include\um;
1> Task Parameter:Name=CAExcludePath
1> CAExcludePath=E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\atlmfc\include;E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503\include;E:\Windows Kits\10\Include\10.0.17763.0\ucrt;;E:\Windows Kits\10\Include\10.0.17763.0\um;E:\Windows Kits\10\Include\10.0.17763.0\shared;E:\Windows Kits\10\Include\10.0.17763.0\winrt;E:\Windows Kits\10\Include\10.0.17763.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Include\um;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Include\um;
1>Target PrepareForBuild:
1> Set Property: TargetDir=E:\source\practice\cuda_lab\vect_addition\x64\Debug
1> Set Property: LocalDebuggerCommand=E:\source\practice\cuda_lab\vect_addition\x64\Debug\vect_addition.exe
1> Set Property: BuildProjectReferences=false
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’ != ‘true’ and ‘$(ConfigurationPlatformExists)’ != ‘true’) was evaluated as (‘’ != ‘true’ and ‘true’ != ‘true’).
1> Using “MakeDir” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “MakeDir”
1> Task Parameter:Directories=x64\Debug
1> Done executing task “MakeDir”.
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(WindowsAppContainer)’==‘true’ and ‘$(ConfigurationType)’!=‘Application’ and ‘$(ConfigurationType)’!=‘DynamicLibrary’ and ‘$(ConfigurationType)’!=‘StaticLibrary’) was evaluated as (‘’!=‘true’ and ‘false’==‘true’ and ‘Application’!=‘Application’ and ‘Application’!=‘DynamicLibrary’ and ‘Application’!=‘StaticLibrary’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(VCToolsInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’ and (‘$(TargetFrameworkVersion)’==‘v3.5’ or ‘$(TargetFrameworkVersion)’==‘v3.0’ or ‘$(TargetFrameworkVersion)’==‘v2.0’ )) was evaluated as (‘’!=‘true’ and ‘E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503'==’’ and ‘’ != ‘true’ and (‘v4.0’==‘v3.5’ or ‘v4.0’==‘v3.0’ or ‘v4.0’==‘v2.0’ )).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(VCToolsInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’ and ‘$(PlatformToolset)’==‘v90’) was evaluated as (‘’!=‘true’ and ‘E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503'==’’ and ‘’ != ‘true’ and ‘v141’==‘v90’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(VCToolsInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’) was evaluated as (‘’!=‘true’ and ‘E:\Applications\Microsoft Visual Studio\VC\Tools\MSVC\14.11.25503'==’’ and ‘’ != ‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(WindowsSDKDir)’==‘’ and ‘$(UseEnv)’ != ‘true’) was evaluated as (‘’!=‘true’ and ‘E:\Windows Kits\10'==’’ and ‘’ != ‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(IntDirTrailingSlashWarning)’==‘true’) was evaluated as (‘’!=‘true’ and ‘’==‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(OutDirTrailingSlashWarning)’==‘true’) was evaluated as (‘’!=‘true’ and ‘’==‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘%(CompatibilityIssues.Identity)’ != ‘’ and ‘$(DesignTimeBuild)’!=‘true’) was evaluated as (‘’ != ‘’ and ‘’!=‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(IgnoreWarnIntDirSharingDetected)’ != ‘true’ and ‘$(IntDirSharingDetected)’ == ‘true’) was evaluated as (‘’ != ‘true’ and ‘’ == ‘true’).
1> Set Property: _IntDirFullpath=E:\source\practice\cuda_lab\vect_addition\vect_addition\x64\Debug
1> Set Property: _OutDirFullpath=E:\source\practice\cuda_lab\vect_addition\x64\Debug
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(IgnoreWarnIntDirInTempDetected)’ != ‘true’ and (‘$(_IntDirFullpath.StartsWith($(Tmp), true, null))’ == ‘true’ or ‘$(_IntDirFullpath.StartsWith($(Temp), true, null))’ == ‘true’ or ‘$(_OutDirFullpath.StartsWith($(Tmp), true, null))’ == ‘true’ or ‘$(_OutDirFullpath.StartsWith($(Temp), true, null))’ == ‘true’)) was evaluated as (‘’!=‘true’ and ‘’ != ‘true’ and (‘False’ == ‘true’ or ‘False’ == ‘true’ or ‘False’ == ‘true’ or ‘False’ == ‘true’)).
1> Using “VCMessage” task from assembly “E:\Applications\Microsoft Visual Studio\Common7\IDE\VC\VCTargets\Microsoft.Build.CppTasks.Common.dll”.
1> Task “VCMessage”
1> Task Parameter:Code=MSB8040
1> Task Parameter:Type=Warning
1> E:\Applications\Microsoft Visual Studio\Common7\IDE\VC\VCTargets\Microsoft.CppBuild.targets(402,5): warning MSB8038: Spectre mitigation is enabled but Spectre mitigated libraries are not found. Verify that the Visual Studio Workload includes the Spectre mitigated libraries. See /Qspectre | Microsoft Docs for more information.
1> Done executing task “VCMessage”.
1> Task “MakeDir”
1> Task Parameter:
1> Directories=
1> x64\Debug
1> E:\source\practice\cuda_lab\vect_addition\x64\Debug
1> x64\Debug\vect_addition.tlog
1>Done building target “PrepareForBuild” in project “vect_addition.vcxproj”.
1>Target “ComputeCrtSDKReference” skipped, due to false condition; (‘@(ClCompile)’!=‘’ and ‘$(WindowsAppContainer)’==‘true’ and ‘$(UseCrtSDKReference)’ != ‘false’) was evaluated as (‘’!=‘’ and ‘false’==‘true’ and ‘’ != ‘false’).
1>Target “GetInstalledSDKLocations” skipped, due to false condition; (‘@(SDKReference)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target ResolveSDKReferences:
1> Task “ResolveSDKReference” skipped, due to false condition; (‘@(SDKReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Target “ResolveSDKReferences” skipped. Previously built successfully.
1>Target ExpandSDKReferences:
1> Task “GetSDKReferenceFiles” skipped, due to false condition; (‘@(ResolvedSDKReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Target “ResolveNuGetPackageAssets” skipped, due to false condition; (‘$(ResolveNuGetPackages)’ == ‘true’ and exists(‘$(ProjectLockFile)’)) was evaluated as (‘true’ == ‘true’ and exists(‘obj\project.assets.json’)).
1>Target “FakesGenerateBeforeBuild” skipped, due to false condition; (@(Fakes) != ‘’ AND $(BuildingProject)) was evaluated as ( != ‘’ AND true).
1>Target “ImplicitlyExpandNETStandardFacades” skipped, due to false condition; (‘$(ImplicitlyExpandNETStandardFacades)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1>Target _HandlePackageFileConflicts:
1> Using “ResolvePackageFileConflicts” task from assembly “E:\Applications\Microsoft Visual Studio\MSBuild\Microsoft\Microsoft.NET.Build.Extensions\tools\net46\Microsoft.NET.Build.Extensions.Tasks.dll”.
1> Task “ResolvePackageFileConflicts”
1> Task Parameter:
1> TargetFrameworkDirectories=
1> C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.0
1> E:\Windows Kits\10\References
1> Task Parameter:
1> PackageOverrides=
1> Microsoft.NETCore.App
1> OverriddenPackages=
1> Microsoft.CSharp|4.4.0;
1> Microsoft.Win32.Primitives|4.3.0;
1> Microsoft.Win32.Registry|4.4.0;
1> runtime.debian.8-x64.runtime.native.System.Security.Cryptography.OpenSsl|4.3.0;
1> runtime.fedora.23-x64.runtime.native.System.Security.Cryptography.OpenSsl|4.3.0;
1> runtime.fedora.24-x64.runtime.native.System.Security.Cryptography.OpenSsl|4.3.0;
1> runtime.opensuse.13.2-x64.runtime.native.System.Security.Cryptography.OpenSsl|4.3.0;
1> runtime.opensuse.42.1-x64.runtime.native.System.Security.Cryptography.OpenSsl|4.3.0;
1> runtime.osx.10.10-x64.runtime.native.System.Security.Cryptography.Apple|4.3.0;
1> runtime.osx.10.10-x64.runtime.native.System.Security.Cryptography.OpenSsl|4.3.0;
1> runtime.rhel.7-x64.runtime.native.System.Security.Cryptography.OpenSsl|4.3.0;
1> runtime.ubuntu.14.04-x64.runtime.native.System.Security.Cryptography.OpenSsl|4.3.0;
1> runtime.ubuntu.16.04-x64.runtime.native.System.Security.Cryptography.OpenSsl|4.3.0;
1> runtime.ubuntu.16.10-x64.runtime.native.System.Security.Cryptography.OpenSsl|4.3.0;
1> System.AppContext|4.3.0;
1> System.Buffers|4.4.0;
1> System.Collections|4.3.0;
1> System.Collections.Concurrent|4.3.0;
1> System.Collections.Immutable|1.4.0;
1> System.Collections.NonGeneric|4.3.0;
1> System.Collections.Specialized|4.3.0;
1> System.ComponentModel|4.3.0;
1> System.ComponentModel.EventBasedAsync|4.3.0;
1> System.ComponentModel.Primitives|4.3.0;
1> System.ComponentModel.TypeConverter|4.3.0;
1> System.Console|4.3.0;
1> System.Data.Common|4.3.0;
1> System.Diagnostics.Contracts|4.3.0;
1> System.Diagnostics.Debug|4.3.0;
1> System.Diagnostics.DiagnosticSource|4.4.0;
1> System.Diagnostics.FileVersionInfo|4.3.0;
1> System.Diagnostics.Process|4.3.0;
1> System.Diagnostics.StackTrace|4.3.0;
1> System.Diagnostics.TextWriterTraceListener|4.3.0;
1> System.Diagnostics.Tools|4.3.0;
1> System.Diagnostics.TraceSource|4.3.0;
1> System.Diagnostics.Tracing|4.3.0;
1> System.Dynamic.Runtime|4.3.0;
1> System.Globalization|4.3.0;
1> System.Globalization.Calendars|4.3.0;
1> System.Globalization.Extensions|4.3.0;
1> System.IO|4.3.0;
1> System.IO.Compression|4.3.0;
1> System.IO.Compression.ZipFile|4.3.0;
1> System.IO.FileSystem|4.3.0;
1> System.IO.FileSystem.AccessControl|4.4.0;
1> System.IO.FileSystem.DriveInfo|4.3.0;
1> System.IO.FileSystem.Primitives|4.3.0;
1> System.IO.FileSystem.Watcher|4.3.0;
1> System.IO.IsolatedStorage|4.3.0;
1> System.IO.MemoryMappedFiles|4.3.0;
1> System.IO.Pipes|4.3.0;
1> System.IO.UnmanagedMemoryStream|4.3.0;
1> System.Linq|4.3.0;
1> System.Linq.Expressions|4.3.0;
1> System.Linq.Queryable|4.3.0;
1> System.Net.Http|4.3.0;
1> System.Net.NameResolution|4.3.0;
1> System.Net.Primitives|4.3.0;
1> System.Net.Requests|4.3.0;
1> System.Net.Security|4.3.0;
1> System.Net.Sockets|4.3.0;
1> System.Net.WebHeaderCollection|4.3.0;
1> System.ObjectModel|4.3.0;
1> System.Private.DataContractSerialization|4.3.0;
1> System.Reflection|4.3.0;
1> System.Reflection.Emit|4.3.0;
1> System.Reflection.Emit.ILGeneration|4.3.0;
1> System.Reflection.Emit.Lightweight|4.3.0;
1> System.Reflection.Extensions|4.3.0;
1> System.Reflection.Metadata|1.5.0;
1> System.Reflection.Primitives|4.3.0;
1> System.Reflection.TypeExtensions|4.3.0;
1> System.Resources.ResourceManager|4.3.0;
1> System.Runtime|4.3.0;
1> System.Runtime.Extensions|4.3.0;
1> System.Runtime.Handles|4.3.0;
1> System.Runtime.InteropServices|4.3.0;
1> System.Runtime.InteropServices.RuntimeInformation|4.3.0;
1> System.Runtime.Loader|4.3.0;
1> System.Runtime.Numerics|4.3.0;
1> System.Runtime.Serialization.Formatters|4.3.0;
1> System.Runtime.Serialization.Json|4.3.0;
1> System.Runtime.Serialization.Primitives|4.3.0;
1> System.Security.AccessControl|4.4.0;
1> System.Security.Claims|4.3.0;
1> System.Security.Cryptography.Algorithms|4.3.0;
1> System.Security.Cryptography.Cng|4.4.0;
1> System.Security.Cryptography.Csp|4.3.0;
1> System.Security.Cryptography.Encoding|4.3.0;
1> System.Security.Cryptography.OpenSsl|4.4.0;
1> System.Security.Cryptography.Primitives|4.3.0;
1> System.Security.Cryptography.X509Certificates|4.3.0;
1> System.Security.Cryptography.Xml|4.4.0;
1> System.Security.Principal|4.3.0;
1> System.Security.Principal.Windows|4.4.0;
1> System.Text.Encoding|4.3.0;
1> System.Text.Encoding.Extensions|4.3.0;
1> System.Text.RegularExpressions|4.3.0;
1> System.Threading|4.3.0;
1> System.Threading.Overlapped|4.3.0;
1> System.Threading.Tasks|4.3.0;
1> System.Threading.Tasks.Extensions|4.3.0;
1> System.Threading.Tasks.Parallel|4.3.0;
1> System.Threading.Thread|4.3.0;
1> System.Threading.ThreadPool|4.3.0;
1> System.Threading.Timer|4.3.0;
1> System.ValueTuple|4.3.0;
1> System.Xml.ReaderWriter|4.3.0;
1> System.Xml.XDocument|4.3.0;
1> System.Xml.XmlDocument|4.3.0;
1> System.Xml.XmlSerializer|4.3.0;
1> System.Xml.XPath|4.3.0;
1> System.Xml.XPath.XDocument|4.3.0;
1>
1> NETStandard.Library
1> System.IO|4.3.0;
1> Output Item(s): _ReferenceCopyLocalPathsWithoutConflicts=
1> Done executing task “ResolvePackageFileConflicts”.
1>Target ResolveAssemblyReferences:
1> Added Item(s):
1> _ReferenceInstalledAssemblyDirectory=
1> Set Property: ResolveAssemblyReferencesStateFile=x64\Debug\vect_addition.vcxprojAssemblyReference.cache
1> Set Property: ResolveAssemblyReferencesSilent=false
1> Set Property: ResolveAssemblyWarnOrErrorOnTargetArchitectureMismatch=Warning
1> Set Property: FindDependenciesOfExternallyResolvedReferences=false
1> Task “ResolveAssemblyReference” skipped, due to false condition; (‘@(Reference)’!=‘’ or ‘@(_ResolvedProjectReferencePaths)’!=‘’ or ‘@(_ExplicitReference)’ != ‘’) was evaluated as (‘’!=‘’ or ‘’!=‘’ or ‘’ != ‘’).
1>Target “GenerateBindingRedirects” skipped, due to false condition; (‘$(AutoGenerateBindingRedirects)’ == ‘true’ and ‘$(GenerateBindingRedirectsOutputType)’ == ‘true’) was evaluated as (‘’ == ‘true’ and ‘true’ == ‘true’).
1>Target “_RemoveZipFileSuggestedRedirect” skipped, due to false condition; (‘$(_TargetFrameworkVersionWithoutV)’ >= ‘4.7.1’ And ‘$(AllowZipFileRedirect)’ != ‘true’) was evaluated as (‘4.0’ >= ‘4.7.1’ And ‘’ != ‘true’).
1>Target “GenerateBindingRedirectsUpdateAppConfig” skipped, due to false condition; (‘$(AutoGenerateBindingRedirects)’ == ‘true’ and ‘$(GenerateBindingRedirectsOutputType)’ == ‘true’ and Exists(‘$(_GenerateBindingRedirectsIntermediateAppConfig)’)) was evaluated as (‘’ == ‘true’ and ‘true’ == ‘true’ and Exists(‘x64\Debug\vect_addition.exe.config’)).
1>Target “ResolveComReferences” skipped, due to false condition; (‘@(COMReference)’!=‘’ or ‘@(COMFileReference)’!=‘’) was evaluated as (‘’!=‘’ or ‘’!=‘’).
1>Target AfterResolveReferences:
1>Target “ImplicitlyExpandDesignTimeFacades” skipped, due to false condition; (‘$(ImplicitlyExpandDesignTimeFacades)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1>Target “ResolveTestReferences” skipped, due to false condition; (‘@(Shadow)’!=‘’) was evaluated as (‘’!=‘’).
1>Target ResolveReferences:
1>Target “PrepareForBuild” skipped. Previously built successfully.
1>Target InitializeBuildStatus:
1> Using “ReadLinesFromFile” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “ReadLinesFromFile”
1> Task Parameter:File=x64\Debug\vect_addition.tlog\vect_addition.lastbuildstate
1> Output Item(s):
1> _ReadProjectStateLine=
1> #TargetFrameworkVersion=v4.0:PlatformToolSet=v141:EnableManagedIncrementalBuild=false:VCToolArchitecture=Native32Bit:WindowsTargetPlatformVersion=10.0.17763.0
1> Debug|x64|E:\source\practice\cuda_lab\vect_addition|
1> Done executing task &quo
