OS: Kubuntu 22.04 LTS x86_64
Host: Asus TUF f15 FX506LH
Kernel: 5.17.5-76051705-generic
GPUs: Intel CometLake-H GT2 and nvidia gtx 1650
problem: System doesn’t properly see nvidia GPU, neofetch displays the GPU as “NVIDIA 01:00.0”, both steam and standalone games don’t use nvidia. Im using driver (510.73.05], on 470 it didn’t work either. I tried using older kernel but it also didn’t work.
Here is nvidia-smi output:
| NVIDIA-SMI 510.73.05 Driver Version: 510.73.05 CUDA Version: 11.6 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 Off | N/A |
| N/A 41C P8 1W / N/A | 5MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 5343 G /usr/lib/xorg/Xorg 4MiB |
here is nvidia-settings output:
(nvidia-settings:9909): GLib-GObject-CRITICAL **: 21:48:14.103: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 21:48:14.173: PRIME: Requires offloading
** Message: 21:48:14.173: PRIME: is it supported? yes
** Message: 21:48:14.203: PRIME: Usage: /usr/bin/prime-select nvidia|intel|on-demand|query
** Message: 21:48:14.203: PRIME: on-demand mode: "1"
** Message: 21:48:14.203: PRIME: is "on-demand" mode supported? yes
I’ll paste nvidia bug report in the comment.
I checked a ton of forum posts. non seem to describe a similar problem nor do they provide any solutions that would help me.
