My laptop has GP108M [GeForce MX150] card. It is on dual boot with windows 10 and ubuntu 19.04. The problem is in ubuntu where despite the driver installed, the system is not using the graphics card. Running “nvidia-settings” gives the following output.
ERROR: Unable to load info from any available system
(nvidia-settings:5808): GLib-GObject-CRITICAL **: 18:33:32.098: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 18:33:32.103: PRIME: Requires offloading
** Message: 18:33:32.103: PRIME: is it supported? yes
and opens windows where i can only select which card to use.
The nvidia-bug-report.log.gz has the following content
____________________________________________
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to 'linux-bugs@nvidia.com'.
nvidia-bug-report.sh Version: 26499344
Date: Mon Jun 17 14:03:58 IST 2019
uname: Linux kunal-X510UNR 5.0.0-15-generic #16-Ubuntu SMP Mon May 6 17:41:33 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r--r-- 1 root root 20 2019-04-16 13:06:43.000000000 +0530 /etc/issue
Ubuntu 19.04 \n \l
*** /etc/debian_version
*** ls: -rw-r--r-- 1 root root 11 2018-08-07 04:05:13.000000000 +0530 /etc/debian_version
buster/sid
*** /var/log/nvidia-installer.log does not exist
*** /var/lib/dkms/nvidia/430.26/5.0.0-15-generic/x86_64/log/make.log
*** ls: -rw-r--r-- 1 root root 404923 2019-06-17 13:35:37.390494052 +0530 /var/lib/dkms/nvidia/430.26/5.0.0-15-generic/x86_64/log/make.log
DKMS make.log for nvidia-430.26 for kernel 5.0.0-15-generic (x86_64)
Mon Jun 17 13:35:05 IST 2019
make[1]: Entering directory '/usr/src/linux-headers-5.0.0-15-generic'
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \
echo >&2; \
echo >&2 " ERROR: Kernel configuration is invalid."; \
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.";\
echo >&2 " Run 'make oldconfig && make prepare' on kernel src to fix it."; \
echo >&2 ; \
/bin/false)
mkdir -p /var/lib/dkms/nvidia/430.26/build/.tmp_versions ; rm -f /var/lib/dkms/nvidia/430.26/build/.tmp_versions/*
make -f ./scripts/Makefile.build obj=/var/lib/dkms/nvidia/430.26/build
ln -sf /var/lib/dkms/nvidia/430.26/build/nvidia/nv-kernel.o_binary /var/lib/dkms/nvidia/430.26/build/nvidia/nv-kernel.o
ln -sf /var/lib/dkms/nvidia/430.26/build/nvidia-modeset/nv-modeset-kernel.o_binary /var/lib/dkms/nvidia/430.26/build/nvidia-modeset/nv-modeset-kernel.o
(cat /dev/null; echo kernel//var/lib/dkms/nvidia/430.26/build/nvidia.ko; echo kernel//var/lib/dkms/nvidia/430.26/build/nvidia-uvm.ko; echo kernel//var/lib/dkms/nvidia/430.26/build/nvidia-modeset.ko; echo kernel//var/lib/dkms/nvidia/430.26/build/nvidia-drm.ko;) > /var/lib/dkms/nvidia/430.26/build/modules.order
CONFTEST: INIT_WORK
CONFTEST: hash__remap_4k_pfn
CONFTEST: set_pages_uc
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: sg_alloc_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: register_acpi_notifier
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: do_gettimeofday
CONFTEST: kernel_read
CONFTEST: kernel_write
CONFTEST: dma_direct_map_resource
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: vmf_insert_pfn
CONFTEST: drm_framebuffer_get
CONFTEST: drm_gem_object_get
CONFTEST: drm_dev_put
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: scatterlist
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: file_inode
CONFTEST: task_struct
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_present
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: vm_insert_pfn_prot
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: vmbus_channel_has_ringbuffer_page
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: node_states_n_memory
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: kref_has_refcount_of_type_refcount_t
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_hyperv_available
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: pm_runtime_available
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
