Hi, i am having problems to use the GPU NVIDIA GeForce 920M on Ubuntu 20.04.
I installed the drivers, but nvidia-settings gave the following:
ERROR: Unable to load info from any available system
(nvidia-settings:7748): GLib-GObject-CRITICAL **: 01:13:16.956: g_o
** Message: 01:13:16.960: PRIME: Requires offloading
** Message: 01:13:16.960: PRIME: is it supported? yes
** Message: 01:13:16.999: PRIME: Usage: /usr/bin/prime-select nvidi
** Message: 01:13:16.999: PRIME: on-demand mode: “1”
** Message: 01:13:16.999: PRIME: is “on-demand” mode supported? yes
while opening a window to select the prime profile; on the other part the
correct profile looks already selected, using the command sudo prime-select nvidia:
Info: the nvidia profile is already set
Anyway no process is using the GPU, nvidia-smi gives:
| NVIDIA-SMI 465.19.01 Driver Version: 465.19.01 CUDA Version: 11.3 |
| | | MIG M. |
| 0 NVIDIA GeForce … On | 00000000:04:00.0 N/A | N/A |
| N/A 38C P8 N/A / N/A | 0MiB / 2004MiB | N/A Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Running nvidia-bug-report.sh points this error:
nvidia-bug-report.log (1.8 MB)
(I coudln’t load log.gz version for some reason)
DKMS make.log for nvidia-465.19.01 for kernel 5.4.0-73-generic (x86_64)
ven 14 mag 2021, 21:43:56, CEST
make[1]: ingresso nella directory «/usr/src/linux-headers-5.4.0-73-generic»
test -e include/generated/autoconf.h -a -e include/config/auto.conf || (
echo >&2;
echo >&2 " ERROR: Kernel configuration is invalid.“;
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.”;
echo >&2 " Run ‘make oldconfig && make prepare’ on kernel src to fix it.";
echo >&2 ; \
What i tried so far:
follow entirely this guide CUDA Installation Guide for Linux
I had to solve a chain of dependency that made me install nvidia-driver-465 from 460, that should be installed,cat /proc/driver/nvidia/version:NVRM version: NVIDIA UNIX x86_64 Kernel Module 465.19.01 Fri Mar 19 07:44:41 UTC 2021
GCC version: gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04) -
remove the file /lib/modprobe.d/blacklist-nvidia.conf
followed bysudo update-initramfs -u -
remove the file /usr/share/X11/xorg.conf.d/20-intel.conf
check
dkms status:nvidia, 465.19.01, 5.4.0-73-generic, x86_64: installed
virtualbox, 6.1.10, 5.4.0-72-generic, x86_64: installed
virtualbox, 6.1.10, 5.4.0-73-generic, x86_64: installed -
install and switch to gdmlight from gdm3
check other errors in the forum, assuring that secure boot is disabled,
xorg logs are included in the bug script -
check requirements from /usr/share/doc/nvidia-driver-465/html/minimumrequirements.html, which are satisfied
I tried to follow the guidelines from »»»»»»»»»» If you have a problem, PLEASE read this first ««««««««««, but let me know if you need additional informations or want the output of some command.
At this point i lost hope, but thank you in advance for your help.
