Hi, I am attempting to flash an AGX Xavier via Jetpack 5.1.2. When I run the flash.sh script, the system.img is not being created, and as a result I cant flash an image to the AGX Xavier. Is there a way to generate this file from somewhere else? Why would this file not be generated automatically?
You could try to share out how you ran your flash.sh and what error you saw there.
I am doing flash everyday but I didnât hit such issue at all.
Your question only happened to yourself. Nobody knows what is going on your side without log.
I guess your BSP is probably has missing package or even your flash command is totally wrong.
Here is the log for the flash.sh script:
Flash_Log.txt (16.1 KB)
I ran the flash.sh command as follows:
sudo ./flash.sh --no-flash jetson-agx-xavier-devkit mmcblk0p1
The log says âSkip generating system.imgâ. However, I have no idea why this would happen, as I did not use the -r flag with the flash.sh script.
I have Jetpack 4.6, and Jetpack 5.1 source files both on the same host as well, and both of them work fine (I only face this issue in Jetpack 5.1.2). I tried re-installing the Jetpack 5.1.2 source files, but the issue persists even after re-installing the source files.
looks like just because you run the command with --no-flash?
@WayneWWW , I edited my previous message. Kindly see the updated comment.
The issue occurs even when --no-flash flag is not used. (My understanding is that no-flash does everything except flash the actual image, so it should be creating a system.img. I have used this before, and it does actually create a system.img file).
Again, do you have any log here to show what you just told? We really donât need such simple comment. We need the log.
@WayneWWW , here is the log when --no-flash flag is not used.
Flash_Log2.txt (68.8 KB)
Apologies for not sharing this log earlier. Both logs show the line âSkip generating system.imgâ, which indicates that a new system.img file is not created. Additionally, the log without the --no-flash flag (Flash_Log2.txt) gives an error at the end âFile to be written cannot be of zero size, pFileName=system.imgâ because the system.img file does not exist (because it wasnt created in the first place).
Could you check what is the result of variable â${skip_systemimg}â when running flash.sh?
@WayneWWW , This variable seems to be empty. I ran the following command to check the value of this variable before and after executing the flash.sh script:
echo â${skip_systemimg}â
The output is an empty line in both cases.
Where does this variable get its initial value? I donât see this variable getting assigned anything in the flash.sh script itself.
Could you check why the flash script (flash.sh) goes into this condition on your side?
I mean make sure the skip generating system.img is from this code first.
3820 # At this stage, the kernel dtb in $BL_DIR folder has the "bootargs=" added,
3821 # it can be saved to rootfs.
3822 #
3823 if [ "${reuse_systemimg}" = "true" ] || [ "${skip_systemimg}" = "true" ]; then
3824 if [ ${disk_enc_enable} -eq 0 ]; then
3825 APP_TAG+="-e s/APPFILE/${localsysfile}/ ";
3826 fi;
3827 if [ "${skip_systemimg}" != "true" ]; then
3828 sysfile_exist
3829 else
3830 if [ ${disk_enc_enable} -eq 0 ]; then
3831 echo "Skip generating ${localsysfile}";
3832 else
3833 echo "Skip generating ${localsysbootfile} & ${localsysencrootfile}";
3834 fi;
3835 fi;
Hi @WayneWWW , I added three âechoâ statements to the lines you mentioned in the flash.sh script. These are shown below:
echo "CUSTOM LOG: THE VALUE OF SKIP_SYSTEMIMG VARAIBLE: ${skip_systemimg}"
echo "CUSTOM LOG: THE VALUE OF REUSE SYSTEM IMAGE VARIABLE: ${reuse_systemimg}"
fi;
sysfile_exist
else
echo "CUSTOM LOG: FLASH SCRIPT ENTERS HERE!"
else
fi;
fi;
Then I ran the flash.sh script again as follows:
sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1
I see the following on the log:
kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
CUSTOM LOG: THE VALUE OF SKIP_SYSTEMIMG VARAIBLE: true
Not signing of kernel-dtb
The full flash log is attached.
Flash_Log3.txt (69.3 KB)
The modified flash script is also attached (I uploaded it as a text file as the forum doesnt allow me to attach .sh extension files because they are unsupported file extensions for attachment)
flash script.txt (140.0 KB)
So could you trace down why that variable is set to âtrueâ in your case?
Looks like that is why system image didnât get generated.
I couldnât find any instance in the flash.sh script where this variable is assigned any value. So I am not sure where the value of âtrueâ comes from. Is there anywhere else these variables are set?
I think something else should be clarified first
Is this issue really reproducible on each BSP you use on your side? For example, if you download another package by sdkmanager, will that package also hit this issue?
Does this issue always reproduce with your jeptack5.1.2 for every host PC you could try there? For example, also use jetpack5.1.2 on another PC, will it hit same problem as well?
Does this issue also reproduce on this PC if you use some latest BSP (e.g. jp5.1.4)?
I really donât think this issue could be easily reproduced on a arbitrary PC, so above could be consider tested first.
As for the flash script checking part,
Only these two condition will set skip_systemimg=âtrueâ;
# check cases where system.img is not needed
if [ ${bup_blob} -eq 1 ] || [ ${rcm_boot} -eq 1 ] \
|| [ "${no_rootfs}" -eq 1 ] \
|| [ "${no_systemimg}" -eq 1 ] \
|| [ "${read_part_name}" != "" ]; then
skip_systemimg="true";
fi;
# APP partition does not exist
if ! partition_exists_in_PT_table "APP" "${cfgfile}"; then
fi;
As you told this variable is unset in the beginning, it sounds only these two conditions might be related. Please check if it got entered.
Hi.
Regarding your queries, this issue occurs on a specific PC only with release 35.4.1 only. Downloading other releases on the same PC works just fine. I tried deleting everything for 35.4.1 on this PC and download the source files for this version again, but I ran into the same issue.
I understand that this issue is not reproducible on just any PC. Itâs most likely an issue in my host PC. However, since this is a server PC, I need to figure out the issue and resolve it. I canât just use another PC.
The two instances you mentioned where the âskip_systemimgâ variable is being assigned true are worth investigating further (I must have missed these when searching in the script earlier). Unfortunately I lost access to the Xavier and the server PC. Will investigate these two instances further as soon as I get the access back.
Just a reminder. You got a typo there. It is 35.4.1 but not 32.4.1.
Apologies. You are right. Its 35.4.1. Corrected it now.
Is this host PC using ubuntu 18.04/20.04?
The host PC is 18.04 ubuntu
