System throttled due to overcurrent and shutdown
Hello friends,
My jetson nano kit is shutting down all the time.
The board’s power supply is adjustable at 5V2 and has a capacity of up to 3.2A. The board is not heating up because it has coolers to dissipate the heat (pictures attached).
The temperature of the jetson nano kit is low according to “run tegrastats”.
RAM 1595/3963MB (lfb 286x4MB) SWAP 0/1981MB (cached 0MB) IRAM 0/252kB(lfb 252kB) CPU [15%@204,16%@204,19%@204,18%@204] EMC_FREQ 1%@1600 GR3D_FREQ 0%@153 APE 25 PLL@28C CPU@29C PMIC@50C GPU@28.5C AO@35.5C thermal@28.5C POM_5V_IN 1934/1934 POM_5V_GPU 78/78 POM_5V_CPU 157/157
The power of kit is set to MAX.
And yet the kit is shutting down all the time.
This is my setup
Can someone help me please??
use a powered USB hub
Thanks for message @mhd0425
What’s the problem with the power supply through the jack connector?
The jack can source up to 4amps. Maybe connect directly instead of through your switch, or you can power via J41 header for up to 5amps
But it is most likey your USB. There is a pin connected to detect over current
But the app I want to run doesn’t even need 2A.
I believe it is not a problem to feed the kit through the jack connector.
Do you have any other suggestions please?
Max needs 10W. on top of that you have many usb peripherals which need more power. I don’t know how you determined it only needs 2A. The RTS5411S or TPS259530DSG has overcurrent pins connected to the Jetson… not really sure how it works
I have a regulated DC power supply that shows current average consume and the never reached 2A.
Try a different power supply
you can read more about it here:
