We are developing a T4000 carrier board but encountering a no-display issue via HDMI on boot. We cannot check the boot log because no UART pins are exposed on our board.
Could you please advise on the following:
- Are there any alternative ways to debug the boot sequence?
- Could you share the T4000 UART pin definitions so we can rework the board(pcba component not moudle pin out) to access the logs?
The Thor module’s debug signals are UART3_TX_DEBUG and UART3_RX_DEBUG, mapped internally to SoC UART0. The design guide lists the debug interface as 1.8 V, so use an adapter or
level shifter compatible with that voltage. Connect module TX to adapter RX, module RX to adapter TX, and a common ground. Thor design guide, UART and debug sections (https://
developer.nvidia.com/downloads/assets/embedded/secure/jetson/thor/docs/jetson_thor_series_modules_designguide.pdf)
Once the UART connection is available, capture logs from power-on using the matching BSP’s demuxer:
cd Linux_for_Tegra/tools/demuxer
mkdir -p /tmp/thor_logs
./nv_tcu_demuxer -m T264 -d /dev/ttyUSB0
-r 115200 -s /tmp/thor_logs -t
Replace /dev/ttyUSB0 with the actual adapter device. Thor UART documentation (https://docs.nvidia.com/jetson/archives/r39.2.1/DeveloperGuide/AT/JetsonLinuxDevelopmentTools/
TegraCombinedUART.html)
