I need to connect TC358748XBG and GS2961A.
GS2961A datasheet tells that when you use it in 10 bit mode, you need to make parallel output 0 to 9 forced to ground. Hence outputs 10 to 19 are used.
TC358748XBG datasheet does not tell anything about this issue.
My question is: Which parallel inputs of TC358748XBG should be connected to GS2961A? Are these also from 10 to 19? or from 0 to 9?
