Tegra_defconfig not found
I’m trying to rebuild the kernel as documented here. with the command make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig -j32
it seems that tegra_defconfig has been renamed or moved.
ls arch/arm64/configs/
defconfig                          tegra13_defconfig                  tegra21_defconfig                  tegra_t210ref_gnu_linux_defconfig
tegra13_android_defconfig          tegra21_android_defconfig          tegra_exuma_sim_android_defconfig
I downloaded the L4T Kernel Sources from here.
What is the replacement for the tegra_defconfig if I were to purchase a “NVIDIA Jetson Nano Developer Kit - Rev 2”?
hello JacobH,
I can see tegra_defconfig from r32.6.1 kernel sources.
for example,
$L4T_Sources/r32.6.1/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/configs/tegra_defconfig
could you please access https://developer.nvidia.com/embedded/linux-tegra and re-download the [L4T Driver Package (BSP) Sources] for confirmation,
thanks
I did correctly find tegra_defconfig in several releases. Which exact release did you download? If I have that, then I can try to mirror downloading that release and look for the tegra_defconfig.
I do have to say that your procedure looks correct, but since the sources I’m looking at have the file, then I wonder if there is something about your kernel source itself which is incomplete.
I can confirm the same. Maybe I got an old build somehow.
Thanks!!!
