Yugui
May 8, 2017, 3:24am
1
I followed steps in file “tegra_multimedia_api/README” to try to make video encode, and get below errors:
ubuntu@tegra-ubuntu:~/tegra_multimedia_api/samples/01_video_encode$ make
g++ -o video_encode video_encode_csvparser.o video_encode_main.o …/common/classes/NvElementProfiler.o …/common/classes/NvElement.o …/common/classes/NvApplicationProfiler.o …/common/classes/NvVideoDecoder.o …/common/classes/NvJpegEncoder.o …/common/classes/NvVideoConverter.o …/common/classes/NvBuffer.o …/common/classes/NvLogging.o …/common/classes/NvEglRenderer.o …/common/classes/NvUtils.o …/common/classes/NvJpegDecoder.o …/common/classes/NvVideoEncoder.o …/common/classes/NvV4l2ElementPlane.o …/common/classes/NvV4l2Element.o -I"/usr/include/aarch64-linux-gnu" -I"…/…/include" -L"/usr/lib/aarch64-linux-gnu" -L"/usr/lib/aarch64-linux-gnu/tegra" -lpthread -lv4l2 -lEGL -lGLESv2 -lX11 -lnvbuf_utils -lnvjpeg
/usr/bin/ld: cannot find -lnvbuf_utils
/usr/bin/ld: cannot find -lnvjpeg
collect2: error: ld returned 1 exit status
Makefile:58: recipe for target ‘video_encode’ failed
make: *** [video_encode] Error 1
I searched libnvbuf_utils and libnvjpeg in TX2, but didn’t find them, could you tell me how to make video encode correctly. Thanks.
Yugui
May 8, 2017, 3:54am
3
Hi Andrey1984,
Can you help to point where libnvbuf_utils.so.1.0 is? We could not find it in TX2.
nvidia@tegra-ubuntu:~$ locate libnvbuf_utils
/usr/lib/aarch64-linux-gnu/tegra/libnvbuf_utils.so
/usr/lib/aarch64-linux-gnu/tegra/libnvbuf_utils.so.1.0.0
please install mlocate : sudo apt-get mlocate
update db: sudo apt-get updatedb
use locate: locate libnvbuf_utils
Reference link:
https://github.com/madisongh/meta-tegra/blob/master/recipes-bsp/tegra-binaries/tegra-libraries_27.1.0.bb
Yugui
May 8, 2017, 6:31am
5
Hi Andrey1984,
I opened the path /usr/lib/aarch64-linux-gnu, but there is no tegra directory.
I try to search libnvbuf_utils and libnvjpeg in whole TX2 system, but can not find them.
Yugui
May 8, 2017, 7:43am
6
Hi Andrey1984,
Could you help send me these two libs, my e-mail is xuyugui@huawei.com , thanks very much.
The files are represented in the System by default, presuming you have made flashos with Jetpack 3.0 with all packages selected. It results in 27.1 tegra with all corresponding files installed.
I have attached the two files, But I suspect the problem is rooted deeper than there.
It seems that the forum deletes the attachments.
files : Download
Could you check your tegra installation with
sha1sum -c /etc/nv_tegra_release
and check all is ok ?
