Hi
I build Tensorflow 1.7 on my TX2. i installed it using sudo pip3 install tensorflow-1.7.0-cp35-cp35m-linux_aarch64.whl. THere were no errors as you see below
Successfully installed tensorboard-1.7.0 tensorflow-1.7.0
In PYthon3 when i say import tensorflow as tf I am getting below error
File “/usr/local/lib/python3.5/dist-packages/tensorflow/python/pywrap_tensorflow.py”, line 58, in
from tensorflow.python.pywrap_tensorflow_internal import *
File “/usr/local/lib/python3.5/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py”, line 28, in
_pywrap_tensorflow_internal = swig_import_helper()
File “/usr/local/lib/python3.5/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py”, line 24, in swig_import_helper
_mod = imp.load_module(’_pywrap_tensorflow_internal’, fp, pathname, description)
File “/usr/lib/python3.5/imp.py”, line 242, in load_module
return load_dynamic(name, filename, file)
File “/usr/lib/python3.5/imp.py”, line 342, in load_dynamic
return _load(spec)
ImportError: /usr/local/lib/python3.5/dist-packages/tensorflow/python/_pywrap_tensorflow_internal.so: undefined symbol: _ZN3Aws11Environment6GetEnvB5cxx11EPKc
During handling of the above exception, another exception occurred:
File “”, line 1, in
File “/usr/local/lib/python3.5/dist-packages/tensorflow/init.py”, line 24, in
from tensorflow.python import * # pylint: disable=redefined-builtin
File “/usr/local/lib/python3.5/dist-packages/tensorflow/python/init.py”, line 49, in
from tensorflow.python import pywrap_tensorflow
File “/usr/local/lib/python3.5/dist-packages/tensorflow/python/pywrap_tensorflow.py”, line 74, in
raise ImportError(msg)
ImportError: Traceback (most recent call last):
return _load(spec)
i looked upt https://www.tensorflow.org/install/install_sources#common_installation_problems but it is of no help.
I searched google but still of no help
I am running CUDA 9.0 Cudnn 7.0.5 and PYthon 3.5
I tried with Tensorflow 1.6 and also 1.5 but same issue
Hoping someone can help me here. Thanks in advance
