Tensorflow installation problem on TX2
I installed tensorflow-gpu on TX2 per the following instructions:
But, when I try to verify the installation by importing tensorflow in python3, I get a segmentation
fault. Pease advise.
Hi deshanej
Please refer below link if can help on resolving your issue: https://elinux.org/Jetson_Zoo#TensorFlow
Thanks for the assistane, I uninstalled the tensorflow mentioned above, and reinstalled per the instructions in the link that you referred:
install prerequisites
$ sudo apt-get install libhdf5-serial-dev hdf5-tools libhdf5-dev zlib1g-dev zip libjpeg8-dev
install and upgrade pip3
$ sudo apt-get install python3-pip
$ sudo pip3 install -U pip
install the following python packages
$ sudo pip3 install -U numpy grpcio absl-py py-cpuinfo psutil portpicker six mock requests gast h5py astor termcolor protobuf keras-applications keras-preprocessing wrapt google-pasta
install the latest version of TensorFlow
$ sudo pip3 install --pre --extra-index-url Index of /compute/redist/jp/v42 tensorflow-gpu
Tried importing tensorflow in python3, got the segmentation fault again.
Is building from source the next option? But still curious as to why this aforementioned method fails.
A possible issue is that you are using the package built with different JetPack version.
Please use this command for the JetPack4.2.1:
sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v42 tensorflow-gpu==1.14.0+nv19.10
The issue is fixed. Looks like the TX2 wasnt flashed properly, once reflashed, everything works fine.
