sudo apt install tesnorrt
returns
Some packages could not be installed …
… unmet dependencies:
tensorrt : Depends: libnvinfer4 (>= 4.0.2) …
and I guess it is because this is not compatible w cuda9.0
returns
I am seeing the same issues - When installing libnvinfer4 with
sudo apt-get install libnvinfer4
it says
The following packages have unmet dependencies:
libnvinfer4 : Depends: cuda-cublas-9-0 but it is not installable
I have cuda-cublas-9-1 installed
Same problem here
I think you can install cuda on the .run file. If so, you should uninstall it and reinstall cuda using the .deb file.
run
dpkg-query -W | grep cuda-cublas
, then if the outputs look something like this:
cuda-cublas-9-0 9.0.176-1
cuda-cublas-dev-9-0 9.0.176-1
then your problem will be solved
