Hello All,
I have a ThinkPad 51 Laptop with an hybrid video card I use Gentoo as OS, when I resume system from suspend text and icon become corrupted. I use Cinnamon as desktop and the workaround for this problem is Alt+F2 and r.
If I modify this option “options nvidia NVreg_PreserveVideoMemoryAllocations=0” to “options nvidia NVreg_PreserveVideoMemoryAllocations=1” from /etc/modprobe.d/nvidia.conf everything work fine but the system will never go into the suspend mode.
Is it a way to have in same times the possibility to enter in suspend mode and the resume of system works fine ?
Below information my hardware configuration :
root@himalaya /etc/modprobe.d # inxi -GAz
Graphics:
Device-1: Intel HD Graphics 530 driver: i915 v: kernel
Device-2: NVIDIA GM206GLM [Quadro M2200 Mobile] driver: nvidia
v: 535.154.05
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB
Display: x11 server: [X.org](http://X.org) v: 1.21.1.11 driver: X: loaded: intel dri: iris
gpu: i915,nvidia resolution: 1600x900~60Hz
API: EGL v: 1.5 drivers: iris,nvidia,swrast
platforms: gbm,x11,surfaceless,device
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.154.05
renderer: Quadro M2200/PCIe/SSE2
Audio:
Device-1: Intel CM238 HD Audio driver: snd_hda_intel
Device-2: NVIDIA GM206 High Definition Audio driver: snd_hda_intel
API: ALSA v: k6.6.13-gentoo status: kernel-api
Server-1: PulseAudio v: 17.0 status: active (root, process)
Many thanks in advance for your help.
Kind regards,
Willy
Please enable the needed systemd units.
Hi Generix,
Thank you for your reply, I don’t use systemd subsystem I use rc, below a status of all services :
root@himalaya ~ # rc-status --all
Runlevel: boot
hwclock [ started ]
loopback [ started ]
modules [ started ]
procfs [ started ]
binfmt [ started ]
fsck [ started ]
root [ started ]
mtab [ started ]
localmount [ started ]
sysctl [ started ]
bootmisc [ started ]
termencoding [ started ]
keymaps [ started ]
save-keymaps [ started ]
swap [ started ]
seedrng [ started ]
systemd-tmpfiles-setup [ started ]
save-termencoding [ started ]
hostname [ started ]
consolefont [ started ]
elogind [ started ]
Runlevel: sysinit
sysfs [ started ]
devfs [ started ]
udev [ started ]
dmesg [ started ]
kmod-static-nodes [ started ]
systemd-tmpfiles-setup-dev [ started ]
udev-trigger [ started ]
cgroups [ started ]
Runlevel: nonetwork
local [ started ]
Runlevel: shutdown
killprocs [ stopped ]
savecache [ stopped ]
mount-ro [ stopped ]
Runlevel: default
rsyslog [ started ]
wpa_supplicant [ started ]
nordvpn [ started ]
netmount [ started ]
acpid [ started ]
dbus [ started ]
display-manager [ started ]
alsasound [ started ]
atd [ started ]
chronyd [ started ]
clamd [ started ]
cupsd [ started ]
freshclam [ started ]
libvirtd [ started ]
libvirt-guests [ started ]
numlock [ started ]
openrc-settingsd [ started ]
sshd [ started ]
xdm [ started ]
local [ started ]
Dynamic Runlevel: hotplugged
Dynamic Runlevel: needed/wanted
dhcpcd [ started ]
display-manager-setup [ started ]
virtlogd [ started ]
Dynamic Runlevel: manual
Thank you for your help generix, infortunetly the fix does’nt work probably because I use xorg server.
Hi Generix,
You can close this case now because I’m installing Gentoo on another notebook (ThinkPad E14).
Thank you so much for your help.
Have a nice day.
Willy
