The camera displays only a single frame and then freezes
I am working with the TP2855, receiving input from four cameras and outputting via MIPI 4-lane.
When I run the following command:
gst-launch-1.0 -v v4l2src device="/dev/video0" ! video/x-raw,framerate=30/1,width=1920,height=1080,format=UYVY ! autovideosink
the camera output displays only 1–2 frames and then stops, showing the following log messages:
[ 1904.137310] bwmgr API not supported
[ 1904.193669] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 2, flags: 0, err_data 64
[ 1904.227008] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 3, flags: 0, err_data 64
[ 1904.260361] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 4, flags: 0, err_data 64
[ 1904.293660] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 5, flags: 0, err_data 64
[ 1905.114049] bwmgr API not supported
I have also attached the trace log for reference.
I would greatly appreciate any advice or suggestions regarding this issue.
Thank you.
trace.log (90.8 KB)
Looks like PIXEL_RUNAWAY that tell the output pixel more than expected and CHANSEL_NOMATCH that could be incorrect embedded_data_height in device tree.
Also looks like sensor didn’t send FE but only FS.
