Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim · GitHub ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
Isaac Sim Version
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: Geforce rtx 4070 super ti
- Driver Version: 570.124.06
Topic Description
The delay node cannot work correctly when i use a ros2 camera helper node to send camera render imag msg to ros2(ros2 is humble).
Detailed Description
When I used the ros2 camera helper to send camera rendered images in the action graph, I had other business logic that required a delay node. However, I found that the node after the delay node would not execute (the execution of the graph stopped at the delay node). When I turned off the ros2 camera helper, the node after the delay node could execute.
Steps to Reproduce
open isaac sim assets/samples/ROS2/ROBOTS/Nova_Carter_Joint_States_ROS.usd in isaac sim
add a action graph with delay node,(On stage Event/simulation start play)–>Delay–>Print Text
click play, the print node can not perform
stop the simulation. disable the ROS2 Camera Helper node in the action graph under the Nova_Carter_Joint_States_ROS.usd
click play, the print node can perform
(Add more steps as needed)
Error Messages
(If applicable, copy and paste any error messages you received)
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
